Question about Bosch BRUTE TOUGH?? 18 Volt 1/2?¶ Drill / Driver
Jammed chuck - Bosch BRUTE TOUGH?? 18 Volt 1/2?¶ Drill / Driver
    Sergeant:
  • 281 Answers
You can use 6 inch pipe wrench on the top of the chuck and an eight inch on the large part of the chuck.Put a rag in the pipe wrench jaws.Lay the drill on a flat surface with the chuck pointed at you.The handles face the same way,small one on the bottom to lock the chuck and the 8 inch on top so they look like scissors. Depending on which way the chuck is jammed will determine if the handles are on the left or right side.Gloves and safety glasses will make holding the top wrench with a bit of force to lock every thing in place.Now just a tap on the end of the eight inch wrench will loosen the chuck.If the set up is wrong you will only jam the chuck more.
Posted on Feb 04, 2012
    Problem Solver:
  • 14 Answers
Wrap cloth or something around chuck to protect it a bit and using multi grips try to free up .if chuck is faulty youll need to get to left hand screw down inside the chuck to remove it. good luck some are very tight.
Posted on Nov 21, 2009
Cordless drill chuck problems jammed closed
Jam the chuck in a vice and the with help of w40 oil try to unscrew open
Dec 28, 2017 | Drills
How to unstick the chuck
Hi Gregory,You can use a 6 inch pipe wrench on the top of the chuck and an eight inch on the large part of the chuck.Put a rag in the pipe wrench jaws.Lay the drill on a flat surface with the chuck pointed at you.The handles face the same way,small one on the bottom to lock the chuck and the 8 inch on top so they look like scissors. Depending on which way the chuck is jammed will determine if the handles are on the left or right side.Gloves and safety glasses will make holding the top wrench with a bit of force to lock every thing in place.Now just a tap on the end of the eight inch wrench will loosen the chuck.If the set up is wrong you will only jam the chuck more. Thank you for choosing FixYa.
Jan 28, 2012 | Black & Decker Drills
How do I straighten a chuck bend off removing a jammed bit?
If this is a TE7 then the chuck will just pop off of the front end. You just pull the rear chuck sleeve foward to release the chuck. With the chuck off run the drill to see if the cylinder is bent. If you bent the cylinder it will wobble. If the cylinder is okay just order a new chuck. If the cylinder is bent then your best choice is to send it to Hilti and have it repaired by them. They have a ceiling on the amount the repair would be and you would get a warranty with the repair. It would be cheaper than you trying to buy the cylinder and replacing it yourself.
Hilti 1-800-879-8000
Glenn
Nov 11, 2011 | Hilti TE 7-C 120V Rotary Hammer Drill
Model # HJP001 Ryobi 12 volt cordless drill. Chuck is jammed, will not close. There is a screw down inside the chuck but it will not turn.
I just had the identical problem with my HJP001, and managed to solve it piecing together info from this thread. The cause for the chuck to jam was that the retaining screw had come loose and was interfering with the chuck. As others have pointed out, the retaining screw has a left-hand thread, ie reverse from most screws, which obviously needs to be taken into account. Simply tightening the screw solved my problem - together with some WD40 ;-)
Sep 05, 2011 | Ryobi Garden
The collet seems jammed and I cannot adjust...
This is just a longshot, but look down inside the chuck with a flashlight and see if your chuck-mounting screw has migrated out. I had the same problem with my Milwaukee, and turns out that's what it was. The collet was jamming up on the chuck screw.
May 02, 2011 | Black & Decker & Cordless Drill
Jammed chuck
Use a pipe wrench to turn the chuck open. J.
May 31, 2010 | Dewalt 18 Volt Compact Drill Kit
I have a broken drill bit stuck in a B&D BD154R chuck It is broken off low down so I can't get a pair of pliers on it. What can I do?
If it won't fall out with the chuck fully open, you'll have to remove the chuck. use an allen wrench larger than the jammed bit and lock it into the chuck. Hit the allen wrench with a soft hammer to loosen the chuck. Remove chuck completely and push the bit out from the bottom.
Mar 09, 2010 | Garden
How to take my chuck off broke tool off inside chuck
The screw that holds the chuck on, is in the bottom of the chuck itself. If there is something jammed in the chuck, it must be removed in another manor. If the chuck is jammed, I have used two pair of channellocks to open the it.
Oct 07, 2009 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Chuck has jammed
Try setting drill chuck on work bench and with a rubber or shot hammer, spin drill and tap tooth on chuck
Sep 07, 2009 | Drills
Cordless drill- chuck jammed.Model No. HP146F2B
b&d usualy thow away inthis range.still you can remove the chuck and fix or relace chuck unscrews anticlockwise hold shaft behind chuck with thin spanner or it may be the type with allen screw dwn the centre of chuck
Jul 25, 2009 | Black & Decker Pivot Plus Cordless...
Bosch  BRUTE TOUGH?? 18 Volt 1/2?¶ Drill / Driver Logo
215 people viewed this question
Top Bosch Drills Experts
Matt Olenzek
Matt Olenzek
woodzowl307
Are you a Bosch Drill Expert? Answer questions, earn points and help others
