Question about Rowenta DZ1700 Iron
My Rowenta DZ1700 Iron does not heat up anymore when plugged in. This happened after I had left it on long enough for the auto shutoff to kick in. Any suggestions?
  • 17 Answers
SOURCE: Doesn't heat up...
Authorized Appliance And Repair in St. Louis Mo, works on all model Rowenta Irons.
Posted on Nov 03, 2007
geokohler
  • 304 Answers
SOURCE: Rowenta iron manual needed
If you dropped it it will probably be an easy fix. Just openup the unit and look for a crack in the cicuit board. This is the case 99 percent of the time in apliance drops. If you find a crack in a board simply epoxy it and on the cicuit side of the board solder jumper wires from point a to point b when you follow the boken trace(s). If more than one trace is broken repeat the process until all the circuits can be repaired. Make sure you use wire of a high enough rating to handle the current the trace handles, and also use wire with heat resistant insulation in this application.
First things first though. Just open it up and have a look. The plug to the heating element may have just been knocked off. With a little trouble shooting skills and a good look you should be able to see your problem. If you get it open and see something I did not tell you how to fix just post any question you have and I will answer them for you.
George
Posted on Jul 24, 2008
SOURCE: Rowenta Effective Iron - Model DX1700-U1 NRB01-01
I just drop it a few times on the floor really hard a few times and then it gets hot again!!!
Posted on Sep 14, 2008
wizzard8955
  • 18 Answers
SOURCE: Rowenta DM880 Auto shutoff - Shuts off too frequently
This is a problem with a lot of Rowenta irons. It is the auto shut off that is not working properly and the only way to fix it is to have it disassembled and the switch hardwired to be on whenever the iron it plugged in. It is a thermal metal switch and it just stops working and then the iron will not turn on and the yellow light blinks.
Posted on Mar 06, 2009
omaromid
  • 332 Answers
SOURCE: I have a Rowenta DX1700. The iron will only stay
The problem is with the iron's thermostat which controls the temperature of the iron
Posted on Feb 07, 2010
Iron only stays hot enough to iron for about 2 minutes. The red light blinks except for that time.
I suggest contacting Rowenta; if you check here at FixYa, you'll find a spectrum of problems with what should be a simple, reliable device. Several instances of the iron not turning off at all until the plug is pulled from the wall, several others that fail to turn on at all. This once was a good company and it wouldn't surprise me to find that they are now made in . . . China.
Nov 12, 2009 | Rowenta DZ1700 Iron
Red light keeps blinking and iron shuts off
Sounds as if the cable may be damaged or a loose connection. May be cheaper to buy a new one from wallmart or similar store.
Jul 31, 2009 | Rowenta Effective DX1900 Iron with Auto...
When plugged in iron will not "turn on." If shaken it will sometimes turn on then shut off again. Appears to be an auto shut-off problem.
Could also be a break in the supply cable inside the cable guide
The cable moves during ironing and as the cable guide is fairly rigid , the inner cable gets stressed and snaps
Try waggling the cable instead of shaking the iron
Jul 06, 2009 | Rowenta DZ1700 Iron
IRON WILL NOT HEAT UP, LIGHT DOES NOT COME ON
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Jun 02, 2009 | Rowenta DZ1700 Iron
Jan 06, 2009 | Rowenta Professional Luxe DM880 Iron
My rowenta effective will not heat up.
Dec 15, 2008 | Rowenta DG5030 Iron
I have a Rowenta 1700 iron. The iron has started to act up. When I plug the iron in it just flashes & does not get hot. It is like it is in the stand by mode when you leave it on & don't iron...
Oct 14, 2008 | Rowenta DZ1700 Iron
Rowenta Iron problems
inside the iron is a thermal switch that has failed to make contact. Dissassemble the iron and you will see a small white ceramic pin sticking up out of the heating chamber and on tip there is a small contact. Above it is another contact that makes the heating element work. Easiest way to fix is to put a small bead of glue on the housing to force the contacts together.
Sep 02, 2008 | Rowenta DZ1700 Iron
George
Jul 24, 2008 | Rowenta DZ9080 Iron with Auto Shut-off
Brand new rowenta professional won't heat
The mostly problem in that case is the internal terminal from cord to iron is loose ,open it and fix the the terminal cord to iron,or go to the nearest shop to repair that.
Thanks & good day,
Edgz
Feb 12, 2008 | Rowenta DZ1700 Iron
Rowenta DZ1700 Iron Logo
120 people viewed this question
Top Rowenta Irons Experts
Joseph Hoffmann
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
