Question about Zerus Intel Desktop Board D815EEA (Z-D815EEA) Motherboard
What is the pin diagram for bcd to excess-3 code
Which ic is used in designing and implementing bcd to excess-3 code converter? what is its pin diagram?
Bcd to excess3 code converter pin connection diagram
Posted on Mar 03, 2010
Usb pin config
You need some expensive equipment to do this.
1. Electronically Erasibale Programmable Read Only Memory Programer 840 pounds minimum for a decent one.
2. Digitally Controlled Interfered Re-Work Station 3740 pounds
3. Computer Aided Design Software 1000 pounds +
4. Computer Aided Manufacture Software 1000 pounds +
5. Specialist Micro Electronics Tools 130 pounds
6. Specialist Digital Systems Tool Kit 322 pounds
You need to first remove 3 IC controllers from the motherboard using the Re-Work station, than insert them in to the EEPROM Programer and reprogram them using the software that cam with it. DO NOT touch these IC's as 1 spec of dust on a pin and they will never work again unless you have Concentrated Sulfuric Acid and Acetone which you you can mix for 12hours in a sealed high pressure chamber with argon (I doubt), or you could spend 4000 pounds sending the IC's off to be cleaned (not likely when you can buy them for 16 pound.
Sep 20, 2013 | ASUS P5S800-VM Motherboard
Tip
Magnavox TB100MW9 Digital TV Converter, Intermittent
After about 6 years of service, my Magnavox TB100MW9 Digital TV Converter
developed ann intermittent problem, where it would take several minutes to
come on and then the picture would come and go. I took the cover off and
found that by gently moving a vertically-mounted IC, I could reproduce the
problem. From other units of the same model that I have, this design was
only used for serial numbers 4000000 and up. The IC is mounted to a substrate
board that is then soldered into the main board. Inspection of the pins on
the main board that solder to the substrate showed that there were poor
solder joints with visible cracks, probably dating to the original
manufacture, and which took 6 years to oxidize and lose connection.
Resoldering these joints, using a miniature iron along with visual guidance
from a binocular microscope with variable zoom, solved the problem.
on Apr 27, 2015 | Magnavox TB100MW9
Tip
How to diagnose not having audio on the right channel of Yamaha YST-MS201
a ) Start with the input , then to the op-amp IC.
b ) check your cable like those above for continuity , ( VOM )
or use the signal tracer ( you can use any small amplifier with
speaker and point the tip of the probe on designated points
on the preamp section.
c ) then check also cable ( like one with the arrow pointed )
d ) from the cable it goes to the volume control
e ) the audio signal passes through these op-amp , see the diagram:
f ) Upon reaching pin 11 of IC TDA7370B via C444, the audio will be
further amplified and send the audio signals to your right speaker via the
cable above ( see the image ).
g) there might be a reason or a possibility that your Main Audio IC is good ,
under the following conditions:
1 ) the said IC is not overheating
2 ) the voltage on pin 14 is one-half of the supply
3 ) that there is audio input on pin 11
If it is, then
It could possibly from the capacitor ( C24 ) to the foil path going to your speaker.
Anyway you can check it with a signal tracer , only if you have one.
on Jan 30, 2010 | Audio Players & Recorders
Just replaced both ic's and now getting 3 red flashes tv worked before i changed
I would guess to say, that you replace two convergence ICs. When you soldered the pins, were you sure you did not use excess solder and shorted pins together? I would pull the board out and inspect your solders. I may be correct. Shorting pins to together may be the problem. This is one of those cases, if you did the repair, you could be on your own on this one. But, visit this site when you can and we will give you our best to repair your TV. Thanks for asking and show all hands of support!
Sep 13, 2011 | Panasonic PT-53WX53 53" Rear Projection...
How to create website?
You can create the WEBSITE using the steps Below:
1)You need to first register the Domain name
2)You need to host the Domain name(website)
3)You can do the Manual Codings
4)You final design the webpage and implement the content....
You can get the Website Domain name register,Hosting services,Website design tools and services at here
Tucktail and make Your website.........
Jul 18, 2011 | Computers & Internet
Tda9380ps /n3/3/1664 using in sharp tv power supply ok ,but no EHT ,the power LED are glowing red light press program key to change green light to return in few miniutes to ...
Tda9380ps /n3/3/1664 using in sharp tv power supply ok ,but no EHT ,the power LED are glowing red light press program key to change green light to return in few miniutes to standby in red light position ,please to help of rectivied this problem and send circuit diagram and IC pin configaration thanking you sir
Mar 03, 2011 | Televison & Video
Sony walkman NWZ-S754 Recharge is through computer - but can I recharge it via mains or in car.
Yes you can charge your player through main. All you need is a converter which connects to the usb cable to the plug. They are available in the market so you will need to look for it. Or you may find it at any electronic store.
Jan 20, 2011 | Sony Walkman Video NWZA818 MP3 Player
1 To develop a problem statement. 2. Develop an IEEE standard SRS document. Also develop risk management and project plan (Gantt chart). 3. Identify Use Cases and develop the Use Case model. 4....
Sorry, do your own homework. Do you realize the harm you could cause by getting an IT position after cheating your way through school?
Mar 15, 2017 | Cycling
Network diagram
you can feel free to call to this mobile number ill help u 09620077956.cuz we are the solution providers.
Feb 22, 2008 | Cisco ASA 5510 Firewall
Zerus Intel Desktop Board D815EEA (Z-D815EEA) Motherboard Logo
477 people viewed this question
Top Zerus Computers & Internet Experts
David Payne
David Payne
Are you a Zerus Computer and Internet Expert? Answer questions, earn points and help others
