How to fit keyboard advent 7102 - Computers & Internet
2 Suggested Answers
SOURCE: Screen on laptop advent 7102 very dull can hard
Have you tried the FN key with F8.
Posted on Nov 07, 2011
Advent problems
the cable between keyboard and computer is lose or fitted in place.
May 05, 2014 | Advent Netbook
Keyboard backlight
Dear Jaine,
I did not find any replacement keys for your keyboard, but I located in ebay some replacement keyboards for around US$ 20 that may be an option. Please, have a look at:
http://www.ebay.com/bhp/advent-keyboard
Hope it helps!
Best regards,
Miguel L. Martins
Nov 03, 2013 | Advent Computers & Internet
Advent 7102 hear 2 short beeps, blank black screen when turn on
you have a AMI BIOS system and with AMI BIOS 2 beeps means there is a problem with the RAM if you have two cards remove one then try to power on if it still beeps twice swap the RAM and try again if it still beeps twice see if you can borrow a 200pin DDR-333 SODIMM RAM card from someone that is deffinatly working if it starts with that you need to replace the RAM cards
Oct 19, 2013 | Computers & Internet
How to replace the keybord on an advent 9517 laptop
Advent laptops are manufactured by DSG International, which owns the names to other name-brand computers such as Acer and Hewlett-Packard.
The Advent laptop keyboard has integrated mouse touch-pad functions that allow you to move the mouse around the screen with your fingers.
Function keys at the top of the board contain alternate ways to exit and enter software applications.
Function Keys
The Advent laptop keyboards function keys are "hot keys" that act as shortcuts to applications and functions on the computer. The function keys sometimes don't work and won't carry out the function assigned to the key. This problem is considered a hardware malfunction, and the solution is to replace the keyboard or use a universal serial bus (USB) keyboard for the laptop. b> Malfunctioning Keys b> Advent keyboards are made of thin plastic. Striking the keys too hard will cause the keys to break or stick awkwardly in the housing unit that supports the keyboard. When these keys get stuck in the housing unit, a pin tool can easily set the keys back on track. If there are too many keys that get stuck or broken, you can purchase a replacement Advent keyboard and have it installed. b> Mouse Problems b> The mouse is located at the bottom of the Advent keyboard but is connected to the keyboard data strip that sends information through the keyboard unit to move the mouse on the screen. If the mouse malfunctions, check the connector under the keyboard to see if it is loose. A loose connector can cause the mouse or other keys not to function on the laptop. b> Electrical Shortage b> An electrical shortage can cause an Advent keyboard not to work properly. A shortage is when the main board of the laptop is not getting the voltage needed to efficiently operate the computer. When this happens, certain devices underperform or become inoperable. Check to see if your power supply is extremely hot or if your system heats up around the keyboard. If so, replace the electrical adapter. b> Wire Damage From Keystrokes b> The wire that is responsible for the liquid crystal display (LCD) on the Advent laptop extends from under the middle of the keyboard to the LCD display unit. This wire is unprotected and can be damaged from striking the keys over the wire. When this happens, the display will not show the correct colors or the screen will go black. To eliminate this problem, purchase a keyboard cover that fits the keys to relieve the pressure between the keyboard and video cable. b> Keyboard Drivers b> Problems have been reported with upgrades from Windows Vista to Windows 7. Windows 7 will not recognize the system drivers that operate the Advent keyboard. To get the keyboard to work, you must load the old drivers in Windows 7 Safe mode, which is used anytime there is a hardware or software discrepancy. Advent keyboard drivers can be loaded from the original restore CD, which is included with the system at the time of purchase.
http://www.laptopkeyboard.com/Guides.php/Advent/Advent Series/9517 (Black)/KBAD3
Jan 29, 2013 | Computers & Internet
Advent 9215 keyboard malfunction
The laptop keyboard will need to be replaced, go to www.ebay.com Type: make and model of computer, refine search to keyboard.
May 20, 2012 | Advent Computers & Internet
Screen on laptop advent 7102 very dull can hard use it hardly any brightness
The LCD screen for the Advent 7102 does not produce light. It needs an additional light source.
A Backlight is the additional light source.
A Backlight is a CCFL.
Cold Cathode Fluorescent Lamp
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
An Inverter (Screen Inverter) converts electricity from the laptop, for the LCD screen, and the Backlight.
90 PERCENT OF THE TIME the fault is the Inverter.
The Inverter is a small circuit board located behind the Display Bezel, and under the LCD screen.
[ The Display Bezel is the thin plastic frame in front of the LCD screen. Resembles a picture frame ]
Example of a screen Inverter for an Advent 7102 Netbook PC,
http://www.laptoppowerjacks.co.uk/category-27/Acer12.html
Regards,
joecoolvette
Oct 17, 2011 | Advent Netbook
Require instructions on how to open keyboard and
ur RAM is down to laptop just open the screw &take out ur RAM by hand no problem.&change that
Feb 02, 2010 | Computers & Internet
Where can i buy keyboard surround for advent k200
Try Shopping for it at this following website:
http://www.keyboardweb.co.uk/companies/Advent.htm
or Google:
"Acer Advent k200 Replacement Keyboard"
That should do it for you.
make sure you use a walkthrough/diagram/faq to replace it or risk shorting out/ destroying the hardware.
Nov 30, 2009 | Acer Computers & Internet
Avent Laptop 1115C Replacement keyboard
I have the same problem replacements arent cheap though www.adventspares.co.uk £39 +vat apparently part number is 71GL51082-21 hope this helps
Jun 02, 2009 | Recoton Advent Advent Q2035A 20" TV
I need to replace the power pin in my advent 7102 laptop but can not get the laptop apart fully
Take it to a shop and ask for help, sometimes they give it for free if its just opening the thing.
Dec 17, 2008 | Computers & Internet
Computers & Internet Logo
76 people viewed this question
David Payne
David Payne
