Question about Briggs & Stratton Garden
How do I install a fuel pump on a model #31g777 0559 17 1/2 hp briggs and stratton engine?
  • 169 Answers
Remove the screws that hold on the fuel pump install new pump and torque screws to 16 inch lbs
Posted on Nov 19, 2009
No fuel flow to Briggs & Stratton Intek, 18.5 hp
blow air back threw the line towards the tank you have something clogging it or you forgot to turn the fuel on
Jul 07, 2012 | Briggs & Stratton Briggs Stratton Intek V...
New battery, new starter & still problems starting
Hello! How long have you owned it? Question is directed at the carb and fuel pump...I would suggest rebuilding the carb with kit and replacing the fuel pump at the same time...see photos below...There are a couple of different fuel filters; one for a non- fuel pump (gravity feed) and one with a fuel pump...Your engine requires the fuel pump filter...dirt and varnish build up in the carb and pump especially if the wrong filter is installed...Buy a gallon of carb cleaner with the tray inside...
Guru...saailer
Genuine OEM Part - Manufacturer #808656...$18 Fuel Pump
Genuine OEM Part - Manufacturer #691035...$6 Filter
Genuine OEM Part - Manufacturer #797890...$45 Rebuild Kit
Feb 13, 2012 | Briggs & Stratton Briggs Stratton Intek V...
My 18 hp vanguard is making oil,( oil level is rising) is not carb as it starts and runs good. any chance of bad fuel pump?
if the diaphragm in the fuel pump gets a small hole in it , it will still run, but **** fuel into the crankcase, the fuel pump is serviceable, and easy to rebuild, a new diaphragm kit is fairly cheap at any local saw shop, just remember to take the model number off of the engine so they can look it up, and sometimes its a good idea to take the pump in with you to match it..
Aug 20, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
Carb wont pump gas
If gravity feed works to the fuel line on the carburetor, then the fuel pump is bad. Repair or replace fuel pump. I am looking for fuel resistant sealant to repair fuel pump diaphragms. Has anyone tried Permatex 85420 or something else to achieve this? My application is antique and the part is no longer available at a reasonable cost.
May 04, 2010 | Briggs & Stratton Briggs Stratton Intek V...
On a 2-cylinder, 25 hp Briggs & Stratton INTEK twin engine (year 2002, Model 44577-0134-E1), there is a ~1.5-inch rubber hose to the top of the right OHV cover coming down from a round plastic piece in...
Ok I haven't worked on this exact model before but Im curious if the engine runs?
It sounds to me like a fuel pump that uses crankcase pulses to pump the fuel. It is very common way to pump fuel but usually the pump portion is in the carb and not the fuel line.
If it were attached to the intake Id say it was a crankcase breather.
May 01, 2010 | Briggs & Stratton Briggs Stratton Intek V...
20 hp briggs and stratton revs up and down
lower throttle and if that doesnt solve it check the governor might be broke
Jun 24, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Engine starts but won't stay running
an easy way to know that is to start engine and give it a shot of starting fluid ,if you can keep it running by this method I would replace diaphragm.
Jun 18, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
420 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
