Question about Diesel Watch DZ7078 Watch for Men
My Diesel DZ7078 beeps every hour. How do I turn it off?
Stop it beeping every hour
Have to reset button and hit mode at same time til days of the week disappear, beeping every hour should stop
Aug 25, 2013 | Diesel Anti-Intelligent
Can't set the digital time on Diesel DZ721
here are instructions from diesel:
http://store.dieseltimeframes.com/wcsstore/CommonDiesel/instructions/ENGLISH/Diesel_Digital-Guide_ENG.pdf
more specifically
TIME OF DAY MODE
1. Press C to toggle between Time 1 and Time 2.
2. Hold C for two seconds to set Time 1 or 2 as default.
3. Press D to turn on/off key tone.
Time 1
> To set Time, press A until hour flashes. Press B to select the setting
item. Use C and D buttons to adjust the values up or down. Press A to
exit set mode.
Time 2
item. Use C and D buttons to adjust the values up or down. Press A to exit set mode.
> The range difference between Time 1 and Time 2 is 23 hours.
CHRONO MODE
1. Press C to start and stop chronograph.
2. Press D to Split/Reset the chronograph.
3. Press A to recall the memory if Chronograph is stopped.
4. Press A again to view the next lap.
5. Press C or D to exit Recall mode and go back to Chronograph mode.
6. There are a total of 10 lap memories.
TIMER MODE
1. There are 3 different modes of timer: Count Down-Stop, Count DownRepeat, Count Down-and Up.
2. Press C to start/stop the timer counting.
3. Press D to reset the counter to the preset value if timer is stopped.
4. Press and hold A for 2 seconds to enter Timer Setting Mode. 35 Timer Setting Mode
5. Press B to cycle around the setting item: timer-type, hour, minute,
second and to back timer-type again.
6. Press C and D to increase/decrease the setting value.
7. Press A to exit the setting mode.
TIMER ALARM
Timer alarm will beep 2 times a second for 30 seconds.
ALARM MODE
1. Press C to select the alarm.
2. Press D to enable/disable the alarm.
3. Press B to change to Time mode again.
ALARM SETTING MODE
1. Press and hold A for 2 seconds to enter the alarm settings mode.
2. Press C and D to increase or decrease the settings value.
3. Press A to exit the settings mode.
Nov 19, 2012 | Watches
It beeps every hour. I want to turn it off
I pressed the buttons A and D at the same time, while the watch was ready to beep.
Nov 17, 2009 | Diesel Watch DZ7078 Watch for Men
Diesel DZ7076 beeps every hour
Press all the buttons at the same time. It's so annoying...
Jul 22, 2009 | Diesel Audio Diesel Watch
Turn off beeping every hour
How do I turn off the hour beep on my G-Shock?
Jul 10, 2009 | Casio G-Shock G2600 watch
Need instructions or a manual on how to stop beep mode on watch
To turn hourly beep on/off: Hold the RESET button (lower right) and press the MODE button (lower left). When the days of the week light up, the hourly beep is on; when the days of the week are off, the hourly beep is off.
To turn the alarm on/off: Hold the RESET button and press ST/STP (upper right). Alarm light will go on/off.
Mar 26, 2009 | Watches
Diesel watch dz7076 beeping every hour Anoying!
Press all the buttons at the same time. It works!
Mar 18, 2009 | Diesel Audio Diesel Watch
Diesel Watch DZ7078 beeps every hour
I have a Diesel watch, not sure of the type, but if I press both the bottom buttons either side of the display, it turns the chime on/off. (on this watch the buttons are MODE and SET/RESET)
Dec 29, 2008 | Watches
How do i make my watch beep by the hour
Press and hold SET, then press START/STOP. This should turn the chime on. Press it again to turn on the alarm.
Dec 27, 2008 | Timex 1440 Nylon watch
Innovage Gear wristwatch beeps every hour
To turn off the hourly beep: While holding the lap/reset button down, press the mode button. When all 7 day flags show, the hourly chime is on. When no day flags show, the chime is off.
Mar 11, 2008 | Watches
Diesel Watch DZ7078 Watch for Men Logo
187 people viewed this question
Top Diesel Watches Experts
Ansel Alberto
Ansel Alberto
Jimmy Accardi
Are you a Diesel Watch Expert? Answer questions, earn points and help others
