Question about Epson Expression 1640XL Flatbed Scanner
Epson 1640XL scanner with trans adaptor
Purchased used 1640xl Ist time in scanning a 8 x 10 trans, not working, the scans of photos are great.
  • 2,427 Answers
If your are scanning transperency, please place a sheet of white paper over it after you place it in the scanner :)
Posted on Jan 10, 2008
    Genius:
  • 1,067 Answers
Just use scan feture in high quilty mode when yuor doing 8x 11 instead of instant transfer alot these epsons have isses did u dl the latest driver from website for it also www.epson.com
  • nick helpap
    nick helpap Jan 10, 2008
    ya if your using transparent i thought u mentto say tranfer then yes wuse white paper behind it good one darklord
How to scan in pdf format?
In File Save Settings, you get a drop down box with the option to change the file format to PDF.
Jul 05, 2012 | Epson Expression 1640XL Flatbed Scanner
Red and yellow streaks appear in scans, always in the same location. The scanner was cleaned but the repair person could not find any problem with the equipment. Yet the streaks persist. How do I resolve...
execute a calibration to correct the wrong color:
  1. place your photo on the scanner, with a distance of 0.25 inch from the edge of the glass
  2. open Epson scan and select Professionnal Mode
  3. select the document source
  4. select the image type
  5. uncheck thumbnail then click Prevew
  6. crop the area of the image
  7. Click zoom to fine tune the area you see the streaks
  8. select the resolution of 72 dpi
  9. scan your photo
if the problem still not solved, you need to change the scanner unit , there are many dead pixels.
Dec 09, 2010 | Epson Expression 1640XL Pro Flatbed...
Verticle color lines on scanner bed and printout in photo mode
Hardware failure, nothing much can be done, just replace the scanner.
Aug 27, 2009 | Epson Expression 1640XL Graphic Arts...
Our Epson Scanners do not work from Photoshop CS4
Try using a separate scanner utility to do yr scans - not ideal but sorted my problem. I use the EPSOM scan utility with a Perfection 2400 scanner.
Apr 17, 2009 | Epson Expression 1640XL Pro Flatbed...
3170 Epson scanner. Never a problem before, but
Turned off scanner. Rebooted computer. Turned on scanner again. Works fine now.
Mar 22, 2009 | Epson Expression 1640XL Pro Flatbed...
Epson 3170 Photo scanner will not work
I don't know specifically what the solution is, but I just downloaded the user manual which has been missing and info from it might help. You might have the manual already, but here is a link to the manual (eighth item down), then go to page 62 and there are a lot of things to look at and consider. http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=14585
Dec 22, 2008 | Epson Expression 1640XL Flatbed Scanner
Funky look to images
Hi folks. I am the originator and have the solution to the problem. I feel a little stupid because I overlooked using a plastic insert/guide which is placed on the scanner, fitting on notches. It lets the scanner know to use the transparency device and provides a notch for film holder placement. It has been so long time since I used film ever since digital photography took over, I overlooked using this plastic insert. With it placed, I can scan film fine. Thanks
Sep 30, 2008 | Epson Expression 1640XL Flatbed Scanner
Epson 1640SU scanner, red line in all previews and scans
Most likely it is a spec of dust on the scanning sensor.  I recommend cleaning with a soft cloth and isopropyl alcohol.  More info here -  http://www.willshak.com/scanner/
Apr 29, 2008 | Epson Expression 1640XL Pro Flatbed...
Error message on Epson 1640 XL scanner
try to fix the usb cable or just replace it and reinstall the drive software disk. bye.
Sep 28, 2007 | Epson Expression 1640XL Pro Flatbed...
Epson Expression 1640XL Flatbed Scanner Logo
127 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
