Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Hi I have a Sears, Kenmore refrigerator model #106.53382. The freezer has stopped freezing. Everything is defrosted. The lights all work, I hear sound. What could it be?
  • Anonymous Mar 30, 2014
    Hi I have a kenmore refrigerator everything don't work except the lights how do I fix this problem
  • 725 Answers
This is your defrost system that has gone out on this model. When this system goes out, everything thaws out because the defrost system has failed.
This is an easy repair if you want to attempt it yourself and you can save a lot of $$$$ by doing it on your own.
Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service from 7 AM until 9 PM CST and we will provide part removal/installation instructions for you when you get your parts through us.
We want to get you cooling and freezing again soon and we ship overnight for our customers.
Thanks, Ella
Posted on Nov 17, 2009
Kenmore sidebyside 53552200 stoped cooling and defrosted completly light still works both frezer and refrigerator not getting cold
It could be stuck in defrost. Check your defrost heater, and see, if it is still hot. If it is, then the defrost timer is stuck. When it goes into defrost, everything, stops working, but the defrost heater and light. As long, as the defrost timer is on, nothing else will work, as far as the compressor, freezer fan, and any cooling/freezing.
Sep 07, 2014 | Kenmore Refrigerators
Lg refrigerator leaking and freezer issue
Honestly, most people are not experienced on LG to know all the symptom and their solution. I guess you will have to wait for it to break again to have it fixed.
Oct 25, 2013 | Refrigerators
Kenmore refrigerator(model 10653606202) freezer is cooling, can hear the circulation fan' noise, also see defrosted water in the bottom collection pan. but the refrege is not cooling.
If the freezers is freezing everything and you can hear the circulation fan, maybe it is a defrost problem. Sometime ice will build up behind the rear panel in the freezer section that blocks either the chilling tubes to the refrigerator section.
You will need to remove the food from the freezer, then remove the shelves and inside back panel of the freezer. If you see a lot of ice, that is probably your problem. DON'T use water to defrost, either unplug and let it set with the door open or hurry it up with a hair dryer.
It also means your defrost assembly has stopped working and will need replaced, but the unit will work without it for several weeks before the ice build up redevelops.
Jun 07, 2011 | Refrigerators
Freezer isn't freezing. Everything is defrosting. 1998 Kenmore Side by Side Ice/Water Dispenser Model 57058751
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 14, 2011 | Kenmore Refrigerators
Freezer works, Fridge doesn't
The defrost timer inside the fresh food compartment is most likely the problem. Need to turn the timer slowly clockwise until compressor stops. I should remain off for about 25 minutes. During that time the freezer should be in defrost. You may be able to open the freezer door and hear the crackling and sizzle of the defrost taking place. If the timer does not restart the refrigerator after 25 minutes the turn the timer clockwise again until the compressor restarts. Number 6 in photo below is the defrost timer. The replacement timer part number is 482493. Here is a photo. Thanks Sea Breeze
http://servicepartstec.blogspot.com/
Aug 19, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Freezer coils completely frost (freeze) up--refridgerator warms
Sounds like the defrost timer or something in the defrost circuit. Sears has a complete model number system that is confusing I know. Sears made it that way. Not sure why but look around the cold food door while open and look near bottom on the frame just above the kick plate. The number looks like this, (model No. 253.64802400 for example) Find that number and we can go from there, Thanks, Sea Breeze
Jun 11, 2009 | Kenmore Refrigerators
Stopped cooling and freezing
check that the condenser fan is working and condenser is clean.. check that the evaporator fan is working may have to push switch in to make it run. if ice is visible behind rear freezerwall you do have a defrost problem find defrost timer and with a flat head screwdriver turn it until you hear a click and everthing shuts down. if yoou hear ice cracking you have a bad defrost timer(very common failure)you may have problem in the defrost heater but you might find that a little over your head and a repairman might be the cheapest way to go, because buying parts can be expensive and they are not returnable
Jan 19, 2009 | Kenmore 53642 / 53644 Side by Side...
Kenmore Refrigerator-Freezer top
install a defrost drain tube heater call sears for a part number have the model handy befor calling
Apr 21, 2008 | Kenmore 64254 / 64252 / 64259 Top Freezer...
Kenmore side by side no longer freezing on freezer side and not as cold as it should be on both sides
We had the same thing happened. We called Sears and scheduled a repair. Apparently there is a small electric heater that keeps the coils from freezing up and had to be replaced, about $80, I think. Not sure if that is your problem.
Mar 05, 2007 | Kenmore 44109 / 44102 Side by Side...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
148 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
