Question about Panasonic MC-V5745 Bagged Upright Vacuum
I CAN'T SEEM TO INSTALL A NEW UB8 BELT
PLEASE SEND ME AN APPROPRIATE FIGURE DIAGRAM.
  • 1 more comment
  • mo16sor Jan 11, 2008
    THANKS FOR YOUR INFO! I HAVE SINCE BEEN ABLE TO FIGURE THE INSTALLATION OF THE BELT.
  • Anonymous Sep 02, 2008
    Diagram does not show exactly where to put the belt. The belt's break so easily, I wish I had my old vacuum back, never had this muuch trouble. If Panasonic is reading this, it is costing me so much to replace the frail little belt than I've ever paid on repairs on other vacuum cleaners. Please send me a years supply, ha! and a diagram, for I pay over $5.00 each time it breaks. I have had nothing but aggrevation with this belt problem. Again, where exactly do you put the belt, so I can do it at home and with over $300.00 invested in this vac, I sure can't afford another one. Thanks!
    Where is the motorshaft on the MC-V5745, there are so many places one could put the belt and it slides off and breaks. I don't know a motorshaft from a motorboat. Help!!
    President:
  • 1,673 Answers
  1. Remove the lower plate
  2. Carefully lift up on the agitator assembly until it clears both sides of the nozzle housing.
  3. Remove the belt from the motor shaft by sliding it off between the end of the shaft and the nozzle housing.
3.4.2 Installation
  1. Place the belt around the motor shaft.
  2. Start the new agitator assembly back into the nozzle housing by placing the side opposite the belt partially into the slot. This will hold the agitator in place and leave both hands free to place enough tension on the belt to allow that side of the agitator to return to the nozzle housing slot.
  3. Place the belt around the agitator pulley on the agitator assembly.
    NOTE: There is a place for the belt to fit on one end of the agitator assembly only. This is the agitator pulley.
  4. Use both hands to pull the belt tight, and slide the agitator assembly firmly into the slots on each end of the nozI CAN'T SEEM TO INSTALL A NEW UB8 BELT - repagitc.png
  5. Rotate the agitator assembly by hand to insure nothing rubs and to check for correct assembly.
  6. Replace the lower plate
Posted on Jan 10, 2008
I need a diagram to show me where and how to install the front belt< I think the motor belt) on my Hoover Windtunnel, self propelled Model U6634-900 series x12-0 60HZ 120 V
Most vacuums are pretty well the same belt set-up...remove the metal plate covering the rotating floor brush and pull it out...place new belt over motor pulley and and stretch other end over rotating floor brush in the space provided for it....pull and place ends into slots on the sides....if the belt is not straight flip the brush the other way...you will figure it out. Just be sure to buy the right belt!!!
Regards,
Dennis
Aug 15, 2014 | Vacuums
Seem to have a belt slipping problem. The motor runs but the belt is not turning. Have been trying to get new belts. IMPOSSIBLE !!! I have two machines...148 15600 and 385 1233280
I assume you need belts for both machines? Searspartsdirect (SPD) are the best place for Kenmore replacement parts.
There are 2 belts on the 385 1233280 - the timing belt and the drive belt. Both are in stock at SPD and can be obtained by clicking on the following link:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Sewing-machine-Parts/Model-3851233280/0582/1220000/00024020/00008?blt=06&prst=&shdMod=
If you hover over the exploded parts diagram you can see a larger view. The timing belt is number 7 and the drive belt is number 15. If you scoll further down the page you can add them to your shopping cart.
They also have both belts for the 148 15600. They are numbered 16 and 17 in this diagram:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Sewing-machine-Parts/Model-14815600/0582/1220000/00033316/00008?blt=06&prst=&shdMod=
Again both are in stock, and can be ordered by scrolling down the page and adding numbers 16 and 17 to your shopping cart.
Yoiu may be able to get these from a Sears store, but you can any which you need from here.
Hope this helps. Please post back if you need further assistance.
Regards,
BElectric
Dec 16, 2010 | Vacuums
I need help replacing my belt
Just changed mine. I have a Turbo Force 6585. Flip it over and press with your fingers on clip #s 2,3 and 4 (This releases the cover over the roller brush - The clip locations are labeled on the plastic cover). Remove the cover - this will expose the brush , belt and drive motor spindle. Pull the roller straight out (note one side of the roller has a "square peg" - its pretty obvious but you need to align it when replacing. Remove the belt and replace the new one over the silver motor spindle first and then the roller. You will see the area or Pulley (it is part of the roller brush itself) to put it on it is fairly obvious where it goes. Use the roller to stretch the belt and insert the roller back in and replace the cover.
Note; There have been several complaints about belts breaking prematurely on these models - I used a Homecare No. 1145 that is made to fit Panasonic Upright, Belt type UB / UB8 - This belt is about an 1/8 longer (much less tension) than the supplied one and it hasn't broken yet - Considering the factory supplied belt broke in 3 uses, I really don't care what Bissell recomends as this has been a common complaint with this mode on forums. Hope this helps
Apr 12, 2010 | Bissell 6594 PowerForce Bagless Upright...
Cannot figure out how to install brush belt on a bissell proheat
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
twywt
Jan 16, 2009 | Bissell 8910 ProHeat Clear View Upright...
Can't figure out how to get the belt around vacuum motor shaft
I am assuming you are referring to the beater bar belt. You will either find a release lever on each side or a small screw and bar restraining the bearing that holds the bar in place. Removing whichever of these you find will allow you to install the new belt. Clean up the dirt accumulation on the bearings while it is apart.
Dec 31, 2008 | Eureka Smartvac 4870 Bagged Upright Vacuum
How do you change belt on Bissell pro heat carpet cleaner. can you please send diagram or instruction how to change belts.
http://www.bissell.com/images/UserGuides/7950_1204.indd.pdf
here is the complete manual (it is in pdf form)includes diagrams & instructions on belt replacment.thanx for using fix-ya!!!please rate all replys.
Nov 30, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
I have no idea how to put the belt back on
Take the nozzle of, remove the brush roll, put the a new belt over the brush roll, re-install and put the bottom plate on, making sure that the belt is in the middle of the brush roll. Turn the big knob on the front until it locks, when it grabs the belt it will be hard to turn. Re-install the nozzle on the machine and lock it down. Turn the knob again all of the way, this will release the belt unto the pulley.
Jul 13, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Generation 4
First off get a new belt, I am sure this one has stretched. Then put the belt around the brush roll, put it in the center, put the bottom plate back on. Then turn the big knob on the front and turn it until it locks, you will know if it grabbed the belt, it will be hard to turn. Then install the nozzle back on the vac, lock it down, turn the knob again and it will release the belt on he pulley.
Jun 22, 2008 | Vacuums
Need instructions on how to replace the belt on a hoover dirt finder model u5321-930
You can download the manual from the link below: http://www.hoover.com/Media/ModelPDF/U5468900.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 28, 2007 | Hoover 5416-900 WindTunnel Bagged Upright...
Cannot get new belt on
no need to remove motor shaft which is integral with motor. slip belt on motor shaft first, then on roller then pull roller back to correct position. needs a little force
Jun 06, 2007 | Hoover U8145-900 Savvy Bagless Upright...
Panasonic MC-V5745 Bagged Upright Vacuum Logo
654 people viewed this question
Top Panasonic Vacuums Experts
Jim Parker
Jim Parker
Joseph Hoffmann
Are you a Panasonic Vacuum Expert? Answer questions, earn points and help others
