Question about Microwave Ovens
My microwave light keeps burning out, can't find the right bulb on parts lists. Also display is dim, can it be replaced?
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave display - digits have become dim / partialy missing
We repair these on a regular basis for customers nationwide with our guaranteed $39.95 service.
Full details and *critical* safety, disassembly, and troubleshooting info is at Web our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Posted on Nov 18, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: Replacement light bulb for GE spacemaker microwave
That model number doesn't look quite right, but nevertheless:
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Posted on Sep 16, 2008
SOURCE: burned out bulb on GE spacemaker micro
turntable stop turning even when you press turn now
Posted on Aug 27, 2009
SOURCE: One surface light bulb on GE Profile microwave keeps burning out
I have the same problem. The left one burns out within a couple of hours use, the other one lasts a couple of months and is then gone. This pattern has repeated over 8 years. I replace them every now and then and then just go without until I get the urge again to fix it. Maybe smaller lower wattage lamps are worth trying...
Posted on Jun 28, 2010
Where to get light for ge profile microwave
It should be listed here:
https://www.geapplianceparts.com/store/parts/category/lightbulbs
With more information about the microwave, a Google search could find the exact bulb, and its price/availability.
Jan 15, 2018 | GE Microwave Ovens
Tip
How do I replace light bulb on my Jenn-Air microwave?
Hi.
You will need to partly disassemble the oven by removing the outer cover held by screws (the cover part 2 on the first diagram). once there you will see the bulb hand side, located on the right (the bulb is part 6 in second diagram).
Before disassemblying the appliance disconnect power, by tripping circuit breaker or unplugging the power cord.
Here the replacement part for the model JMC9158AAS, listed in title: PS391758 .
Diagrams below are also for Jenn-Air JMC9158AAS.
If you have a different model, use the links listed here: Where do I find parts and diagrams for my appliance?
Here the diagrams. Click on the pictures to enlarge.
Diagram 1:
Diagram 2:
Unless you are a technician or a trained DIYer, better ringing the number listed on the owners manual to call service support. A badly assembled microwave will be dangerous for your health. The capacitor inside the microwave can also release dangerous discharge, take care and observe safety prescriptions while disassembling.
Regards.
on Apr 08, 2010 | Jenn-Air JMC9158AAS Convection/Microwave...
Light over the stove is to dim
Good Morning Paul, thank you for allowing me to assist you!
For the above-listed Frigidaire model number, FMV156D, it is not recommended to use a bulb larger than 30 watts. Your microwave does not have an option available to adjust the lights. If the light is dimmed, than more than likely your microwave is experiencing an issue with the control board, a potential wiring failure, or faulty light socket. Regrettably, this is not a simple DIY job. I would strongly recommend connecting with a professional to narrow down the precise issue before investing in parts that may or may not be the root cause. You can often locate a qualified service provider through the manufacturer website.
Nov 24, 2013 | Frigidaire FMV156D Microwave Oven
Display window dim
I would open it up and look at the connections to see if any can be replaced. Look for any darkened or burned looking connectors related to the display panel. Hopefully you won't need to replace the display panel circuit board but if you do. I would look for the cheapest replacement starting with ebay parts, and search engines for that specific part. Sometimes there are microwaves of different models with the same parts too!
Nov 07, 2013 | Maytag MMV4205 Microwave Oven
Dim display light brightness
You will need to replace the display, call Dacor first to see if they will assist in a price break or replacement part. They are normally good with there customers. But there is no way to adjust the display, its just fading over time, like a light bulb.
I hope this helps
Oct 30, 2013 | Dacor DMT2420 1200 Watts Microwave Oven
How to replace burned out light bulb
You need to remove the top cover to access the bulb. That is the only way on most microwaves.
Dec 02, 2011 | Emerson MW8107WA Microwave Oven
On our Panasonic the genius sensor 1200w microwave the bulb burned out so replaced. After replaced turned light switch on both bulbs turned on and right away one bulb burned out and now the switch will not...
Mine burned out within a month. Probably due to the poor design of the machine which forces you to slam the door to get it to shut.
My biggest concern is the under counter lightbulbs it has burned out in my kitchen over the last year. I wonder how much leaking this thing really gives off. Moving in a few weeks and will be throwing this cancer machine out.
Sep 09, 2011 | Panasonic NN-H764 Microwave Oven
Jun 06, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Right bulb keeps burning out
the microwave has a short let a tech look at it to verify.
Apr 07, 2007 | GE JVM1630 Microwave Oven
Light socket is dead on my Maytag
Yes, this is caused by not disconnecting the microwave from the power line when removing or installing a bulb or by the filaments shorting when the bulb blows. This is a problem with the control panel assembly, which we repair nationwide for $39.95. If you or a friend decide to send it to us, we have *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Apr 01, 2007 | Maytag MMV4205 Microwave Oven
Microwave Ovens Logo
276 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
