Question about Kenmore 73932 Gas Dryer
Flame does not turn on for heat what could be the problem
  • 612 Answers
This could be and is most likely the igniter. Even if it glows, it does not mean it's good. It could also be the ignition coil. Go to www.partselect.com and enter your complete model number. This will bring up diagrams of your unit. You will be able to see the parts as well as where they are located. Good luck
Posted on Nov 17, 2009
Does low water pressure influence water being heated? The flame does not ignite. Gas bottle(19 kg is more tan half full).
no--- as low pressure is what turns the gas on to heat up
high pressure turns the burner off
call a gas fitter to determine the real reason the flame is not igniting
Apr 09, 2017 | Heating & Cooling
Propane heater burner has flames coming out the side heating chamber
This points to 2 things blocked burners ,or blocked heat exchanger eithe rway this should be turned off now ! and get a gas fitter to look at this as this would give off fumes .
Jan 30, 2013 | Dayton Heating & Cooling
The furnace will light up and the fan will blow but the flames cut out before my house reaches temp. i have the thermostat set at 70 and the house will not get above 55. i have tried turning the propane...
First, for those of you who might not know, "What is a flame sensor?" A flame sensor is a safety device. When your furnace's main burners ignite (light Up) the flame sensor picks up the heat from the furnace's main burning and says, "YES," and sends a signal back to the main furnace control board saying that it is OK to let the main burner stay on. Or if the main burners do not ignite, the flame sensor does not pick up the heat and says, "NO" to the main control board, Shut That Gas Valve and Main Burners Down! Thank God we have safety controls like the flame sensor. Most of the time, after turning your furnace's power off, you may clean the flame sensors with light sand cloth, emery cloth or steel wool. Reinstall the flame sensor and you are back in business! Over the years flame sensors can build up a light coating of burned-in dust and dirt. This insulates the flame sensor so that it doesn't sense the heat of the flame well enough, so by cleaning it you have almost restored it to its new condition. Seldom, but sometimes they do go out completely.
Dec 08, 2010 | Coleman Heating & Cooling
Pilot will not stay lit unless red knob depressed
There is a thermocouple that protrudes up into the flame. If the thermocouple is bad or out of adjustment it will not produce enough electric current to lock the red knob down allowing the heater go into operating mode. This thermocouple is a safety device that senses weather there is a flame or not. If no flame no heat don't turn on. If heat then there must be flame OK turn on. The thermocouple should protrude into the flame about an inch to heat it sufficiently to trigger the valve if it doesn't adjust it into the flame more. If adjusting does no good replace it. Take the old thermocouple to the store you bought the heater at and get a replacement. If you cant get it there almost all hardware stores or heating stores will have generic replacements that will also work.
Oct 08, 2009 | Mr. Heater Mr Heater Portable Buddy...
No heat
It can be both the heat fuse that gone or your pilot light has gone out, check to see if you see a flame while it is functioning, to do this turn on your dryer and watch in the dark so that you can actually see the flame coming on and off or check behind the little door that houses the pilot light to see if you see a flame if no flame relight, this should start your dryer producing heat again
Jun 22, 2008 | Sharp R-353 Microwave Oven
Amana gas range bake burner does not heat
Pull the bottom of the oven off. You will see 2 to 4 screws that hold the panel on. The ignitor is under there. Look at the ignitor carefully for breaks. I say carefully as the ignitor is very easy to break.
Feb 03, 2008 | Ovens
Kenmore 73932 Gas Dryer Logo
75 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
