Wont work Simpson EziLoader 5.5kg front loader - when i close the door and set the dial it makes the sound that the door is locking over and over again.
    Scholar:
  • 53 Answers
Your door lock is not fitting correctly!
This is a safety override to make sure that the washer does not fill with water & leak all over the floor because the door is not locked properly!
Suggest you get the door lock mechanism checked out and adjusted. It could be that this has either become blocked with soap powder or cotton material shedded from your clothing over time.
The latch is normally available as a spare part, so you could check this out with your local Simpson dealer, or buy it on the internet once you know the part ref number.
Posted on Nov 17, 2009
    President:
  • 1,653 Answers
Try turning off the AC power for 30 minutes then switch it back on and trying to close the door again. make sure there is not too much wasing in the machine. If the error persists you will need a new door lock assembly fitted.
My Simpson eziloader front loader 5.5kg will not fill up with water
get the water inlet valve replaced or clean the water screens in the hoses ,possibly
Aug 28, 2016 | Simpson Washing Machines
I have a Simpson esprit 550 and it won't agitate or spin? Fills and drains fine any help would be great thanks
check pressour switch door lock or lid lock not familer with mechine so don't no if its top or front loader good luck
Apr 20, 2015 | Simpson Washing Machines
My simpson eziloader machine won't start - when I press the start button it clunks a couple of times then nothing - water won't enter have checked the inlet pipes
sounds like blocked pump or door latch sensor/switch more likely pump blocked.thats normally first to activate in wash cycle.if unsure seek help to locate and check.it ll be either accessable from bottom front of machine or you may need to tip it up as it ll be at bottom of machine.unplug first,and if you pull pipes off pump to access there will be some water.hold waste pipe as low as itll go to release any water left in machine
Feb 21, 2015 | Simpson Washing Machines
I would please like a manual for the simpson eziloader front loader washing machine
45s558e_lr.jpg A 5.5kg capacity front load washer with a stainless steel spinbowl, 8 wash programs, variable spin speeds, 2.5 star energy rating and a WELS 4 star water efficiency rating (56 litres). General Specifications Colour: white Overall Dimensions (Check installation guides in downloads for exact dimensions) Overall Height: 850 mm Overall Width: 600 mm Overall Depth: 630 mm Key Specifications and Features Capacity: 5.5 kg Energy star rating on old scale: 2.5 stars Spin Bowl: Stainless steel Wash Programs: 8 Water efficiency star rating (WELS): 4 WELS Water consumption: 56 Litres Other Specifications Door opening - Large: 300 mm Door opening angle: 165 degrees EAN: 8853328005026 Variable spin speeds: 800,650,500 rpm Other Features Colours 40/ Colours cold: Yes Cotton 60 / Cotton 60 eco / Cotton cold: Yes Cycle start/pause button: Yes Delicates 30 / Delicates cold: Yes Extra rinse: Yes EZILoader: Large EZILoader doors makes loading and unloading your washing easy. Levelling legs: The levelling legs may be adjusted if the floor is not level, to ensure correct operation of the washing machine Pre-wash: Yes Pushbutton electronic options: Yes Quick Wash: Yes Rinse/ Drain / Spin: Yes Rotary Electronic Controls: Yes Wool 30: Yes Warranty Details 2 years from the date of first purchase (3 months for commercial applications) and subject to the conditions set out in the warranty card accompanying the product when purchased.
Aug 06, 2011 | Washing Machines
Simpson ezi loader 5.5kg front loader. when it goes to start the door clicks 3 times then the end light flashes. I am an electrician. but I do not work on appliances. if you could send me a...
the door is clicking because it is trying to lock the door but is unable to for some reason what is the make/ model number of the machine? most likely it would be something dealing with the door look but id rather be 100 percent correct then assuming Please send model number i await your reply Thanks again
Rick
Dec 09, 2010 | Washing Machines
Simpson Front Loader won't start - Clicking Noise
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 03, 2009 | Washing Machines
How to turn on the simpson eziloader dryer
The timer is the "on" switch.
Things that can stop it starting.
Door switch- is the depresser pin contacting.
Broken main belt.
Faulty - motor- timer- door switch- belt switch ( if fitted) wireing.
Aug 29, 2009 | Dryers
Dryer will not spin
are you sure the drum belt isn't broken,the whirring noise your hearing sounds to me like the motor is turning
Jul 30, 2009 | Whirlpool GEW9250 Electric Dryer
Simpson Eziloader frontload washer clunks 3 times and ends
The motor controller or ECU is to blame.
Have them checked & replace as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 14, 2009 | Washing Machines
My Hotpoint Aqaurius WD62 door is shuting but the door lock light wont come on!
you may need a switch but not a door see if you can adjust the door and try shutting it hard as front loaders close snug because of the rubber boot check your power too
Mar 02, 2008 | Hotpoint Aquarius WD63 Front Load...
194 people viewed this question
jasbo
jasbo
