Question about Seagate Barracuda 7200.10 ST380815AS 80 GB SATA Hard Drive
How do I format my Hard drive. Some of the Windows are missing
How do I format my Hard drive. Some of the Windows are missing I can restart my computer.
IL.COMRES.SIR, PLEASE TELL ME HOW TO ADD(INSTALL) THE MISSING FILES OF OPERATING SYSTEM (XP/SP2)TO RUN WINDOWS PROPERLY,WITHOUT FORMATTING CONCERN DRIVE.PLS PROVIDE THE PROPER PROCEDER. THANK YOU.
hi,
1. Some hardware malfunction also leds to show msg of missing or corrupt windows file. So, try to remove any new hardware fixed and give a restart.
or
2. Try to upgrade the XP through the XPinstallation CD. If it is not possible then Reboot the system by formating the C:\ drive.
or
3. A problem in hard disk could be the reason. Better change it.
enjoy.
Apr 26, 2011 | Computers & Internet
NTLDR is missing is displayed when i turn on the computer
The "NTLDR is missing", error displays very shortly after the computer is first started; after the Power On Self Test (POST) is complete. Windows XP might only initially load when the NTLDR error message appears. Causes of this error message include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors, an outdated BIOS, and damaged or loose IDE cables.
Get more help and information for Windows XP hope this helps you.
Mar 01, 2011 | Microsoft Windows XP Professional
I have boot mgr is missing could you help and tell me what i can do to get my pc working again thanks steve
Hello,there are a number of possible causes for "BOOTMGR is missing" error message.The most common reasons for BOOTMGR errors include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drives, an outdated BIOS, and damaged or loose cables.First we are going to try the start up repair.You will need your windows installation disk or recovery disk.Put it on your cd rom,restart and watch for a Press any key to boot from CD or DVD...Press a key to force the computer to boot from dvd.Once it finished loading files Choose the Language to install, Time and currency format, and Keyboard or input method that you'd like to use in Windows Vista.Click on the Repair your computer link on the bottom-left of the Install Windows window.This link will begin the Windows Vista System Recovery Options.Wait a minute to search for your hard drives.
Choose the Windows Vista installation that you'd like to perform the Startup Repair on.
Click the Next button.
The Startup Repair tool will now search for problems with important Windows Vista files and try to repair them.Your computer may or may not restart several times during this repair process. Do not boot from the Windows Vista DVD on any restart
Click the Finish button once you see the Restart your computer to complete the repairs window to restart your PC and start Windows Vista normally.
Now your done and is supposed to work normally.Let me know if is fixed.Good luck
Feb 05, 2010 | ASUS Computers & Internet
NTLDR is missing..how can i log-in to the windows?huhu..pls help
NTLDR is missing Press Ctrl+Alt+Del to Restart hmm..there's still no effect even if i press Ctrl+Alt+Delete..what should i do?
Aug 28, 2009 | ASUS Eee PC 1000H Laptop
Error message NTLDR missing on formatted hard drive
You need to either reinstall windows, or take the hard drive out, hook it up as a spare drive to a working computer and copy NTDLR to the root of the laptop hard drive. It would be much easier to reinstall windows. You can always use the recovery portion of Windows, but if I were you I would just do a format and reinstall. NTDLR is just a startup file for Windows XP, that does not mean your hard drive is gone or anything. Please don't forget to rate!..Thanks
Jul 14, 2009 | Compaq Evo D500 PC Desktop
How to reinstall windows xp if files are missing??
actually you can reinstall your xp system but this you can't, why:
the reason
your windows xp system are being updated every month...
the version from original system are being extracted to a new version....
by this time reformat you hard disk...
Jun 18, 2009 | Gateway 310 Series (158920) PC Desktop
BOOTMGR is missing Press Ctrl+Alt+Del to restart. Im trying to format an older computer with XP Pro. I physically took out the only hard drive in the computer and hooked it up externally to my laptop to...
The problem is caused by Formatting the HDD in Vista before moving back to the system.
Simplest fix, hook it back to the Vista system and delete the partition from the drive in disk management. Once that is done, then put the drive with no partition in the XP system and boot to the XP CD, create a new partition and install XP
Jan 29, 2009 | Computers & Internet
I reformated my hard drive and I cant load windows
1.Make sure the hard drive is installed correct and the bios found it.
2.In bios you have to put the cd/dvd as first boot and the hdd at second.
3.Load the original windows xp disk and restart saving changes in bios.
4.When prompt to pres any key do so.
5.Continue setup as new install. (if a miss one excuse as im thinking the step)
a.Enter continue
b.F8 I agree
c.d delete
d.enter sure
e.L delete
f. C create partition
g.Enter create
h.Enter Install
I.NTFS Quick Enter
Lets windows format copy some file and make a restart.
Keep windows setup all the way.
Install drivers and that it.
Let us know thanks.....Hope this help....
Sep 11, 2008 | Toshiba MK8025GAS 80 GB Hard Drive
Seagate Barracuda 7200.10 ST380815AS 80 GB SATA Hard Drive Logo
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
