Question about Tappan TGF320 Gas Kitchen Range
Tappan ES 200 burner stays on high and not turning off.
Tappan ES 200 front right (only large) burner stays on constantly no matter where the dial is set. The burner will also sometimes not turn off.
  • 187 Answers
I need to clarify a bit.... did you remove the knob and check where the metal rod inserts into the plastic knob hole? If that is chipped on the inside, it will not turn the metal rod that comes out of the stove. Take the knob off, and use a pliers to turn the metal rod. Leave me comment if you have already checked that or you do not have that type of knob on your model.
Posted on Nov 17, 2009
Kitchenaid electric stove burner stays on high
The dials you mentioned are called infinite switches and if they control, or regulate should i say the amount of power applied to the burner, so those are the parts you need to replace. You can order online or go to a local appliance parts store, just make sure you take your model number with you, not the number in your owners manual but the model off the machine itself.
May 08, 2012 | KitchenAid Kitchen Ranges
Large right/front burner is out of control. Regardless of the setting, the burner heats very high. In fact, recently, oliver oil in a skillet ignited. Even though the control was set to less than medium,...
The switch for the right front burner is defective and needs to be replaced,its bad as far as internally when turned on no matter what its set it the interal contact is stuck on only high so their is no setting it will work on except high. By replacing the switch it will work on the various settings and not just high.
GENE
Sep 23, 2011 | GE Cooktops
Right large burner cooks on high no matter what setting.
This is usually the infinite switch has failed. They are easy to check and inexpensive. There is a video at http://appliancehelponline.com/infiniteswitchvideo.html that will walk you thru testing this. It may be a different model but the testing will be the same. You can also enter your model # for diagrams and illustrations for your specific model. Not all models are available. All parts come with installation instructions.
Jun 08, 2010 | Hotpoint RB787BHBB Electric Kitchen Range
Tappan front right side burner gives out very little flame...
sounds like a ignitor problem or a dirty burner.clean all the holes of the burner and if you could see the oraphas clean that as well.
Mar 06, 2010 | Tappan TGF320 Gas Kitchen Range
Flame going low on range cook-top
Check your gas supply is not running too low and then check for leaks, Let me know if this helps.
Jan 02, 2010 | Tappan TGF320 Gas Kitchen Range
Right front (large) burner indicates hot, won't work, flashes F153
I hade a code 153 also. Changed the element(costly-$200) and had to recalibrate the pan sensors(in the manual). All works fine now.
May 21, 2009 | GE Cooktops
Front left burner wont work.
It sounds like the left front control or element has a high resistance short.
Jan 23, 2009 | Tappan TEF242 Electric Kitchen Range
Tappan TGF320 Gas Kitchen Range Logo
480 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Sal DeAngelo
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
