The Ricoh 3310LE plain paper fac shows the follwing on the screen "time to change PCU". How is this problem corrected and how is this accomplished?
  • 555 Answers
"Time to change PCU" is not exactly a problem, it is just a requirement on modern laser printers and photocopiers. It's similar to "Hey, I need a new drum to keep making good-quality copies".
The solution is pretty simple as changing the toner: You need to go to the store, Buy a DRUM/PCU unit and replace it. Even simple easy-to-follow instructions comes with the new PCU.
You can buy it online, for example, from here: http://www.avantadirect.com/ric-411113-oem.html OR you can contact the manufacturer with the number indicated on the user manual. Office Depot, Office Max and others stores (like Best Buy) may also have it, just ask for a " PCU for a Ricoh Model 3310LE ".
Posted on Nov 17, 2009
Time to change the PCU
It is time to change the drum unit normally after 45 000 copies.If the copies are still alright,dont worry bout it,till the drum unit shows sighns of wear,like black dots and background.you can clear the message,but its a long process to do that.
Mar 04, 2011 | Ricoh 3310LE Copier
Ricoh 3310l fax shows error code 0390H in display. Anyone know what this means?
I've never seen a message like that with the 0390H code. There is no mention of that code in either the user manual or service manual. The closest thing is the sc390 code, which means either the toner density sensor or the developer has gone bad, and typically replacing the PCU can fix that problem.
If the new PCU doesn't fix the problem, you might want to try calling Ricoh for support, since their documentation doesn't mention that code.
Jun 11, 2010 | Ricoh 3310LE Plain Paper Laser Fax
Time chance pcu
here you will find the manual read to resolve this issue, thank you,
http://pdfdatabase.com/ricoh-3310le-manual-repair.html
it counts to vote, have a wonderful day
Mar 25, 2010 | Ricoh 3310Le Fax Machine, FAX3310Le...
Hi.when i m switch on the Ricoh 3310L Fax,the message is coming as shown below "time to change PCU"
Order a new PCU from Ricoh. Power off the machine and replace the pcu.
If you try and cheat it it will run for a short while and then lock-up breaking some gears. Cheeper just to order a pcu. Check Ebay, i see alot of Ricoh supplies there.
Jan 23, 2010 | Ricoh 3310Le Fax Machine, FAX3310Le...
Fax shows ''time to change PCU'' how can this be fixed?
you need to replace the Photo Conductor unit (drum unit).
Nov 17, 2009 | Ricoh 3310LE Plain Paper Laser Fax
Hi, we have a ricoh 3310Le fax machine that is amking a "knocking noise" anytime we recieve.
A knocking noise is typically a bad bearing, probably in the fuser. You can try lubricating the bearings (once the fuser has cooled down) and see if the noise goes away. If not, the bearings might need to be replaced in order to get rid of the noise.
Nov 10, 2009 | Ricoh 3310LE Plain Paper Laser Fax
Time to change PCU- Ricoh 3310L
Go to this page http://www.ricoh.com/ and find the official ricoh service department for your area
Nov 07, 2008 | Ricoh 3310Le Fax Machine, FAX3310Le...
PCU?
Hi the you will be able to purchase the PCU (Photo Conductor Unit) it is customer changeable so type in the following in google there you will be able to find a store that sells them.
Photoconductor unit for ricoh 3310
Thanks J
Jan 22, 2008 | Ricoh 3310Le Fax Machine, FAX3310Le...
jasbo
jasbo
