Question about Philips LX3000D System
The power button on my Philips DVD player blinks.
My DVD player will do nothing. While it is plugged in the power button continously blinks. It will not eject a DVD nor play. After I unplug it the power button blinks for aproximatly 2 seconds and then turns off. The model # is HTS3410D/37, and the serial # is KN020630146474
  • 3 Answers
The Front PCB might be damaged. Check the front PCB
Posted on Jan 06, 2009
Power light blinking unable to turn on
And get no display?
Probably the power supply, or some other relatively catastrophic problem happened.
If it's still under warranty call Philips tech support first, for possible replacement.
Else you're probably looking at buying a DVD player, unless you want and are willing to open it up and fix it your self (time consuming).
Jul 20, 2010 | Philips DVP642 DVD Player
My Philips dvd player model DVP642/37 is not working. The stand by/ on button flashes the red light on and off slowly and non of the other buttons respond on the machine or the remote for the dvd player...
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Apr 21, 2017 | Philips DVP642 DVD Player
Dvd tray won't open. Says blocked then open & close but nothing is happening. It's making a noise & the dvd loading sign is continously on the tv
hello. I've had the same problem...I resolved it leaving some cd or dvd inside for ever.
To put into a dvd, look at the picture and the service manual
Jun 10, 2010 | Philips DVDR3455H/37B
one of these philips/magnavox codes should work press dvd and ok buttons then release - the top row of buttons will blink twice - then enter 4 digit code - after which the dvd button will blink twice - then try power - if fails - try next code.
2002, 2018, 2032, 2033, 2045, 2051, 2089, 2091, 2109, 2169, 2208, 2209, 2222, 2237, 2241, 2243, 2259, 2260, 2264, 2270, 2282, 2285, 2293, 2302, 2304
Sep 08, 2009 | Philips Magnavox MWD7006 DVD Player
DVD player disc tray won't open
take a screw driver and open it up
maybe its a disc that stuck
if not working
probably cheaper to buy a new one
Apr 28, 2009 | Philips DVD793CH Multi-disc DVD Player
There is a DVD in the player that wont eject or play.
Instead of a pinhole, there is a slot on the bottom of the DVD player that will force the disc out. There's a plastic lever visible on one side of the slot. I used a butter knife to push into the slot.
Nov 29, 2008 | Philips DVP642 DVD Player
Blinking lights
I left if off and unplugged for a few hours. When I plugged it in it started working again. My recommendation if this happens to you is to just unplug it all and let it stand for at least 4 hours and then plug it back in.
Good Luck
Oct 01, 2008 | Sony RDR-VX555
Philips DVD Player Seems Dead
It looks like this problem has been discussed here: "Standby light blinking."
Mar 24, 2008 | Philips DVP642 DVD Player
DVD player froze, now only turns off
Sounds like the power supply in the dvd player has failed. It works just well enough to turn on the led infront but as soon as you go to do anything it shuts off. This is common in cheaper dvd players. Unless you can troubleshoot electronics. Or know someone that can. Your best bet is to unplug the unit and disassemly and retrieve your dvd.
Jan 13, 2007 | Philips DVP642 DVD Player
Philips LX3000D System Logo
391 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
