Question about Canon imageRUNNER C2058 Led Printer
I am not able to replace black toner in Canon IR C2058 as cartridge in not going in fully. What can I do
  • sales847 Nov 17, 2009
    I have Canon IR C2058. I bought new black toner. Ihave removed the old one but new new was not going in fully. To check what wrong, I removed the Cyan but now Cyan is not back. Can you help me and tell me what is wrong with this copier? A simple thing has become hard one
Lower the developer unit handle and take out the blk DV and then take out the toner cart:and use a flash light i see what blocking it from coming out.
Posted on Nov 17, 2009
How do i stop my savin 2020 from printing a yellow streak on my color copies?
Sounds to me like either a faulty yellow toner cartridge (try replacing it) if the drum is integral with the toner this should clear it. Otherwise you may need to replace the yellow image drum.
Jun 09, 2014 | Canon for IMAGERUNNER C2020 C2050 C2058...
Canon ir 4580i e000020-04c0
Trouble in the supply of the toner from the toner cartridge to the developer. Too much toner is supplied to the developer. Broken or disconnected wire in the ATR sensor.
Replace the drum unit (check its connections).
Black in yours.
Jan 29, 2014 | Canon iRC4580i
I cant get the toner cartridges in my canon c ir 2050 to go back into the copier
Try these steps.
  • Pull out of the front cover of the Canon 2200 so that it flips down and exposes the inside of the machine.
  • Remove any toner cartridge already in the machine by pressing down on the blue lever located near the bottom right of the inside of the machine. Then grasp the toner box right above the handle and slide it out until it stops.
  • Hold the new toner cartridge in both hands and shake it from side to side a few times to loosen up the toner.
  • Orient the toner cartridge so that the flat surface is facing downward and the small handle at the end of the surface is pointing toward you.
  • Place the toner cartridge on top of the toner box. Push it back in as far as it will go and then press down on the cartridge until you feel it click into place.
  • Pull back on the small handle on the top of the cartridge. A thin separator sheet between the cartridge and the toner box will come out. Continue to pull until you see a stop sign on the separator sheet.
  • Tap on the toner cartridge to cause the toner to vacate the cartridge and fall into the toner box. After you have tapped it a few times, push the cartridge handle back in. When the handle goes all the way back in, you will feel the cartridge unlock from the toner box.
  • Remove the empty toner cartridge and push the toner box back into the machine. Pull up on the blue lever once the box is all the way in. Close the front cover to the Canon 2200.
Hope this helps.
Jun 29, 2011 | Canon for IMAGERUNNER C2020 C2050 C2058...
My canon printer ir 2022 prints faint and blank pages, what can be a problem and how can i fix it?
Possible Problems:
1)Out of / Low on Ink.
Solution : replace the ink
2)Printer Setting
Solution : Check to make sure the lighter/darker slider is somewhere near the middle. This will be in the configuration screen on your printer.
May 02, 2011 | Canon iR 2022 Printer
Canon iRC 3380i error code E00025-002...help please?
Service Bulletin
Issued by Canon Europa N.V. Copier Color
HARDWARE
Revised:
Addition of the Affected Machines
Hopper Assembly
Subject:
Measures against E025 error due to toner leak
Detail:
<Symptom>
The toner leaking from the toner cartridge flows onto the inside toner sensor (PS3/PS4/PS5/PS6), causing erroneous
detection and E025 error (Error in the toner motor).
Model:
iRC2380i
iRC2880
iRC2880i
iRC3080
iRC3080i
iRC3380
iRC3380i
iRC3580
iRC3580i
Ref No.:
iRC3380-023 Rev. 2
(F2-T01-NO1-10097-03)
Date:
January, 2009
cartridge, the toner in the supply route between the toner cartridge and the
hopper may leak between the gap between the toner cartridge case and the holder of the machine.
<Factory Measures>
The gap between the toner cartridge case and the holder of the machine is covered with the plastic sheet and the shape
of the front unit cable guide on the toner sensor is changed to prevent the toner from flowing onto the toner sensor.
P-1 Position where the toner cartridge is installed
nside and replace the front unit cable guide into its new type.
Points to Note About Service Work:
When the front unit cable guide is replaced, implement periodic cleaning (every year) for the area around the photo
sensor (PS3/PS4/PS5/PS6).
For the affected machines or later, implement periodic cleaning (every two years) for the area around the photo
sensor (PS3/PS4/PS5/PS6) and the area of toner leak [1].
Service Parts:
Supply of the new part(s) will follow a normal supply pattern.
P-2 GUIDE, UNIT CABLE, FRONT
[2] Change Point
Parts Number Description Q'ty Interchange
ability Fig No.
Old FC6-9380-000 GUIDE, UNIT CABLE,
FRONT 1->0 N
620
New FC6-9380-010 GUIDE, UNIT CABLE,
FRONT 0->
and later IR C3580 230V EUR : CZS00218 and later
IR C3580I 230V EUR : CZT04670 and later IR C3580 230V : CZU00011 and later
IR C3580I 230V : CZY00752 and later IR C3580I 230V AU : CZZ00857 and later
IR C3080 UL 120V : DBE01554 and later IR C3080I UL 120V : DBF02861 and later
IR C3080 230V EUR : DBM00294 and later IR C3080I 230V EUR : DBN10330 and later
IR C3080 230V : DBT00011 and later IR C3080I 230V : DBU00714 and later
IR C3080I 230V AU : DBV01085 and later IR C2550 UL 120V : DCA03694 and later
IR C2380I 230V EUR : DCF16473 and later IR C2550I 230V : DCK00864 and later
IR C2550I 230V AU : DCL01033 and later
Jun 15, 2010 | Canon C3380i Color Copier
Waste Toner is full. It's a iR2020/iR2016 photocopier and I need to clean it. Please help.
Hello sir; According this particular model,the waste toner box comes with drum unit, for another word if waste toner box is full you have to replace whole drum cartridge.
May 08, 2009 | Canon iR 2016i Black and White Copier
Toner waste container location
The waste toner is in the front, open front cover and the white bottle in the middle is the waste toner cartridge. Remove the black screw, and empty or replace the cartridge.
Mar 30, 2009 | Canon iRC3100 Printer
Canon IR3100 CN making grinding noise
hi..there...you may visit canon website at internet..chose product support/dowlnload----find your product here and finally you can get and download manual book as pdf for free....good luck..
Feb 03, 2009 | Canon imageRUNNER C3200 Color Printer
62 people viewed this question
old marine
old marine
