Question about Goodman GDS80904BNA Open Flame Heater
Open rollout - Goodman GDS80904BNA Open Flame Heater
  • 1 more comment
  • djrickes420 Nov 17, 2009
    yes just replaced the ingniter and still show me an open rollout can u assist me i would really appreciate it thanks
    flashes #6
  • Robert Horton
    Robert Horton May 11, 2010
    Can you give me more information? Are you saying you have a heater down due to an open roll out switch?
    Scholar:
  • 79 Answers
If your roll out is open it is due to it over heating. Your burners when they are lit are rolling back and opened your roll out. You need to check your exhaust venting to see if is clear(no restrictions). Also, your heat exchanger could be cracked enough that when your indoor fan comes on it puts enough positive pressure on your exhaust that it won't exhaust correctly. One way to check for a cracked heat exchanger is to watch the burner flames when they are lit and see if they move(flutter) or come back toward you when the blower fan starts to operate.I hope I was able to help you!!
Posted on Nov 18, 2009
    President:
  • 1,515 Answers
Hi, I just wanted you to know if you are still having a flame roll out condition, yes the other tech was right by checking for a cracked heat exchanger, or obstruction in the flue. I have seen and found birds nests in the flue on the roof. Also, rusted up burners, plugged burners will cause this. If you have a roll out error, this tells me this furnace is a newer model? The switch will be located at either side near the burners and can be reset after this condition is found. If all appears good, I have seen a gust of wind come through and open the contacts on this roll-out switch. Just food for thought.
Sincerely, Shastalaker7
Posted on Dec 17, 2009
How can i fix a model raypak 406A natural gas pool heater with a rollout switch open indicated?
replace but find out why either inproper gas supply which will soot up and overheat and burn that part or if gas is ok then see if wind caused it to roll out then add a wind stack
Aug 17, 2014 | Raypak 406A Digital ASME Natural Gas IID...
Why condenser won't start board flashes6times meaning open rollout
check your roll out with an ohm meter they should have continuity if not they have a reset button on top of the switch push it and this will reset them. If they don't have continuity they are open.
Jul 17, 2014 | Goodman Manufacturing Goodman DSXC180601...
Rollout switch is open?
You possibly have a Flaming out problem. Your "One" time rollout sensor needs to be replaced, then the reason for the rollout needs to be identified! Very Important! Get a qualified heater service center out to diagnose this problem. Don't just replace the rollout sensor. Sometimes these are called Fusible Link.
Oct 06, 2013 | Rheem 266K to 399K BTU Swimming Pool...
We r in our NEW house built in 2008. HVAC unit looks clean, & New. our A/C do not work, or kick on. the unit is Goodman during troubleshoot found-open rollout ->6 flashes gmh80704bn -...
If you didn't reset the rollout switch, the air will not work. The rollout switches are in the furnace burner secton. Look at the burners, the rollout switch(es) are just above the burner. They will have a button on top to push for reset. These rollout switches will generally have two wires going to them.
May 18, 2011 | Heating & Cooling
My furnace turns off and I am getting an alarm OPEN ROLLOUT. I reset it and work for 6 hrs, 3 hrs and last time worked 2 days straight.What could be the problem
Hello, a rollout switch opens for several reason, a damaged heat exchanger,lack of combustion air, impoper gas input. I would have a technician come out and check these three things.
Feb 26, 2011 | Goodman GMS90703BXA Heater
Rollout switch continues to trip
If you have a cracked heat exchanger this will cause the flames to rollout and trip this switch. Its meant to stop the furnace from running and putting carbon monoxide in your home. Watch the furnace as it tries to light if when the gas valve opens and flame is established it should go into the tubes heat the heat exchanger and then your main blower motor will come on. When your main blower comes on is usually when you see the flames rollout and trip that switch. If this happens you can either buy a heat exchanger or new furnace if its a older unit Obama still has that awesome tax credit til 12-31-2010.
Dec 13, 2010 | Goodman Heating & Cooling
Coleman home heater stops working fault code "limit switch open"
How do you test a pressure switch and other limit controls?
