Question about Braun Health & Beauty
How do I open case of my Braun Razor 5520 to replace rechargeable battery?
4 Suggested Answers
SOURCE: Braun battery replacement
Unfortunately this is almost impossible. The batteries are part of the circuit board, and Braun only authorize their service agents to replace the whole unit, and my local agent found that it had been discontinued. If you still want to have a go, two screws are hidden beneath the two grey plastic caps either side of the charging socket on the underside of the shaver which can be prized off quite easily. Once you have removed the screws, the small plastic section comes off. Now you can slide the outer casing off. A thin black cover at the back can then be unclipped, revealing the circuit board and batteries. The whole unit simply lifts out and would be easy to replace if you could find one! Rplacing the batteries would be far more difficult and risky. Good luck.
Posted on Sep 02, 2008
SOURCE: how do I open the case to change the battery?
There are 2 removable plastic plates on either side of the power entry connector> Pry these off with a knife and remove the 2 screws. Next slide the razor out of it's case. The batteries are soldered in.
Gary
Posted on May 25, 2009
brector3
  • 1612 Answers
SOURCE: My Braun 5564 electric/rechargeable razor will no
You will need to replace the battery pack. Depending on when your shaver was made, it may have one of two different battery types. You will ned to look inside to see which you need before ordering.
To open, remove the two round screw covers on the bottom of the shaver. Remove screws to remove bottom of shaver. The outer case will then slide off the bottom. Push the trimmer up to be abl to take the circuit board out. BE CAREFUL not to detach trimmer oryou will not likely get it back on yourself.
Your battery(s) will be one of the two types below found at shaveroutlet.com
http://shaveroutlet.com/replacement-battery-for-remington-df-ms2-some-braun-p-213.html
http://shaveroutlet.com/shaver-replacement-battery-aa-nimh-p-108.html
Be sure to read the Note on the second link concerning instalation
If you are unable to do this yourself, shaveroutlet.com can do the repair for you. See link below
http://shaveroutlet.com/professional-battery-replacement-for-most-models-p-374.html
Posted on Feb 06, 2010
How do I open my Braun 9585 Pulsesonic shaver to replace the battery??
Hello
Remove the electrical cord from the base of the shaver.
Press down and slide off the panel on the front of the shaver.
Remove the two nickel-plated batteries. Use these batteries as a guide to purchase new batteries at a hardware store or home repair store. Recycle the old batteries when finished. (Many hardware and home repair stores have battery-recycling stations.)
Put the new batteries inside the shaver and press gently to pop into place.
Place the front panel back on the shaver and plug the electrical cord into the bottom of the shaver. Connect to an electrical outlet to charge.
THANK YOU FOR VISITING FIXYA
Feb 03, 2011 | Braun Pulsonic Rechargeable Cordless Men's...
Where are the rechargeable batteries located and can any rechargeable battery work as a replacement?
The battery is inside the shaver body. You must remove the rubberized grip to access the screws to disassemble it. You can not use any rechargeable battery. The battery is lithiun ion. The correct battery is available at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/braun-liion-barrery-for-pulsonic-model-shavers-p-836.html
Jan 13, 2011 | Braun Pulsonic Rechargeable Cordless Men's...
I have a braun 5614 razor bought in usa many years ago and now needs new batteries.No one in zimbabwe can help, please tell me how to open razor and change batteries.
There are two round screw covers on the bottom. Pry these out to reveal two screws. Remove screws and then the out case can be slid downward and off. You can then access the batteries
Replacement batteries for model 5614 can be found at shaveroutlet.com. See link below
http://shaveroutlet.com/braun-battery-nimh-2-batteries-p-105.html
Sep 12, 2010 | Braun Health & Beauty
The razor will not hold a charge. How can the battery be replaced? How much does a replacement cost?
Thanks for using Fixya. You can buy battery for your braun shaver 5520 from this website. It will cost you around $40.
Have a nice day.
Rating the solution is highly appreciated.
Mar 10, 2010 | Braun Flex Integral Shaver 5520
I have a Braun 5525 rechargeable razor purchased in 1996. It no longer recharges, and in the charge window displays a jagged line rather than a battery image. Is this a problem with the internal cell, and...
In that case, the circuit board in also bad. This happens when the batteries aren't changed in a timely manner. You can buy a circuit board with batteries at shaveroutlet.com. See link below.
http://shaveroutlet.com/braun-printed-circuit-board-with-batteries-p-107.html
To open the shaver you will need to remove the two plastic screw covers on the bottom on either side of the port where the plug fits in. Then remove the screws underneath. The outer case will then slide off the bottom. You may need to reposition the travel lock to get it all the way of. Then unsnap the black plastic back of the inner case and remove it. You can then lift out the old circuit board. Reassemble in reverse order.
Feb 20, 2010 | Braun Health & Beauty
I need to replace batts in a Braun #5520...i donr
You will need to remove the two screw covers on the bottom of the shaver. They are on each side of the hole where the cord plugs in. Then remove the two screws to take off the bottom and you can then slide the outer case off the bottom also. You may need to change the position of the lock to get this outer case off.
You will then need to remove the black plastic back of the inner case. It snaps on so you will need to 'unsnap' it. You can then remove the circuit board for easier access to the batteries. Reassemble in reverse.
You can purchase batteries from shaveroutlet.com. See link below
be sure to read the installation note on the item page
Feb 09, 2010 | Braun Flex Integral Shaver 5520
My Braun 5564 electric/rechargeable razor will no longer hold charge. Suggestions please on repair or battery replacement?
Feb 05, 2010 | Braun Health & Beauty
How do I open the case to change the battery?
Gary
Apr 22, 2009 | Braun 4501 Electric Shaver
Braun 5520 Shaver Stopped Working
The "Braun 5520" doesn't have the 2 screws under 2 small caps on bottom, as described by so many on these boards.
The round plastic plug receptacle 'itself' is the release. (Twist-Release the outer ring.)
Look on the base, where you plug the AC cord in.... Just inside the rim, you will see two small 'recesses', opposite each other, that allow a wedge tool (like a large screw driver) to turn the rim counter-clockwise (left) 45 degrees, releasing the base and housing.
Once this is unlocked, slide the cover off and pop the black retainer cover off to reveal the "PC Board W/Batteries" module/assembly. (Batteries are NOT replaceable by themselves.)
There is a tiny (and I mean "tiny"!) resistor that burns out in the circuit board and causes the majority of power malfunctions in these models.
You can order a new PC Board (with batteries) for approx. $40.00. (+ S&H)
One place is: "http://www.electricshaverstore.com/get_item_5505631_braun-pc-board-w-batteries.htm".
(Fits Models: 5510, 5515, 5520, 6515, 6520, 6510, 6512 - Types: 5505, 5506, 5705, 5706)
Or, find other by Googling "Braun 5520 Circuit board assembly", and/or replace this model with your number.
Nov 03, 2007 | Braun Flex Integral Shaver 5520
Health & Beauty Logo
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Gary
Gary
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
