-   can trekkies be banned from this site?(cyrstal solution)
i have the same problem i think, the machine starts to fill but it never fills enough and can't progress in the cycle and just sits there humming-   Guest
Nov 24, 2008
-   Same again. Stopped mid-cycle, salt light on. Now it appears not enough water is coming in, and the arms won't spin-   davidov1975
Nov 09, 2008
-   I have the same problem. Could it be a blocked filter? I don't know where that is!
-   gedw
Oct 07, 2008
-   I have the same problem, and the light is on beside the indicator for salt.
Does anyone know how to fix this?-   shamballs
I am getting water leaking through the diswasher and have a large wet "seal" at the bottom...
(More)
I am getting water leaking through the diswasher and have a large wet "seal" at the bottom of the door. How can I stop the leak?
We have just aquired the machine with the house (no manual) The soap dispenser will not open when...
(More)
We have just aquired the machine with the house (no manual) The soap dispenser will not open when the machine is running. I'd be prepared to stop the machine and add the powder if I knew where in the cycle to do this. The other problem is that the dishes come out with fine grit dried on them. Should I just give up?!
My Indesit D63 won't start running. The power light comes on but then nothing. I've read other...
(More)
My Indesit D63 won't start running. The power light comes on but then nothing. I've read other solutions about how it's usually water draining in to the bottom of the dishwasher, but I've checked that. What I do have is where the salt goes in, there's another plastic section joined on to the salt container, but separated. This appears to be full of fat! I can't see how to open up the plastic container to remove this.
