Question about Air Tools & Compressors
Portable air compressor won't start
My Husky portable air compressor was running when we had a power outage, and now it will not power back on. (Flip the switch, nothing happens at all.) Is there possibly a cheap fix, or am I better off just purchasing a new (more reliable) Porter Cable?
  • 530 Answers
To be honest with you your compressor is what is commonly referred to as a throw away. You can't even imagine how many times I have posted that in the past month for your compressor and similar ones, such as the 3 gallon 1.5 hp craftsman.
The Porter Cable Is more reliable or rather it used to be. I believe that there are so many manufactures around the world pumping these things out that in order to get a reliable compressor you have to do it through the warranty. I know Senco makes a pretty good portable compressor. I believe Home Depot carries it and the cost is around $125.00.
That said your compressor may be salvageable so don't write to Santa just yet.
Almost all compressor,(even the throw a ways), come with a reset switch. The problem is finding it.
If you don't have your manual then start looking. You may need to remove the plastic shroud to locate it. All it is is a small black or red plastic button about a 1/4" in diameter.
Since you stated that there was a power outage that kind of rules out loose wiring or incorrect extension cord size. You may want to check the breaker though. You may have already but check it again. You want to turn it off and on a couple times to see or rather feel if the breaker itself has became compromised.
I hope something here helps.
Posted on Nov 17, 2009
Testimonial: "Thanks very much digritz! I knew it was a throwaway when I bought it, but was hoping to get more than 15 months use out of it since I barely use it.."
  • david mcclellan
    david mcclellan Nov 25, 2009
    After I read your "Testimonial" I wasn't sure if you checked the other possible causes I added at the end of my solution regarding the reset switch and the breaker. I hope you check those before you give up on the compressor because throw away or not money is money. So please don't toss it out until you checked those items.
    Also I am going to stick a link here just in case. You might be able to find parts for your compressor here.
    Good Luck.
    http://www.mastertoolrepair.com/husky-pa...
Compressor won't build more than 50psi
Check all connections with leak detector or a soapy water mixture for any possible air leaks.
Mar 30, 2014 | Husky Electric Portable Air Compressor:...
Why wont my air compressor hold pressure
i dunno how it works but there should be a little pin on it and try pushing it in
Dec 01, 2012 | Husky Air Compressor. 2 Gal. Portable...
Husky generator won't start
did you try cleaning the conductor that goes to the spark plug if not try to clean it with a real fine sand paper it should do the job.
Oct 27, 2012 | Husky Portable generator
Need Manual for Husky Model 41214 Air Compressor
You can get the manual for model 41214 from my dropbox area:
http://dl.dropbox.com/u/54567653/husky_aircompressor_model_41214.pdf
BTW, if you find this manual helpful consider installing dropbox using this link (full disclosure -- I do get about 0.2 GB freespace from dropbox if you install using this link):
http://db.tt/vQycqXIW
Thanks,K
Dec 20, 2009 | Air Tools & Compressors
Air conditioner compressor runs for about 1-2 min, then cuts off
well when u have outages the voltage drops obviously, the one that suffers are the capacitors the capacitor for the compressor might need to change, change it with the same capacity as the old one example if labels say 55 microfarady ( mf ) ( 55 mf ) get one of the same I am not saying it is a 55 mf capacitor vary depending on motor and brand. So check the label
Jul 23, 2009 | Danby Portable Air Conditioner
Husky air compressor/1.5 hp
Compressors pull a lot of juice that is why they come with a large power cord. If you use a small extension cord with it it will easily pop a breaker. So first check all your breakers. Second thing is check your manual to see if you have a reset switch on you compressor, as most do. It should be a small, red switch (rocker or push button type), located between the pump motor and compressor switch. The third is a long shot, check to see if the bleeder valve is functioning correctly. It will be the small copper tube running from the pump to the switch. Just make sure the small lever is free to move.
If this fails to resolve the problem then it is probably the main switch itself. That is a warranty issue. If it's out of warranty then your going to have to either repair or replace the switch yourself. Please feel free to ask for help if you need it in latter case.
Jun 07, 2009 | Air Tools & Compressors
Air Tools & Compressors Logo
344 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
