Question about Maytag MED5600TQ Electric Dryer
Dryer not heating I had the heating element checked--it is good
  • 5,911 Answers
There's more to the heating circuitry than the heating element. If the element is good, more than likely the Thermal Cut-Out (TCO) has blown. This component acts as a fuse in an overheat condition to protect the heating element. There are two components located on the outside of the heater box of the heating element. The one at the opposite ned of the heating element terminals is the TCO, the one closest to the terminals is the Hi-Limit Thermostat. To check either of these components, disconnect the wire leads and remove from the heater box. Take a resistance check across the component terminals and you should get a reading of zero ohms (or something close to it). If either component is bad, you must replace BOTH of them. Failure to do so may result in premature failure of any parts you replace. These two components are sold as a set and can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The part number is 279816. The average cost is about $20. Prices vary between these sites, so shop and compare. If you do not wish to order on line, take the part nukber provided to your nearest appliance parts retailer. This is a common replacement item they should have in their in-store inventory.
The first three sites on the list also offer excellent exploded view diagrams to assist you in locating components. The TCO (with Hi-Limit Thermostat) is listed as item 9 under the "Bulkhead" parts section.
If you have any questions, please let me know. I hope this helps you.
NOTE: If the TCO blows, it usually blows for a reason. Most commonly, this is caused by the dryer exhaust vent becoming clogged. It is adviseable to inspect the entire length of the exhaust vent ducting and dryer interior to ensure you have no clogs anywhere. Failure to do so will result in repeated failures of the heating circuit and it is a fire hazard.
Also make sure the vent hose is not kinked or crushed. It is recommended that you use the semi-rigid metal type exhaust vent ducting as it resists kinking, crushing, rodent infestation and heat. Make sure the exhaust vent is at least 12 inches from the ground. If you have any type of protective cover on the exhaust, make sure it is of the louvered variety. Do not place screens on the vent as it will collect lint and become clogged.
Posted on Nov 17, 2009
Maytag dryer heating element won't come on
you should have a nominal 240 volts between the 2 heating element connections
Feb 07, 2012 | Dryers
My dryer is turning but the clothes are not drying. There is no heat in the dryer.
Check the dryer heating elements that they are intact. You will have to open the back. Chek for fuses in the dryer. Good luck
Jul 02, 2011 | Dryers
My dryer wont heat up its not the heating elment
If the heating element is good, then you need to check the voltage to the element. I would first check voltage at the heating element connections, should be 220 volts.Then work back through the start switch and dryer selection switch.
Jan 10, 2011 | Dryers
No heat
Well first of all you can tell us the model number of your dryer, so we can help you...... anyway if your dryer is a electrical dryer then first you check Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it. Please post comments for further help or information..........
Good Luck!!
Mar 28, 2010 | Hotpoint Dryers
Kenmore dryer makes no heat
replace the heating element. Or the control panel has weakening capacitor not sending correct current flow to the heating element
Jul 09, 2009 | Dryers
Dryer will not heat
Check to make sure you have 240V at the outlet. If you do, check the continuity of the element and thermostats. If still no heat, it could be the temperature setting switch, the timer or the motor.
Feb 19, 2009 | Kenmore 65924 Electric Dryer
The dryer works but does not heat
Before you buy an expensive heating element change out the thermal fuse. It's only about 15 dollars for a fuse as opposed to around 100 dollars for a heating element. Both can be purchased at a appliance repair shop. The thermal fuse is usually located near the heating element housing and has two wires coming off of it. Make sure you unplug the dryer first though. If the thermal fuse if dead then your heating element will only heat for about a second or two at a time. The way to check this is to open up the dryer so you can see the heating element. While it's running watch it and it the heating element comes on and then turns off then the thermal fuse is bad. If it doesn't come on at all then the heating element is bad. Wait a good 5 minutes though before determining if the heating element isn't coming on. Sometimes it takes a bit before it engages. I hope this helps you and if you have any more questions feel free to ask me. Good luck.
Jan 08, 2009 | Whirlpool GEW9250 Electric Dryer
No heat from dryer
is it 220 volt dryer,if so check the plug at the wall and make sure you have 220,the plug runs off 2 circuit breakers at your electric panel,1 breaker may be no good so your only getting 110 volts to the dryer which will run the dryer but not the heating element
Jul 08, 2008 | Dryers
Whirlpool dryer problem
dryer works but does not heat up
Mar 12, 2008 | Whirlpool LEQ9858P Electric Dryer
Maytag MED5600TQ Electric Dryer Logo
295 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
