Question about Air Purifiers
I replaced a Lennox DSL-450LX heat pump thermostat with a Honeywell RTH3100C. Everything works except the gas does not ignite when set to emergency heat. The Lennox was wired as follows: W = white wire Y1 = yellow wire G = green wire R = jumpered to 24V 24V = red wire 24V(c) = blue wire O = orange wire (brown and black wires not used) I labelled the wires as I disconnected them with the stickers from the RTH3100C package. I followed the instructions as best as I could and wired the Honeywell as follows: AUX = white wire Y = yellow wire G = green wire O = orange wire R = red wire C = blue wire E = small wire jumpered to AUX per instructions (There's a note on the inside of the honeywell that says that C is optional with batteries installed, but I wired it anyway.) Any ideas why the gas won't ignite during eHeat?
  • bpen42 Nov 17, 2009
    Thanks! It is actually a heat pump system with gas for aux/emergency heating. It has two heating modes. 1) Heat, which uses the compressor/heat pump system to heat the house, and 2) E-Heat mode, which bypasses the compressor and uses a gas furnace in the attic and blows through the same duct work as the heat pump system. It's the builder's design. Personally I can't see why they went with heat pumps if they were going to put in gas furnaces as backups anyway. It would have been cheaper to go with AC units instead of heat pumps.
    President:
  • 1,515 Answers
Hi, If indeed you do have a heat pump, there wouldn't be any gas involved as a heat pump runs on freon with a reversing valve and heat strips for aux and emerg. heat. For gas electric operation thermostat terminals are rc to rh with factory jumper. Red wire to either.W to W for Heat, Y to Y for cooling G to G for Fan. If you have a blue, you wont need it unless this is a commercial stat useing a common for the Led lights on the stat. The unit will get its 24volts through R terminal in combination with y,w,and,g. Cant be a heat-pump if you have a gas furnace.Wrong t-stat. You need a gas /elect stat. And on a 24volt programmable t-stat, the batterys are used for the program only.If the batterys die, than you will loose the program on most residential stats. On commercial stats with the common in play, when batters die the stat defaults back to the factory settings.If you had a Lennox heat-pump stat on a gas/elect unit, you need to change it. Someone was using what they had on hand. Let me know if this has helped you.I will be here if you need me. Sincerely,
Shastalaker7
Posted on Nov 17, 2009
  • Robert Horton
    Robert Horton Nov 17, 2009
    Hi, that threw me on the gas aux on a heat pump as I have to admit, in this field you learn something new everyday. It looks to me that you have terminated correctly, I would leave the common . Try disconnecting the jumper you have E and see if the furnace fires.
    Shastalaker7
  • Robert Horton
    Robert Horton Dec 05, 2009
    Hi, I am sure you have got the solution by now, if not you need to remove the red jumper to fire the gas. I should have focused on your wiring terminations better. I am sorry its been awhile.
    Shastalaker7
Heating& CA
would think that the thermostat has failed .
Jul 07, 2016 | Honeywell Air Purifiers
In house temp is high and furnace stll goes on
Might be dust in the thermostat. Filters might be dirty. I would call a service man before the house burns down!
Apr 01, 2014 | Honeywell Digital Round Single Stage...
New a/c - furnace installed, no instruction manual, it is 23 degrees outside, and I have no idea how to turn on heat instead of a/c. Need thermostat instructions.
Usually just put the thermostat fan on auto, the a/c heat switch to heat and set the temperature where you want it. If it's a gas furnace, you will need to light the pilot. Usually instructions are on the furnace door, maybe inside furnace door.
Dec 05, 2013 | Air Purifiers
Furnace stop working after cleaning the electronic air cleaner F50
Try this educational video: https://www.youtube.com/watch?v=erpnfKbqmoM It could be something as simple as a pressure switch.
I hope I helped you out!
Apr 01, 2017 | Honeywell (F50F1032) Air Purifier
I want to take the 17440 air purifier apart to see why it won't start.
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Aug 30, 2010 | Honeywell 17000 Air Purifier
Unable to locate owner's manual for Honeywell
Go to honeywell.com
Mar 25, 2010 | Honeywell QuietClean HFD-010 Air Purifier
Hi, I have a question about Honeywell F300E
You need to replace the power supply of the unit, Contact your heating and cooling contractor for service on the unit.
Oct 06, 2009 | Honeywell Enviracaire Elite F300E-1019 Air...
Honeywell F300E not cleaning air.
A newly installed system should still be under the contractor's labor warranty. Call them and ask them to come out to check on the unit and explain what you wrote above. This should cost you nothing and is the best way to get to the bottom of the problem.
Nov 09, 2007 | Honeywell Enviracaire Elite F300E-1019 Air...
Air Purifiers Logo
1,164 people viewed this question
Top Air Purifiers Experts
Michael Youngman
Michael Youngman
Are you an Air Purifier Expert? Answer questions, earn points and help others
