Question about Gateway 7322GZ Notebook
GATEWAY 7322 I have this laptop for about one year, one day It got frozen while I was working. I tried to close the application by pressing ctrl+alt+delete. It didn't work then I took the ac power off and took the battery off. when I tried rebooting it. I got some weird messages. I ran the discovering CDs. Discovering CD ran thru fine however once it get to the point where operating system supposed to be downloading. it get frozen. I thought it was hard drive. I bought new hard drive and installed it but did not worked. do you think it the mother board need to be  replaced as well. Thanks
  • JANSAYPIYARA Jan 11, 2008
    I taped the process of my laptop whats happening, when is suppose to downloan operating system, it gets frozen. I show you by moving the pointer back and forth and It got stuck at one point. screen doesnot move any where after that.
    Genius:
  • 1,226 Answers
If you replace the HDD, there is no reason why system hung up. try cleaning your memory cause on that case i can pinpoint that memory something wrong. try cleaning memory fixed it again, if your don't mind maybe you need to replace the memory.
if the same happen, try examine CD Disc or your cd rom drive cannot read the files on the disc.
(Option solution)Examine your motherboard after clear prove that the above solution is not working. i can assure u that main board is good. if ever it was damage that causes overheating.
Posted on Jan 10, 2008
  • Anonymous Jan 22, 2008
    did you try another any bootable windows disc maybe it help , Provide another windows bootable disk installation disc , format and install the new windows operating ssytem.
    do not use the operating system recovery disk maybe it was damage.
6ya staff
SOURCE:
Reset button acer laptop
Laptops do not have reset buttons ! If your laptop is frozen and won't respond hold down the power button for about 20 seconds and force it to shut down. Only do this if you have no other alternative as it is not good for the hard drive of the laptop. Try the three finger salute first CTRL- ALT - DEL and select task manager if windows system and see if any processes or applications have frozen and close them then select shutdown from the task manager if it is not frozen up.
Jun 23, 2014 | Computers & Internet
Gateway 7322 Notebook. Can't get the battery only
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Sep 09, 2012 | Computers & Internet
Logging Off
how long have you waited for it to log off? sometimes it's performing background operations i.e. updates or trying to close a program. hit the windows key and the r key at the same time and type eventvwr and press enter. look at your system events and application events and make sure that it's not having a problem closing a program. this could be what's causing the laptop to hang @ turn off.
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Jul 18, 2012 | Compaq Computers & Internet
Gateway laptop cursor is frozen on the screen
THANK YOU RYLEE SMITH FOR HELPING ME REPAIR THE FROZEN ARROW ON MY COMPUTER ISSUE!!!!!!!!!! YOU ARE A BLESSING FROM GOD!!!!!!!!!!!!!!!!!!!! THANK YOU TREMENDOUSLY!!!!!! I SINCERELY APPRECIATE YOU!!!!! FB.COM/DISTINGUISHEDHUMAN SEND ME REQUEST SO I CAN BESTOW MY COLOSSAL GRATITUDE!!!!!!!!! "ROYAL" ~~~****CLEMENTINA****~~~~
Mar 04, 2012 | Gateway Computers & Internet
I need to do a System Restore on a Gateway 7322 Laptop
try running this virus FREE prog No cost- removes too...: http://www.f-secure.com/en_EMEA/security/tools/online-scanner/
Jun 29, 2010 | Gateway 7322GZ Notebook
I have a Gateway 7322 laptop. I'm trying to hook
Press the Fn key down, hold it down, then press the F2 key.
Here is the download page for the Gateway Notebook User Guide,
http://support.gateway.com/s/Mobile/Gateway/7305GZ/4429ul.shtml
Aug 05, 2009 | Dell Inspiron 1525 Laptop
Gateway inverter board replacment
The inverter board is the circuit board inside the screen, with all the capacitators etc that controls the backlight. It looks like this:
http://cgi.ebay.com/GateWay-7322-7330-7340-7410-Inverter-83-120082-3000_W0QQitemZ290289050786QQcmdZViewItemQQimsxZ20090114?IMSfp=TL090114125004r29293
You can just google 'changing inverter board gateway' and see if you can find the closest guide to your model..
I found this one 4th on the list..
http://www.pcgeekdom.com/2006/02/replacing-laptops-lcd-backlight.html
Hope this helps
Chris (ziraffa)
Jan 17, 2009 | Gateway 7322GZ Notebook
Gateway laptop hang issue
Check the Windows Page File to determine whether it's system managed or manually set. The recommended settings is twice the amount of RAM installed in the machine. If set too low the system will hang often, especially when running memory hungry apps.
I would also suggest checking screensaver and power management options in the control panel.
If those don't work, close any unused applications which run at startup (Start, Run, MSCONFIG). Another possible solution could be updating your display driver.
Nov 06, 2008 | Gateway Computers & Internet
Gateway 7322GZ Notebook Logo
292 people viewed this question
Top Gateway Computers & Internet Experts
Ekse
Prashant M
Prashant M
Thomas F. Schneider
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
