Diodes gone in inspiron 1525
''is it a big job to replace diodes in the rectifier circuit of an inspiron 1525
  • lahtac087057 Nov 17, 2009
    im was just going by an answer that i recieved from my first posting. the symptoms are the computer powers on as normal, but the screen is blank, no cursor or anything. to the left of the power button on the inspiron 1525 there are three symbols that look like padlocks, the first one is lit and stationary,the other two are flashing. the computer is not responsive to any keys.
  • Jon Hunter May 11, 2010
    Why do you think you need to replace the rectifier circuit? Most of that circuitry is in the power brick and they are too cheap to even bother opening up.
    If you are having a battery charge issue that is due to a fault on the power/USB sub board.
    Let me know exactly what your symptoms are and maybe I can help.
    JC
    Sniper:
  • 66 Answers
Trust me. You're much better off buying a new computer than having to pay someone to solder the small diodes in a laptop motherboard.
Posted on Nov 17, 2009
    Scholar:
  • 101 Answers
The padlock lights are for numlock,caps lock, and scroll lock. The fact that two are flashing may indicate problems with keyboard.
One thing you can also try is playing a music CD - if it plays it is probably your lcd inverter.
1. Make sure no keys are stuck on the keyboard - look carefully.
2. If that doesn't do it then try to get an external keyboard - I think you will need a USB as that model has no PS2 plug. Plug the keyboard in before starting and see if it will override the internal kbd.
3. Have you tried to access BIOS using the F2 key right after powering on?
Let me know what you find.
JC
  • Jon Hunter Nov 17, 2009
    I ran across some posts on other Dell laptops that attribute the flashing leds to a memory problem. You may try removing 1 ram block if there are two and trying 1 ram block in each slot. Remember to static discharge (ground) yourself first (touching the metal case of a desktop works fine.
    JC
In onida tv d2498 and fuse in power supply gone on connecting ac.Without main board installing please help
If it's not the main board that's causing the fuse to blow then you have a short circuit somewhere in the power supply. Check things like the electrolytic capacitors. The ones that look like little cans. They should all have flat tops. If any are bulging out at the top they will need replacing. Also check the bridge rectifier which is a black component usually standing up on the board with four legs. If there is no bridge rectifier there will be 4 rectifier diodes together. They are black cylindrical items with a sliver band on one end and a lead out of each end. They are usually located near to where the mains lead enters the power board. Other things to check are power transistors, they are usually 3 legged, (sometimes 2 legs if they are used as a diode) black items with their case fixed to a heat sink (aluminium block.)
Dec 15, 2014 | Televison & Video
How do you test a diod in the circuit
First of all it is called a diode and it is an active component. The way you test it is , first remove power from the circuit, then using a ohm meter on the high power ohms or diode test function. It should read high resistance in one direction and low resistance in the other direction you also can use a battery and light bulb in series connected to the diode. The light should light in one direction and not the other. If the diode is across a coil or low resistance device it may not be able to be tested accurately in circuit, in this case one end will need to be lifted from the circuit to test.
Aug 07, 2014 | Electronics - Others
If the rectifier is defective would it chip tht circuit bbaker to the power source
Yes almost certainly if it (the rectifier) has gone short circuit, but you should be able to test the rectifier with a test meter; disconnect mains and rectifier, forward and reverse resistance should be low and very high for each diode leg in each direction of test leads (4 diodes if it has 4 wires)
test each leg both ways, or get testmeter with diode test
Jul 14, 2014 | Black & Decker 19" Electric Lawnhog...
DIODE PART NUMBER 907 ON POWER SUPPLY CIRCUIT HAS HOW MANY VOLTAGES
That diode part number is not recognizable. IT IS possible that the full number is 1s1907.which is a 400PIV diode.
If the diode is about 3/8 inch long and 1/8 diameter replace with a 1N4007 which should have adequate voltage margin if it is a rectifier diode.
One has to be careful as the original could also be a Zener regulator. The board nomenclature for that would likely have "ZD" followed by a number. Verify the diode is used as a rectifier type by tracing the circuit enough.
Oct 05, 2009 | Sharp XR-11XC Multimedia Projector
My Dell inpiron 1525, does turn on but the display is extremly low... can hardly even read anything... plzhelp
This sounds like the backlighting/inverter has gone out. This can be fixed. It is a fairly tedious job. To have it serviced would range from 100-200$ depending on cost of parts and your location.
Thanks,
Lee
Jul 08, 2009 | Dell Inspiron 1525 Laptop Jet Black (15.4"...
Lose power.
To test the rectifier, hook up the ohmmeter leads to one of the wires and to the ground (mounting) stud. Note the reading you get. Now reverse the leads from the ohmmeter and note the reading again. The exact reading is not all that important, but there should be a big difference between the two if the diode is working right. Test each of the wires this way. If any wire is very close in the two readings then the diode is leaking and no good. If there is no continuity, then the diode is shorted out and no good. Be careful not to turn the bolt holding all the diodes together. This can short them out. It is possible to test the rectifier with a circuit tester by adding a D flashlight battery in line with the circuit tester. You want to see the light, light in one direction and not in the other. If all of a sudden you start blowing the main fuse, it's possible one of your rectifier diodes has failed, letting current, from the battery flow back to ground.
Apr 08, 2009 | 2002 Suzuki GSX-R 600 M
Computers & Internet Logo
315 people viewed this question
David Payne
David Payne
