Question about Sharp AR-507 Copier
I want to connect my sharp ar 507 to the USB port of the pc to improve the data tranmation in aprinting job.really i used adapter from pc USB to the parallel port in the machine but doesnt work, althogh the PC istalled the printer automatically.
  • Sharp Expert
  • 257 Answers
Test your cable elsewhere and see if it works, if okay, use another port in your computer.That should solve it otherwise replace your printer card in your printer.
Posted on Mar 20, 2010
WHEN I SEND APRINT JOB TO AFICIO MPW 7140 THE JOB GOES TO ANOTHER PORT, NOT TO THE PORT OF 7140, IT SEMMW LIKE AS IF THE PORTS ARE CONFUSED. I USE WIN 7
In your printer settings in the printers and devices check to see what port you are trying to attach to. If you are connected to a network printer verify the IP address is correct if you are connecting through USB check to see that you are connecting to the proper USB you can see if there are other USB ports listed and try one at a time until you get a satisfactory print test.
Jul 28, 2016 | Microsoft Dsp Windows 7 Home Premium 32...
Is there a reset code for a Sharp AR-507 copier, error H2-00?
enter simulation: pound, interrupt, clear, interrupt, then enter 14, press start,press execute on touch screen, press ca until copier restarts, this is a general clear code, if problem returns you will have a heat problem in the fuser.
May 04, 2010 | Sharp AR-507 Copier
I want to connect my ar-507 gray digital copier to pc UBS port
Did you use a pcl driver? What was the error message?
Nov 19, 2009 | Sharp AR-507 Copier
Sharp AR-168D will not print
you should change your printer data cable or fix correctly with printer port.
Jul 30, 2009 | Sharp AR-168D Copier
Problem with sharp ar 5320 copier
Sounds like a bad earth or loose connection. Try using the parrallel port instead, or take the panel off and look for bad connection
cheers
Nov 29, 2008 | Sharp AR-5320 Black and White Copier
Sharp AR-507 code E7-00
ICU Communication error. Could be a problem with the ICU board or the connection between it and the PCU board. If resetting the machine (main power off and on) does not solve the problem you'll likely need a service call from a copier tech.
Oct 07, 2008 | Sharp AR-507 Copier
Problem with Sharp AR-507
the Paper does not Jam. The copier just indicates that it is processing data but never seems to print. Seems to print every now and again if we change the fonts to download fonts. Not sure if there is an easy fix
Jun 11, 2008 | Sharp AR-507 Copier
Manufacturing DAte Of Sharp AR-507
that copier was in production between 1998 and 2000, dont quote me but i think it is 9/9/2000
Jan 31, 2008 | Sharp AR-507 Copier
Can't install
If you can ping its IP, you have that part correct.
What you may be having is a firewall issue.
If your firewall protection is not allowing an exception for that IP address, you can ping the machine, yet the data being sent will be blocked.
I have seen this several times in setting up printers, you have to go into your firewall and set up an exception for the IP address on your firewall.
I suspect that is the issue. Not uncommon.
Jan 16, 2008 | Sharp AR-507 Copier
Sharp AR-507 Copier Logo
147 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