This is for people who are experienced with electrical equipment and the use of a Volt Ohm meter. *Please never by pass a pressure switch or limit control. The pressure switch and limit switches are there for your safety. You would test by setting your volt meter to "Volts AC" and test the rollout switch by placing one meter probe on one terminal of the rollout switch and your other meter probe to a good ground. Have the red probe touching the top terminal of the rollout switch and the black probe touching a ground (body) of the furnace. You should be getting 25.85 volts which means the rollout is good on the top terminal. I would next test the bottom terminal of the rollout by touching the red meter probe to the bottom terminal on the rollout switch and the black terminal to ground. If I get 25.85 volts on the bottom terminal the rollout is good. If I do not get any voltage on the bottom terminal then the rollout has tripped and can be reset (if equipped) by pressing in on the little button or replaced. If your rollout switch is tripped you probably have a stopped up heat exchanger or a leaking heat exchanger. I would recommend calling in a service technician to find out why the rollout switch tripped. If you have an open limit control either the furnace has over heated or the limit has gone bad. Problems that would make a limit open up would be dirty filters, dirty evaporator coil causing a restriction in the air flow or a slow blower motor (check the capacitor on the blower motor to make sure it is good). A weak blower motor capacitor will cause the blower to run slow and eventually fail. Pressure switches, and limit switches can be tested with a meter in the same manner. With the furnace calling for heat you can test each of the terminals on the pressure switch to ground to make sure the pressure switch is closed. You should be getting between 24 to 28 volts from each terminal to ground if the pressure switch is closed. If the pressure switch is open you either have a stopped up vent, drain line (if you have a condensing furnace) or bad pressure switch.
Nov 27, 2010 | Coleman Heating & Cooling
Open rollout switch cuicuit
Have you checked the flame rollout switches? Some have to be reset manually. You would also find out why they are tripped.
Oct 05, 2010 | Heating & Cooling
Carrier 48GP rollout switch code
You need to find the rollout switch and see if it has a manual reset button on it or not. There are 3 styles of rollout controls. One is a disc type that mounts behind the burner ends, there may be more that one,possibly one on each side of the burner tray. This style rollout is usually manual resetting. It most likely will be black or silver in color and usually is about the size of a penny in diameter and about 1/2" in thickness with 2 wires going into it and a red push type button in the middle. The next style is similar two the first as it is manual resetting also, but this rollout uses a small copper capillary tube that runs just behind the burner ends and is mounted to the burner tray. If you follow this tube it will lead you to the manual reset button which is most likely mounted below the burner tray. The last style rollout is what they call a fuseable link, this is mounted behind a burner end and looks like a resister used in electronics, it is about 3/4" long and about 3/16" in length and is silver in color. It is mounted in a porcelain mount. This style is not resettable it has to be replaced with one of the same temperature rating. You would need to go to a Carrier/Bryant dealer to get the right one. Either take it with you or bring the model and serial number of your furnace.
The most important thing about rollouts is that there is a reason it opened up(went faulty). The reason they trip or open up is due to the burner flames are rolling back out of the burner box and getting the rollouts hot enough to trip or open up. This is telling you there is a serious issue with your furnace that needs to be found and repaired. There are a couple of things that is causing this. They are that your exhaust is not venting properly. Your exhaust venting could be restricted with whatever. You need to pull your venting off and look for restrictions all the way from your heater to the end of the chimney. The next thing it could be is that your heat exchanger is cracked enough to allow positve air pressure on the exhaust system when the indoor blower fan is running. You can check this out yourself by watching the burner flames when the indoor fan comes on. If the heat exchanger is cracked enough the burner flames will flutter or move back toward you when the indoor fan comes on causing the rollout to trip or open up. Most manufacturers have a 20 year warranty on the heat exchanger(parts only,you pay the labor cost). Depending on the age and condition of your furnace it may not pay to have the heat exchanger replaced.
I hope I was able to steer you in the right direction!! Good luck!!
Nov 28, 2009 | Heating & Cooling
Heating & Cooling Logo
1,154 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
