Question about Maytag Neptune MDE5500AY Electric Dryer
Is there a reset code for maytage neptune MD55?
Dryher was working fine today and all of the sudeen Start button is blinking and none of the electronic controls respond to anything. I've tried unplugging for a while to no avail. Completely unresponsive. Can anyone help!
Posted on Aug 16, 2010
  • 725 Answers
There is not a reset button but you have a control board that controls all the commands and functions on this model.
You can contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service from 7 AM until 9 PM CST and we can overnight the correct parts to you after we know what your dryer is not doing right.
We hope to get you drying clothes ASAP.
Thanks, Ella
Posted on Nov 17, 2009
4 Suggested Answers
  • 32 Answers
SOURCE: My maytag neptune dryer will
Try this (you may need two people):
1. Open the dryer door and locate the door switch. While pushing the door switch in, have someone else push the start button.
2. You'll hear the noise. Keep pushing both buttons and take your other hand, reach in side and grab one of the drum fins and manually push the drum in a clockwise direction.
3. The drum may take off on its own. BE CAREFUL TO REMOVE TO HAND QUICKLY TO NOT GET BUMPED BY THE FINS AS THEY BEGING TO ROTATE.
If it does not start, the motor needs to be replaced. If it is still under full warranty, simply call a repairman.
If this works, turn the dryer off, close the door and try to start it again just by pushing the start button. If it works, it may have been something obstructing the drum from turning. OR, the motor could be going out. It may continue to start on its own for an unkown period of time, a day, a week, and year. But eventually it will go out and will need replaced.
Replacing the motor is a bit involved, but if you want to attempt it I can walk you through it.
There should be a 5 YEARS warranty on the motor, so you might consider a repairman. Make sure they are Amana certified and there will be no cost to you for the motor. The labor, however, may be up to you and could be expensive.
I'm willing to assist you on whatever you decide.
Best, G
Posted on Aug 03, 2010
ROMOAS
  • 97 Answers
SOURCE: have a maytag neptune dryer md55 cannot get a
use some ceader shake shingles ther tapered and the bugs hate it and it smells good this will shim the unit and break off what you don't need. hope this helps
Posted on Aug 30, 2010
richroth
  • 9472 Answers
SOURCE: I have a 6 year
Did you also clean all the internal vent duct work inside the machine? You will get lint buildup on the thermostats that act as a blanket and will cut the heat prematurely causing the unit to run at a cooler temperature. What is the model number that is listed on the dryer? Look in the dryer door for the number.
Richard Roth
The FixYa Team
Posted on Aug 06, 2011
How to reset pf code on maytag neptune washer
codes can be reset by simply unpluging it for 5 min. how ever neptunes are what put maytag out of bus. with mo. # i can get more info and tell you what that code means
Sep 15, 2016 | Maytag Washing Machines
Why is my Maytag Neptune Elec Dryer MD55 chirping? How can I fix it?
Could be a bad spot on the drive belt. Each time it moves over the motor pulley it slips. If the chirp is happening at the same interval over and over I would check the belt.
Mar 28, 2015 | Maytag Dryers
Md55
Are you getting any heat at all in the unit?
Apr 28, 2012 | Maytag Neptune MDE5500AY Electric Dryer
Neptune mah8700aww has a e3 code
The Neptune can sometimes be reset. God knows the repairman for Maytag really needs to get back to work, yet to reset the cpu on your washer/dryer just unplug the unit for 60 seconds. I hope this helps you out.
Oct 05, 2011 | Maytag Neptune MAH5500B Front Load Washer
Need to reset the program of our maytage neptune TL ver: FAV6800AWQ
""need to reset the program of our maytage neptune TL ver: FAV6800AWQ ""
The only hard reset to the Control Board is to unplug your FAV6800A from the 120VAC service outlet then reconnect.
I feel this will not clear your machine issue. What do you mean by reset the program of our maytage neptune TL?
Apr 24, 2011 | Maytag Neptune FAV6800AW Top Load Washer
WHERE CAN I FIND PEDESTALS FOR MAYTAG NEPTUNE WASHER AND DRYER MODELS MD55 AND MAH-1 MODELS?
Don't...Unless you have a concrete floor you will never be satisfied with the pedestal. Your front loader will shake a lot more. People buy these things then I go to there house with a "shaking" problem and then they get mad at me because I tell them it's because of the pedestal. Front loaders were designed on concrete floors so they're only going to work like they say on concrete floors. Do a little research before you make that decision please. Not to mention they're about 200 dollars or more. Just a heads up I don't mean to bring ya down.
Apr 02, 2011 | Washing Machines
Have a maytag neptune dryer md55 cannot get a small enough tool to adjust legs to help balance. any suggestions
Aug 30, 2010 | Maytag Neptune MDE5500AY Electric Dryer
I have a Maytag MD55 dryter and one of the paddles
You remove the door screws with the triangular plastic plates and screws for the door on the opposite side. pull front forward and down. Remove the two bolts at top corners to raise top (unplug machine of course). screws are on outside of drum. When reassembling, make sure that the right screws go with the right area (The wider screws go in the triangular plates and the thinner go in the door) Make sure the door hinges are put in their grooves before reinserting the front.
May 14, 2010 | Dryers
Neptune MD55 elec dryer chirping noise
I would think it might be the "board" but I once went on a call for the same chirp on an oven...ended up being the smoke detector was low on battery..it cost them $$ for me to find that simple thing.
Oct 24, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
603 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
