Question about Palm Tungsten E Handheld
I own a Tungsten E and have a Dell XPS Vista 32-bit. I used to be able to HotSync and now I can't. How can I fix this.
  • tarek665 Nov 17, 2009
    OK, that seems to help, as it will now hotsync. Unfortunately there is only half the data on the calander, how do I get the device to sync with the palm? The desktop used to dominate but some of the items on my calendar are missing?
    First step worked great, followup questions posted.
  • 643 Answers
Welcome to Fixya, thank you for asking your question here. Sometimes the software gets bugged and needs to be reinstalled. Please go here. http://palmone.r3h.net/downloads.palm.com/PalmDesktopWin62.exe Download the newest version of the palm desktop with hot sync, and then install it. After installing it, restart the computer and then try again to sync it. If that doesnt work, please go through the automated troubleshooter listed here. http://kb.palm.com/wps/portal/kb/common/article/2630_en.html It runs through all the scenarios that may be blocking you device from syncing. The most optimal choices are reinstalling the software as i suggested already from the link i gave, and then performing a soft reset on your Tungsten E. I hope this helps out, and please don't forget to rate my solution. If you have any additional question's feel free to ask!
Posted on Nov 17, 2009
  • Tre Elkins Nov 17, 2009
    Ok great, it if will now hotsync. Then you need to try and resync it with the newer information..
    If it seems like it wont overwrite the information on the palm, then sometimes the best thing to do is to save all your contacts and settings to desktop first..
    And then perform a soft reset on the palm ( which basically wipes out all the information stored on it , which is why we saved all the settings to the PC desktop first for backup)
    Then after doing so, shut the device off, then on.. And then try to sync it with your outlook calendar again, now that it has no info stored, it should take the info form your desktop ..
    Then afterwards restore the information you saved earlier back to the tungsten.
    let me know if the reset of the tungsten works for you.
Unable to connect hotsync with desktop
Palm 515 Hotsync unable to connect to Desktop - Expansys ...
www.expansys-usa.com > Forums > Palm > Palm m515
Jun 29, 2004 - 6 posts - ‎5 authors
I get the messsage "The connection between your handheld computer and thedesktop could not be established. Please check your setup and ...
Setting Up Palm OS Hot syncing with Windows 7 or Vista 64bit
www.turbostats.com/support/hotsync.html
Download Palm Desktop 6.2; Install Aceeca 64 Bit driver; Install ... Product Support; If you have Windows 7, 8 or 10 32-bit you should be able to Hotsync now.
unable to connect to computer to hotsync via network or cable
forum.brighthand.com > ... > Device Manufacturers > Palm > Palm TX
Jul 30, 2008 - 10 posts - ‎6 authors
i haven't been able to hotsync since i sent my laptop in for 'repair' a while ago. ... Make sure you do NOT connect the TX to the computer (even ... Cannot hotsync Palm lllxe with USB to Serial Adaptor ...
Jan 24, 2011
Hotsync problem - unable to establish desktop ...
1 post
Oct 19, 2004
Unable to Hotsync - Identifying user? ' Brighthand.com ...
Mar 16, 2004
Unable to Hotsync Palm IIIxe with a USB connection ...
Dec 18, 2002
More results from forum.brighthand.com
Jan 03, 2016 | Palm Tungsten Tx Handheld Pda 312mhz 128mb...
Import photos from zire 71 to windows vista 32 bit
Check and see if you can download a "mediaimpressions" driver. I have found it is great for downloading photos from any device. GOOD LUCK
Jul 02, 2012 | Palm Zire 71 Handheld
I have window Vista Home Premium\ Palm Tungsten E2
google your palm's model for vista and their should be a download for it if not, then it is not compatible for Vista
Feb 23, 2010 | Microsoft Windows Vista Home Premium...
Dell XPS One, Vista, Seagate Hard Drive failing?
go to pcpitstop.com and run full test. But it sounds like spyware to me.
Sep 15, 2009 | Dell XPS One Red Desktop Computer
Dell Dimension XPS PC Desktop won't boot
Vista is available in 32 and 64 bit os.
if your system ran xp which was most likely 32 bit. And you have installed a 64 bit version os.
this will be your problem, also Vista requires more system RAM/Memory to run it.
If you get 1 beep at startup, it states the system is ok.
Alternatives are device drivers incompatability.
Check M$ website, regarding vistas minimum system requirements.
Mike @ Compurepair.
Jun 11, 2009 | Dell Dimension XPS PC Desktop
During hotsync, data wont transfer from Computer to palm
Older palm products and vista aren't compatible. You either needs to transfer info via bluetooth or upgrade your palm if you wish to continue using vista.
Mar 31, 2009 | Palm Tungsten E2 Handheld
Dell Inspirion 1521 Laptop Microphone Wont Work
checklist:
1. sound driver 2. microphone settings in volume control applet 3. tap test (tap the area around the microphone and see if eg Sound Recorder picks it up) 4. external microphone
If you get to step 4 before you get anything then your problem is one of missing or damaged microphone.
Dec 15, 2008 | Dell Inspiron 1521 Notebook
64 bit?
I run Vista 64 bit with no issues at all. 64 bit is the future of the computer world. If software is made to utilize 64 bit operating systems the speed is quite remarkable. 64 bit Vista is still backward compatible with 32 bit so virtually all programs except for the oldest legacy stuff. Also 64 bit allows you to surpass 32 bit's 3 gigabyte memory barrier. Vista 64 can use up to 128 gigabytes. It may not seem important now ,but at the rate computers evolve it will.
Nov 28, 2008 | Computers & Internet
Palm Tungsten E Handheld Logo
Top Palm Computers & Internet Experts
Michael Vincent Cruz
Raj Patel
Andrew Taylor
Andrew Taylor
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
