Question about Dryers
DRYER I HAVE MAYTAG PERFORMA DRYER MODEL PYE2000AYW DOESN'T RUN NOT AT ALL The dryer doesn't start. Checked door switch, timer push to start switch, house circuit breaker. Everything is okay.But still the dryer does not start.This is a series 10 model. Where is the thermal fuse located and how to access it?
  • 1 more comment
  • Anonymous Mar 10, 2008
    dryer stopped running in middle of cycle
  • Anonymous Mar 26, 2014
    Dryer doesn't power up & no light. I believe I heard the timer working. House CB wasn't tripped. I've made repairs on it before but I cannot find the book I used to troubleshoot the faults. (Time-Life Magazine appliance repairs)
  • Anonymous Mar 27, 2014
    I do not know where to find the fuses or breaker in my dryer?
  • 51 Answers
The thermal cut-out is located on the side of the heater housing assm. To gain access you need to use a putty knife to depress the two spring clips between the top and the front panel and raise the top. The heater is on the back wall. The part number for the t-stat and thermal cut-out kit is LA-1053 and is about $20.00. Don't forget to clean your vent, and check your blower assm. Either one could have caused the problem.
Posted on Jan 10, 2008
My dryer will not start when I push down on the dial. There is power to the dryer. When I turn the dial on to the timer, I can here the ticking sound, so the timer is working, but it wont start when I...
Maytag Performa Mod.PYET244AYW wont start has power door switch good thermo protection good at element cant fin any fuses timer has 120v and selecter switch
Oct 14, 2010 | Maytag Dryers
Model # PYG3200AWW my dryer was having a hard time starting and now won't start.
to check for bad motor,open dryer door,hold in door switch and someone push in on start switch,at the sam time reach inside the dryer and turn drum clock wise,if it start's than you have a bad motor.
Nov 15, 2009 | Maytag Performa PAV3200
Maytag dryer overheating
have u replace heating sensor
Oct 22, 2009 | Maytag PYE2200 Dryer
My maytag performa dryer stopped working. The
If a dryer is not working at all that's not good! But it doesn't mean you need to go appliance shopping just yet. It may be something very simple like a bad door switch or even a broken door switch actuator, in a kenmore dryer there is a tab thats sticks out of a hole in the wall that allows the dryer to run only if the door is shut, other models may have button that protrudes out of the dryer and when the door is shut, this allows the dryer to run. These switches go out from time to time, also if a dryer is full of lint build-up over time this will cause the dryer high limit or fuse to blow. The fuse is located near where the blower is in most cases. When the air in the dryer gets way too hot the fuse/hi-limit will blow and the house wont burn down.
Sep 12, 2009 | Maytag Dryers
Maytag Performa Pye2000ayw won't turn on-tried taping wires
If your dyrer has a thermal fuse, it will be on the blower housing (front), not on the heat element. It will be either white plastic os a button about half the size of other thermos. The fuse on the heat element will shut down the haet only. Hope this helps!
Jan 04, 2009 | Maytag HYE3658AY Electric Dryer
Dryer knob sticks in one spot- won't move
 Door switch / Door switch actuator leverThe dryer would not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
Oct 25, 2008 | Maytag Clothes Dryer Almond Timer Knob...
DRYER
The door switch is a good start but UNPLUG DRYER and under the top of the dryer is a thermal limit switch lift the top using a putty knife on each side of the lid raise it and on the left rear you will see the element look under the wires going to the element (straight down) you will see a limit switch with two wires on it remove these wires and plug them into each other.make sure they dont hit the frame and plug dryer back in and try to start it if it starts replace the thermal fuse you can tape these wires together with electrical tape and use it until you get the fuse but dont wait 6 months to do so it could cause a fire .Good Luck
Dec 29, 2007 | Dryers
Dryers Logo
338 people viewed this question
Top Dryers Experts
Marvin
Marvin
