Question about Eureka Smartvac 7975 Vacuum
Eureka High filtration Commercial vacuum fan
I have a Eureka vacuum cleaner the one with a soft bag in teh back. the fan broke, and I was wondering how to replace it.
Thank you,
Rita
    President:
  • 1,673 Answers
One of 2 ways, remove the plate on the bottom, the is a clear cover covering the fan. Just unbolt the belt pulley and remove the fan. If there is no cover covering the fan, then you will have to remove the top, take out the 4 screw holding the motor and turn motor over, then you can remove the fan.
Posted on Jan 10, 2008
6ya staff
SOURCE:
QuickClean Commercial Vacuum Cleaner belts
The most common QuickClean Product is a Eureka and uses a round belt. Here it is!
http://vacuummedic.com/product.php?id=283
Good Luck!
Aug 29, 2012 | QuickClean Commercial Vacuum Cleaner Bags
Sc888 replace fan
please go to :http://www.eureka.com/en-US/Customer-Service/Videos/ proeed with common sense. God bless you
Jul 15, 2012 | Eureka Sanitaire Commercial SC888 Bagged...
Envirovac kicks debris back at my feet and is loud
It's clogged!
Many so-called "environmentally friendly" vacuum cleaners have multiple stage filters; the usual configuration is a standard filter followed by a HEPA filter or equivalent. Standard filters can be a paper bag or a bagless, removable container.
From time to time, the secondary filter will get clogged, so it doesn't matter whether you change the bag or empty the container, performance will not improve.
If you have access to compressed air, try removing the secondary filter and blowing it clean with a high pressure air nozzle. If that doesn't work, check the hose to make sure it's clear. If you are using a rug beater attachment, make sure it has not clogged at its inlet.
Sep 06, 2009 | Eureka High Filtration s Mighty Mite...
I have a eruka The boss vacuum that won't pick up anything
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=828446
Generic problem for all Vacuums
I have a Eureka The
Posted by jcross12 on Jul 24, 2008
I have a eureka the boss vacuum that won't pick up anything
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. It sounds t me like you may have a few problems, 1st the belt could be broken or stretched and is need of replacement. The belt should be changed every 4 to 6 months for the best cleaning. 2nd your vacuum cleaner could be clogged and stopping anything from going into the vacuum bag. 3rd it also could be your brushroll – the brushes end up getting soft and short and between the brushroll and the combination of the belt not working as well may cause it not to pup. Check your owner’s manual to see the trouble shooting section for unclogging your vacuum. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.eureka.com Customer Service
Customer Service Dept 1-800-282-2886
Electrolux Home Care Products
P.O. Box 3900
Peoria. IL 61612
Hours of Operation
Monday thru Friday 8:00am to 7:30pm CST
Saturday and Sunday 10:00am to 6:30pm CST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 24, 2008 | Vacuums
Changing fan
My solution is one that only works if the vacuum is a spare... To get mad at it and throw it in the garbage...
My thought though on what the problem actually was... Seeing as where the vacuum came from and what the problem was, that it was run with the fan broken causing more damage to the motor and therefore making it impossible to fix with just a fan. I would suggest that if your vacuum sounds different than it has before, stop running it and see if there's something you can do to fix it and if not then don't keep running it. Coins are the main problem with a broken fan and are not made to be sucked up by a vacuum cleaner.
Jul 16, 2008 | Eureka 1934 Bagged Upright Vacuum
I am replacing the fan on a sanitaire vacuum - I need to know if the threads are regular or reverse
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=562921
posted by mchll_trvn on May 01, 2008
I am replacing the fan on a Sanitaire vacuum - I need to know if the threads are regular or reverse.
The Sanitaire is a Eureka either a household or commercial vacuum and the plastic fan blade will push on but the fan pulley I believe is a clockwise and you tighten down with a wrench, there is only one way the fan pulley will screw on so you can make a mistake, if you have questions please feel free to contact your local vac dealer. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.eureka.com Customer Service Phone Number
1-800-282-2886 Hours of Operation
Monday thru Friday 8:00 am to 7:30 pm CST
Saturday and Sunday 10:00 am to 6:30 pm CST
Thanks, Don – The Vac Man
Go Ahead. Use Us.
May 01, 2008 | Vacuums
Eureka Smartvac 7975 Vacuum Logo
141 people viewed this question
Top Eureka Vacuums Experts
JoeVacs
Irene Tulloch
Android Man
Android Man
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
