Question about Samsung S850 Digital Camera
The camera cannot be operated even when it is turned on.
Camera will not turn on, even with new batteries
Do you get a flashing low battery symbol? If so, try setting it on P instead of the green rectangle. If it then operates then the shaft in the flash pivot is bent and not operating the flash switch.
Sep 11, 2013 | Canon EOS Elan 7 35mm SLR Camera
Why does my Samsung i85 digital Camera does turn not on even with a new charged battery
Sure the battery is charged? Can you operate the camera with just the adapter? If so, does the camera work then. If so the new battery is defective.
Sep 24, 2017 | Samsung i85 Digital Camera
Camera wont turn on, even when i plug it into computer
The problem is in the systems control board, "controls all aspects of the camera's operations, a camera specialist is the best option at this point in time.
Apr 21, 2012 | Nikon Coolpix S3100 Silver Hd Digital...
Mv500 camera batteries run down fast
you need some new acumulators or alkaline batteries
Oct 27, 2009 | Microtek Take-it MV500 Digital Camera
Won't turn on!
Had that problem too in October (during vacation in Sardinia); had to return the camera to Canon for repair. They noted a change of circuit ...
It 's now fully operational again
Aug 02, 2009 | Canon IXUS 960 IS Digital Camera
Camera problem
could be either camera module failure or flexcircuit cable failure, just take it to authorised nokia care, as it is a little bit difficult to replace these parts, or even get them
May 30, 2009 | Nokia 6280 Cellular Phone
Olympus Stylus 730 shuts off after few seconds. Battery is fully charged, tried a resetting: no change.
To save battery power, the camera automatically goes into sleep mode and the monitor turns off if there is no operation when the camera is turned on (when the lens cover opens and the monitor is on). No picture is taken even if the shutter button is fully pressed in this mode.
Operate the zoom lever or other buttons to restore the camera from sleep mode before taking a picture. If the camera is left for 15 minutes, it automatically turns off (the lens cover closes and the monitor turns off). Press POWER to turn the camera on.
Mar 26, 2009 | Olympus Stylus 730 Digital Camera
Camera problems
Turns out the brand new batteries I installed were dead.
Mar 18, 2008 | Samsung Digimax S500 Digital Camera
Samsung S850 Digital Camera Logo
15 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
