Question about LG 50PX1D 50 in. Plasma Television
I have a 4 yr old LG 50PX1D plasma tv and it works fine for about 20-30 min then the screen goes black. If you turn it off for an extended period, then back on, you can watch for another 20-30 min. Any clues on what would be causing this? I'm about ready to trash this thing.
  • 335 Answers
Its either the XYZ circuits, power supply, or bad ESR conditions starting to develop. Have your local shop repair it for you....
The set is 4 years old, and usually problems in Plasma tv's develop before then......
Posted on Nov 21, 2009
I have a LG 50PX1D 50 in. Plasma Television. it turns on and stays my sounds or working fine. but no picture.. i have checked the power board and the capacitors are ok, and the fans are working @ normal...
You need to replace both the Y and X-sustain boards to light the tv. If the voltage is fine from the power supply then those are the only other boards related to lighting the plasma gas.
Thank you!
Jul 07, 2011 | LG 50PX1D 50 in. Plasma Television
Keeps turning its self off
My MS access files has locked, and now i foget my password, so can you help me,,,how can i open this,,, do reply ,,,,,,,,,which s/w break this password......
Apr 30, 2010 | LG 50PX1D 50 in. Plasma Television
I have a LG 50PX1D-UC plasma TV with a black vertical line
You could have a Driver Board that has a loose connection or a Ribbon Cable that has a intermittent connection to the Plasma Panel, or a defective Plasma Panel. Either one could cause the problem and I would recommend only a Qualified Service Person to check it out.
Here is LG's Customer Service Number. 1800-243-0000. They could direct you to a Local Service Facility.
I hope this helps,
Sky Assoc
Oct 25, 2009 | LG 42PX5D 42 in. Plasma HDTV
I have a lg 50px1d 50" plasma tv that has 2 vertical lines down the screen what can I do to fix this?
Sounds lik a bad buffer board. you will probably have to have a tech replace it.. could be big $$$. get an estimate first.
Oct 23, 2009 | LG 50PX1D 50 in. Plasma Television
LG 50PX1D Plasma TV with dark and fuzzy picture
Z-Sustain PCB will cure it.
It is inside the TV, on the Right Hand Side.
www.chsinteractive.co.uk or Google for a replacement.
Sep 08, 2009 | LG 50PX1D 50 in. Plasma Television
42 inch LG Plasma TV - Lost picture
Hi , I recently had the same problem which I was determined to fix . So I did a few weeks of research to find that it was the Y SUS board which burns out. I'm sure you realized that the TV gets hot. Personally I think this is why. circuit boards don't like heat and I've learned that the cooling fans are a joke. I replaced the board and got my picture back. I proved the fan theory because after the screen started to act up. I placed a cooling fan near the vent holes on top and the problem cleared right up,It also helps if you lower the brightness which helps out on the heat situation.I will soon be adding a fan with a temp. sensor. This shoud help if your screen has lines when you initially turn the cool TV on.then I have Some other costless solutions. Hope this helped these are great TV's and like our cars we maintain them not throw them away..................................Mr Wiseman
Sep 16, 2008 | LG 50PX1D 50 in. Plasma Television
Pink lines only down the middle of the screen aprox. 12" wide for spit second.
Most likely will get worse as you are describing a failing control bd. The part # is 6871QCH038A and is a fairly complicated repair. A good deal of disassembly required, and I would take advantage of your service agreement.
Apr 13, 2008 | LG 50PX1D 50 in. Plasma Television
Vertical bar on Daewoo Plasma screen
YES YOU HAVE DRY JOINTS UNPLUG FROM POWER SUPPLY REMOVE THE BACK/ INSIDE YOU SHOULD SEE AT THE BOTTOM SEVERAL RIBENED CONECTORS FROM THE SCREEN ITSELF? UNDERNEATH YOU SHOULD BE ABLE TO SEE 2 OR 4 COMPONENTS CAREFULLY APPLY A HOT SOLDERING IRON AN SOLDER THE ONE THAT YOU ARE HAVEING PROBLEMS YOU SHOULD NOW HAVE FULL PICKTURE AGAINE ANY PROBS email me andymay2@msn.com
Mar 09, 2008 | LG 42PX5D 42 in. Plasma HDTV
LG 50PX1D 50 in. Plasma Television Logo
291 people viewed this question
Computer Repairing
Computer Repairing
