Question about Sharp AR-M237 Copier
My copier is SHARP AR-M237 will be to change the toner and I get an error. Code F2-04. What can I do in this case, please help.
    Problem Solver:
  • 17 Answers
Your toner should be AR-270NT or AR-310NT. Try cleaning off the brass colored contacts in the plug on the back of the toner cartridge. The toner may also be faulty (try another) Also the contacts inside the copier may need to be cleaned by your copier technician.
Posted on Nov 21, 2009
2 Suggested Answers
  • 148 Answers
SOURCE: F2-02 error on Sharp AR-M237
on this code you may have to clean out the developing unit and start with fresh developer. Make sure the developer unit is not leaking from one of the bearings. You may need a tech for this one...
Posted on May 26, 2008
Diagram Sharp SIM14?
Type # - interrupt - C - interrupt and clear the code with simulation 14 and then hit CA to exit. If the code comes back there is a problem with your fuser (dirty thermistors cloged with toner, or one of the lamps are out)
Apr 06, 2014 | Sharp AR-M237 Copier
Sharp ar 5620 photocopy error f2
F2 errors means problem with toner supply or toner cartridge itself. For better understanding it is necessary to obtain a subcode by pressing START key. Clean toner cartridge CRUM chip contacts and check if cartridge destination is proper for your area.
Apr 15, 2013 | Sharp AR-M237 Copier
SHARP AR-M237 H2-00 ERROR CODE---HAVE INSTALLED NEW FUSER UNIT WITH SAME ERROR/CODE PROBLEM.
check harness and connector betwen thermistor and control PWB.
clear the error code by using SIM 14 if all didn't work you may have defective AC power supply
I hope this help
Feb 10, 2011 | Sharp AR-M237 Digital Copier
U2-40 code
CLEAR THE ERROR
Enter SIM
# - * - C - * - 16 - START
Mar 31, 2010 | Sharp AR-M237 Copier
Change the toner cartridge message doesn't go away on AR-M237
plese check you have changed the same partno toner or not. if its ok you have problem in connector wich hold the toner cartrdge ic
Feb 10, 2010 | Sharp AR-M237 Digital Copier
How to reset u2-40 for sharp AR266 photocopier
Since this appears to be a non-US model I can only base my response on the closest US body type AR-M237.
U2-40 means the countdown (CRUM) chip in your toner cartridge either broke or went to zero. If you can put in a fresh CRUM chip in your cartridge, that's great, otherwise you'll have to replace the toner cartridge.
L4-01 means main motor lock, probably due to a brownout or otherwise missed timing. You can probably get by with a power off and on. Not sharing your copier with other devices on the same outlet will also help here.
To reset error codes, put the machine in test mode with the four-key combo: # - * - C - * ... 16-Start clears your U2 trouble, 14-Start and 17-Start clear the rest. Then hit CA and allow your copier to reboot. Good luck!
Jun 02, 2009 | Sharp AR-M237 Copier
U2-40
Push P * C* in quick succession to enter simulation mode. Once there, enter 16 on the keypad. push the print button (like making a copy). Push 1 for yes then print button again. push the CA button. Copier should reboot and run fine for you.
Apr 01, 2009 | Sharp AR-M237 Copier
F2-02 Error on Imagistics ZB35 machine
Sharp AR-5620N getting f-2 error. What is the solution
Mar 03, 2009 | Sharp AR-M237 Copier
May 23, 2008 | Sharp AR-M237 Copier
Sharp AR-M237 Copier Logo
270 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
