Question about Drills
Replace belt I want to fit a new belt to my Draper D13/5B Pillar drill and need to find out belt size
Sourced the part no and stock number on the Draper site, then sourced the Manual on the Draper site too
Posted on Nov 18, 2009
How do I hook up a 15hp kohler engine to a 13hp lawnmover
will bolt holes physicaly fit ? if so then bolt to frame and i suggest using blade from new mower on old frame
Oct 15, 2014 | Kohler 15HP Replacement Engine SV470-3200...
Tire sizes for 87 ford econoline van?
What is came with when new
It is on the door pillar
Aug 17, 2014 | 1987 Ford Econoline
What is the size of the replacement chuck key for the Duracraft DP514?
The 1/2 inch is the max size drill that will fit into the chuck. There are only a few different key sizes, and sears sells them in their tool area. Easiest thing to do is find the size of the hole the chuck fits into by using the back end of a drill bit that fits the best. Measure that drill bit or take it with you to the store. You might find two different size keys with that size pilot hole, or maybe only one. Good luck!
Dec 27, 2012 | Drills
How do i fit reducing ring 16mm bore onto a30mm bore table saw blade, to use on a draper table saw
the reducer should fit right onto the shaft, if its the right size. Mic it to ensure. Then the blade should fit on no prob. I use a 30mm to 5/8" adapter on my own General 50-185 saw. Quality(sizing) of adapter is an issue.
Aug 02, 2012 | Saws
Draper drive belt
Yahoo.com or Ebay.com
Jun 05, 2012 | Draper Hand Tools
How to use?
It is used to check either the size of a drill bit or to see what size fastener you have and decide what size bit to use. Just insert a bit or fastener into a hole. It should fit snugly and if it doesn't fit the next smaller sized hole then you now know what size you have.
Feb 17, 2012 | Starrett Jobbers Drill Gage Gauge No. 187...
Need a chuck key for model 1140b,f powermatic drill press,manual part number 6285469.
There are only a few sizes of chuck key. Easiest thing to do is first find a drill bit that fits in the hole where the key goes to determine the size of the pin on the end of the key. (Use the back end of the drill bit.) Then take any other chuck key you have and see how closely it fits or doesn't fit - just as a reference. Take the reference chuck key and the drill bit with you to Sears or any place that sells a good assortment of tools. You will probably be able to determine the correct size key from what they have available very easily. Good luck, Al K
Mar 14, 2011 | Powermatic 1140 B,f 14 " Drill Press...
Automatic seat belt removal and replace with regular seat belts
You'd need to pickup the need parts at the junkyard. You'll need the "A" to "B" pillar trim, lower "B" pillar trim, front seat belts and seatbelt giude from a 1995 SC1 or SC2.
The treaded hole in the frame of the car where the track of the automatic seatbelt assembly attaches is in a slightly different place than the three point system. Its not a problem though. You just need to drill a 3/4" hole slightly above the existing hole in the trim panel. The existing hole is hidden by the seatbelt and not noticable at all.
Everything else pretty much bolts or snaps into place.
I've done this swap on several 1991-1994 Saturn S-Series.
Jan 08, 2009 | 1992 Saturn SC
Drills Logo
227 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
