Question about GE Spacemaker JVM1640SJ Microwave Oven
GE Profile Microwave Oven Model Number JVM1660WB005 not heating.
MicrowaveSvc
  • 9098 Answers
SOURCE: GE Profile Spacemaker® XL1800 Microwave Oven
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should be a very helpful "mini-manual" hidden inside the unit behind the control panel.
Please write back with more details if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Dec 04, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: GE Microwave/Convection JVM 1090 oven won't reach temperature
You probably have a bad thermistor.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
(At that site, that part is misspelled as "thermister" for your model).
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Accessing some components for testing will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
Posted on Jan 03, 2009
stonephoenix
  • 563 Answers
SOURCE: GE Profile Microwave will not heat
Unfortunately, there is no way to tell which part the microwave needs without opening it up for examination. There are a few parts that, if defective, would prevent the oven from heating.
  • a high voltage transformer which passes energy to the magnetron
  • a magnetron which converts high-voltage electric energy to microwave radiation
  • a magnetron control circuit (usually with a microcontroller)
This is NOT a repair that you would want to attempt yourself. The labor for the repair would cost a minimum of $50 and shouldn't exceed $100. You'll also have to pay for the necessary part if it's still available from the manufacture or their parts distributor.
Posted on Feb 04, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: My GE Profile Microwave/Convection Oven stopped working.
Chances are that the thermostat / thermal cutout / T.C.O. (whichever it uses) has opened.
This can happen when the magnetron overheats, either due to it's failing, or if the internal cooling fan is not working.
It may also that be the 15- or 20A ceramic line fuse or the oven cavity thermostat / thermal cutout / T.C.O. (whichever it uses) has opened.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
You should be able to get the fuse from a home center or local appliance parts store.
Accessing some components for testing and possible replacement will require you to remove the oven from the wall.
Posted on Jun 08, 2009
heatman101
  • 43501 Answers
SOURCE: GE Profile Sensor Microwave Oven model JE1660
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
yettu
Posted on Sep 30, 2010
GE profile JE2160SF03 microwave oven doesn't heat
3 things high heat low heat cencor or magnatron is bad
Apr 02, 2013 | Microwave Ovens
GE PROFILE MICROWAVE MODEL JEB1095SB002 Making
heatman101
Aug 05, 2011 | GE Profile Over-the-Range Microwave
I have a GE profile microwave convection oven Model Jeb1095WB It stopped heating up any suggetions
heatman101
Oct 25, 2010 | General Electric Microwave Oven
I have a GE Profile series microwave model #
the magnatron has blown they are very expensive to repair i suggest you buy a new microwave
]hope this helps
Jun 25, 2010 | General Electric Microwave Oven
My ge Profile microwave just stopped heating food/liquids. All else works on panel; just not heating. Why?
heatman101
45xs
May 12, 2010 | GE JE2160 Microwave Oven
GE Profile Performance Convection/Microwave Problem Heating
Either magnetron, capacitor, diode pack or transformer has failed causing a fuse to blow.
Jul 13, 2017 | General Electric Microwave Oven
MIcrowave doesn't heat up food
heatman101
fdyjhd
Jul 18, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE PRofile Microwave runs but no heat
This is a sure sign that the magnatron needs replaced ( This is what heats the food!) replace and all will be good again!
PLEASE rate my response to your question
Thank
You!
Jan 10, 2009 | GE JVM1870 Microwave Oven
Ge profile spacemaker over range microwave not heating
It was probably the Magnatron tube that went out , they are normally replaced only under warr. due to the cost to repair , the part is roughly 200.00 and labor ranges from 100-200. I guess it all depends on what it is worth to you , you can pick a decent brand new one up for about 200. Hope that helped you out. Phil
Dec 30, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
118 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
