Question about Frigidaire FDL45P1 Dehumidifier
Frigidare Dehumidifier will not turn off
When I plug the dehumidifier in it automatically turns on and runs. Even if I set it to the lowest level it runs. The bucket does not fill up. Also the coils show frost. Any suggestions?
  • Anonymous May 10, 2008
    I have the setting on max but the water is not condensing into the bucket until I turn the unit off. Ice is forming above the bucket when the unit is turned on.
  • steelerfan86 Jun 02, 2008
    I have same problem, unit is 2 years old. Runs, does not dehumidify as good as it did last year. Took covers off of unit, there was ice on bottom of radiator, above bucket, and on front right side of coils. Looks like it just ices up and does not dehumidify anymore????
  • 828 Answers
Pressure and temperature is directly related with refrigerants in the system. Ice building on part of the coils shows that the pressure inside the system is low and the system has lost some of its charge. Very low humidity with a low ambient temperature will also cause such a problem.
Posted on Jun 29, 2008
Why does nothing happen when it is plugged in and switch turned on?
Your dehumidifier may be set for automatic operation when a certain level of humidity is detected.
May 26, 2015 | Comfort-Aire BHD-301 Dehumidifier
Is there any way to run automatically. . . where when it reaches humid per cent it shuts off? Can you rig to run for x hrs. per day and then shut off and restart the next day?
Norman, once the unit reaches the extraction level you have it set for, the unit will turn OFF automatically. However, depending on the humidity level in your home, it may take several cycles of running and emptying the bucket until it reached. After that, it should turn OFF, once the level is reached. Then when the humidity level rises above the setting it's on, it will start up again.
Since your unit is a Manually Controlled unit, there's no safe way to "rig' it to run on with a timer. The plug in wall timers are not rated high enough to handle the load of the dehumidifiers operation. Trying to use one, would fry the timer and possibly the dehumidifier.
If you want all the features you mentioned, you will need to purchase a new electronically controlled dehumidifier.
Jul 05, 2011 | Amana D545M Dehumidifier
Unit will not run and the code 'LO' show up. What does the 'LO' code mean?
Hi, it simply means that the humidity level is lower then 35% the lowest setting on the dehumidifier...
It will not run when showing that...
Jun 09, 2011 | Haier 45-Pint Dehumidifier
We can hear the fan running and then the compressor, but little to not water produced; sometimes we can hear it click on and then off; the fan seems to be running a lot...
You may have the humidity level set to high. Usually anything above 50%, will show little results, unless your house is flooded.. Turn the humidity setting to the lowest level that your humidifier has
and give that a try.
The fan runs a lot, because it's designed to almost constantly move the air around. That way, if the humidity level rises above the setting on the dehumidifier, it can sense it and the compressor will turn ON.
Hope this helped you. Please let me know. Thanks.
May 17, 2011 | Amana D545M Dehumidifier
How do i check if its working correctly
If you want to give it the ultimate in-home test. Put the dehumidifier in the bathroom with the door closed and a hot shower running, but do not turn on the bathroom exhaust fan. Set the dehumidifier's controls as low as possible and let it run for 20 minutes. After 20 minutes, return to the bathroom, turn the shower OFF and check the water collection bucket for water. The unit will probably be running anyway, when you return to the bathroom.
Remember, the lower the setting, the more the unit will run and collect water. Until it either reaches the humidity level you have it set for or the bucket is full and the unit automatically turns OFF
That's the best way to test a dehumidifier at home. Hope it helps you.
Please let me know.
May 16, 2011 | Maytag M7DH45B2A Dehumidifier
We have some water in our basement. Yikes! So I set up my Kenmore. It has been running for 50 minutes and when I went down to check it, the reservoir is totally dry. Hmmmm... I think there's a...
Probably not a part missing, Judy. It's likely that you have the humidity level set to high on the unit. Remember, the setting that you put it on, is what the unit will maintain, not remove. So, try lowering the setting to the lowest level and that may solve the problem. Also, if you haven't cleaned the air intake filter, since your kids returned unit, that will help too. But, before you do any of the above, turn the Master ON/OFF Switch to OFF and unplug the unit from the wall outlet. Once you have completed the filter cleaning, plug the unit back in and turn the Master ON/OFF Switch to ON. Then set the humidity level to the unit's lowest setting.
All of the above, should solve the problem.
May 14, 2011 | Kenmore 54501 Dehumidifier
My dehumidifier compressor runs and then shuts off, then runs and shuts off, continuously. The fan continues to run. It seems to be pulling water, though it's hard to tell how much because I have a...
Part of the problem may be that you have the humidity level set to high. The fan runs constantly to move the air around. When the unit senses a humidity level higher than what you have it set for, the compressor turns ON. Once it's ON, if the humidity level is short lived, it turns OFF.
Try setting the humidity level to the lowest possible setting. Usually, that 45%. If the humidity level in you home is higher than that, the compressor should turn ON and run until either the bucket is full or the humidity level reaches 45%. If this doesn't solve the problem, turn the Master ON/OFF Switch to OFF and unplug the unit from the wall outlet for 12-15 minutes. Plug the unit bakc in, turn the Master ON/OFF Switch to ON and set the humidity level at it's lowest setting. Allow the unit to run until it cuts OFF and check the bucket for water. Hopefully that 12-15 minute time out allowed the unit to reset itself.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
May 11, 2011 | Maytag M3DH30B2A Dehumidifier
It runs it just doesn't collect any water. Not even a drip.
First, make sure the humidistat isn't set too high by adjusting it to the lowest humidity setting and running it again. Next, test the dehumidifier by placing it in a closed bathroom with a hot shower running. If you don't see water collecting in the unit after several minutes, turn the unit off and clean all dehumidifier filters and coils. If, after adjusting the settings and cleaning the unit, you still don't see water collecting, you may have a refrigeration issue. This situation will have to be addressed by a qualified technician.
Take care.
Aug 15, 2010 | Whirlpool AD25BBR Dehumidifier
Hampton Bay Dehumidifier Model# HB50
MY dehumidifier leaks water from upper part of unit causing water to leak on floor while running.
Feb 23, 2009 | Dehumidifiers
Dehumidifiers Logo
555 people viewed this question
Top Frigidaire Dehumidifiers Experts
Charles T Nevin
Charles T Nevin
Oloyede Monsuru
Are you a Frigidaire Dehumidifier Expert? Answer questions, earn points and help others
