Question about Maytag MAH6500 Neptune Front Loading Washer w/Built in Water Heater
2002 Maytag Neptune front load washer has an odor like a burnt rubber odor.
  • 15,935 Answers
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a "Clean Cycle" available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!@@
Posted on Sep 28, 2010
Is there any kind of recall on a Maytay front loading washer, model #MAH6500AWW? I am having problems with mildew in the rubber part and terrible smelling water in the bottom.
The cleaning process for your Maytag Neptune front-loading washer, for example, requires some time and patience. Over time, your washing machine will need to be cleaned. It can develop offensive odors through multiple wash cycles. This makes the washing machine less effective at cleaning the clothes you put into it. Maytag offers some sound advice for cleaning your front-loading washing machine.
  • Pour 2/3 cup of liquid chlorine bleach into the bleach compartment of the dispenser drawer of your Maytag Neptune front-loading washer.
  • 2
    Run your Maytag Neptune front-loading washer on the "Clean Washer" setting. Press "Start" to start the cycle.
  • 3
    Leave the door open once the cycle is complete to allow the inside of your Maytag Neptune front-loading washer to ventilate and air dry.
  • 4
    Look closely at the gray seal of the Maytag Neptune front-loading washer's door opening. This seal can have a buildup of debris or detergent residue.
  • 5
    Spray the seal with an all-purpose appliance cleaner and scrub away any debris or residue with a cloth or scrubbing pad. Dry with a clean cloth.
  • 6
    Remove the soap dispenser drawer. Press the release lever and lift it out to clean.
  • 7
    Take out the inserts and rinse them and the drawer thoroughly.
  • 8
    Wash with a mild soap and cloth to remove any residue. Dry thoroughly before replacing.
  • ALWAYS LEAVE THE DOOR OPEN WHEN NOT IN USE! This prevents the mold and mildew from forming once you get it cleaned.
    Aug 20, 2011 | Washing Machines
    Burning smell from washer
    YOUR DRIVE BELT MAYBE WORN AND NEED REPLACEMENT.
    Oct 26, 2009 | Maytag Neptune MAH5500B Front Load Washer
    Maytag Neptune washer has bad odor, city water.
    There is no filter in your washer that would cover the odor issue.
    The website link below will give you all the information concerning odors in a Maytag Washer
    http://maytag.custhelp.com/app/answers/list/kw/odors/p/293/r_id/108284/sno/1/search/1/session/L3NpZC9RRDdZdDhEag==
    Jul 18, 2009 | Maytag Neptune MAH5500B Front Load Washer
    Mold in rubber ring front loader Fridgidare washer
    Common problem. Clean the moulding as best you can, even scour with steel wool. Leave the door open so the machine will be dry when not in use or/and wipe the rubber after each use. You can try to cover up the odour by wiping with a rag moistened with vanilla essence. Otherwise fit a new rubber and keep it dry in future.
    Jul 03, 2009 | Maytag Neptune MAH5500B Front Load Washer
    Sometimes there is water that fills in my washer after I use it. It does not happen right away but by the next day. I don't know the model but I do know this is an old washer....gold....I have had it for...
    Q - My washer seems to keep filling  with water, the water keeps coming in the washer and going out the drain without the washermotor running.
    A - This often is a drain hose that is too low or a drain hose that has been pushed too far down inside the stand pipe....the water is actually siphoning out of the washer. Do not "seal" the drain hose to the house plumbing pipe, this will also allow the water to be siphoned out.
    1. Boot change helps
    2. Consumer Display Code Table on the Electronic Display Maytag Neptune Front load washer
    3. Free on-line repair manual for the Neptune washer MAH3000, MAH4000, MAH5500, MAH7500  ( Acrobat reader required )
    4. How to access the console on the mechanical timer models
    5. How to access the workings of the washer
    6. My washer door is locked and it will not open up...HELP
    7. My washer will start when I push the start button, but a few seconds later, it will shut off
    8. My washer will not pump out + pump noise problems
    9. My washer will not spin
    10. Odor complaints from the front load Neptune washer - mildew complaints + a new "freshen up" procedure
    11. Parts breakdowns/exploded of the Maytag Neptune front load washer ( mechanical timer models )
    12. Problem chart for MAH3000 & 4000 Neptune washers
    13. Readers repair tips
    14. Trouble shooting tips from the Neptune manual for MAH3000 and MAH4000 models
    15. Tips from our friendly engineer on changing the boot and re-installing that clamp and spring
    16. Tips on changing the washer belt  ( acrobat reader required ) Belt parts link
    17. Tips that show what components need to be checked/replaced if a certain resistor on machine control board is bad. It is as follows: Burnt resistors in Maytag Neptune washer models MAH4000 and MLE/MLG2000
    18. Washing one item in a front load washer
    Apr 01, 2009 | Maytag Washing Machines
    Washer will wash but not spin
    Sounds like the control board is bad. take the back panel off the control panel and look at the R11 resistor and see if it burnt. If it is replace the control board and the door wax motor (in the locking mechanism)
    Nov 21, 2008 | Maytag Neptune MAH5500B Front Load Washer
    Maytag neptune front load odor
    its better do a maintenance, or put it to wash without cloths, only water and clorox, and varsol with the max level (water)
    Nov 12, 2008 | Maytag Neptune MAH5500B Front Load Washer
    Dirty sock smell
    My suggestion is to contact Maytag. I have the same problem. Maytag can tell you what you can do to reduce the odor. I think the problem originates from the fact that the drum always has water in it and the rubber seal has a bad smell.
    Sep 07, 2008 | Maytag Neptune MAH5500B Front Load Washer
    Mold and smell
    This is a problem common to many front load washers. Besides being very important to wile the the rubber boot down thoroughly there are a couple of products that claim to get rid of the mold and smell. I, myself, have ***** tried these but you might want to give it a shot. One of them is called Purewasher and is offered on the site www.smellywasher.com. Some time ago Maytag came out with a Mildew/Odor kit that they may still provede. again, I don't know for sure how well it works but it too may be worth trying
    Jan 27, 2008 | Maytag Neptune MAH9700 Front Load Washer
    Maytag MAH6500 Neptune Front Loading Washer w/Built in Water Heater Logo
    236 people viewed this question
    Top Maytag Washing Machines Experts
    Bill Long
    John Tripp
    John Tripp
    Dan Webster
    Dan Webster
    Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
