Phillips HDTV model number: 55PP935217
The screen shows double. Out of focus and blury or slanted.
  • Anonymous Feb 09, 2008
    out of focus red blue colors not working right seperated from other colors and blury
  • evansandsons Sep 11, 2008
    mine just seems out of line idont have any dark or light spots it seems every thing is out of line even the picture at one end seems slanted help how is best way to line and adjust colors from back any body no where i can get a manual ? thanks chuck
It sounds you need to have the convergence block fixed. I had the same problem and called a repairman locally. he came out and fixed it in a couple of hours. looks great now, cost 150 bucks
Posted on May 15, 2008
Picture looks like its red and green 3-d,Phillips 55pp935217
Ur convergence it dead,Need a convergence kit,use what in that kit,Know how to solder righht?Tries Tv Repair World.com,Ebay.com.
Oct 06, 2009 | Philips 55PP9363 55" Rear Projection...
Blury screen on panasonic 1080i hdtv
seeing double and a lot of green on my panisonic hdtv 1080i what do i need to replace?
Aug 23, 2009 | Panasonic Televison & Video
Half of the screen is clear and left side of the screen is blury
Its a Common Problem with Projection Tv's ~ If your flash focus is not correcting the problem, And It can Not be Adjusted in your service menu: under Manual Convergence, your IC chips and maybe a few resistoirs may have failed and need to be replaced!... onegeo
Jul 07, 2009 | Sony KP-46WT500 46" Rear Projection...
Phillips tv , double vision,
You have bad convergence IC's. Replace both the red and blue drive chips. They are easy to spot. They are mounted to large, finned heat sinks. The # on the chips starts with "STK-" and then there are numbers following. Both red and blue use the same part. There are 20 or so pins to unsolder\solder. These parts are available to the consumer from tritronicsinc.com. Good Luck!!
barneyluc
Oct 03, 2008 | RCA R52WH73 Projection Television
Have phillips 55 hdtv that needs convergence badly
OK, friends.. Replace two Ic's Stk 392-110, and get in service menu settings , and adjust point by point. After replaced stk IC's, check if any resistor look brown or born, if yes, replaced it with 6.8 Ohms.SOme time SSB is defective ( small signal board, replaced it ) If you have questions? noetvs@embarqmail.com . Good Luck !!
Jul 12, 2008 | Philips 60PP9202 60" Rear Projection...
TV Color
You need to replace both convergence ICs they are both STK392-120 and you will also need four 6.8 ohm 1 watt metal film resistors. You can get the ICs and resistors at the following link and they will provide free instalation instructions with pictures so you can do the repair yourself. Here is the link.
http://servicemanuals.vstore.ca/
Jul 04, 2008 | Philips 60PP9202 60" Rear Projection...
Philips 55" hdtv rear projection internal parts
If your model number is 55PP935217 you dont have a ballast. You have a rear projection with 3 CRts . Please let me know if thats the correct model number and what your symptons are. I will be able to help you get what ever part youre needing.
May 22, 2008 | Philips 55PP9352 55" Projection Television
Focus block is at max still blue
the convergance amplifier have failed there are two of them they need to be replaced. there may be some pico fuses and resistors also. convergance failure is the most common rear projection tv it makes the set appear blury.
Feb 21, 2008 | Hitachi 46F500 46" Rear Projection...
Televison & Video Logo
292 people viewed this question
Top Televison & Video Experts
