Question about Jet Plumbing
My jet pump will not turn off, keeps running....
Will not turn off, keeps running.... have checked pressure it is okay.... this was a replacement...installation setup worked for many years before this...
  • 41 Answers
May have a bad check valve
Posted on Nov 21, 2009
When H2O runs pump keeps cycling every 15 to 20 sec. H2O drops to 30psi and pump stays on until 60psi. Then a couple of seconds does again until H2O is shut off. Pump runs for around 30 seconds.
If you've got the water turned all the way on, it sounds like your setup is operating normal. If the pump where turning of and on say every 5 seconds or so I would say to check the air pressure in the water holding tank that it's at the correct pressure.
Mar 01, 2015 | Goulds Pumps Goulds J5S Jet Pump Shallow...
Can the pressure switch on the Utilitech 1hp convertible shallow well pump be changed from 20/40 to 30/50?
Yes, if the plumbing can handle the extra pressure. There should be a nut in the middle of a large spring inside the pressure switch. Turn that nut clockwise to increase the pressure. You may need to run some water to keep the pump cycling while you do this.
Jul 24, 2014 | Utilitech 1-HP Cast Iron Shallow Well Jet...
I have a Mastercraft1/2 HP self priming Shallow well jet water pump, the water fell below the intake in my well and I quickly noticed and turned off the pump. We had water delivered and I'm not su
If water is back up above the intake, it should prime itself in a few minutes. As long as you don't let the case get hot to the touch it should be okay to run dry.
If it fails to prime and pump up pressure, you may have to prime it.
Oct 20, 2012 | Plumbing
My low oil light comes on while trying to crank my car and car stalls; will not start until I keep trying a couple of times. After it starts it runs fine and then shuts off after backfiring sometimes and...
LOW OIL PRESSURE WILL CAUSE OIL PRESSURE SWITCH OR SENDING UNIT TO DISABLE FUEL PUMP.CHECK FOR OIL PRESSURE.REMOVE OIL PRESSURE SENDING UNIT SCREW IN OIL PRESSURE GAUGE TESTER INTO BLOCK WHERE OIL PRESSURE SENDING UNIT GOES TURN ENGINE OVER CHECK FOR OIL PRESSURE SHOULD BE 18 PSI @ 2000 RPM. BESURE TO WRAP TEFLON PLUMBERS TAPE AROUND THREADS TO THE OIL GAUGE PRESSURE TESTER OIL WILL SPRAY EVERY WHERE.IF YOU ARE GETTING NO OIL PRESSURE.YOUR OIL PUMP FAULTY.YOUR ENGINE CRANKSHAFT BEARINGS WORN OUT.WORN DAMAGED CAMSHAFT OIL PUMP DRIVE GEAR OR OIL PUMP DRIVE ROD DAMAGED OR BROKEN. IF OIL PRESSURE OKAY OIL PRESSURE SENDING UNIT IS BAD.
Sep 28, 2011 | 1994 Chevrolet Caprice Classic
Have an Onga JJ400 jet water pump several years old, pump is working but delivering poor water flow
Is the pump building pressure and shutting off? If the pump keeps running but not building pressure than there is most likely a problem with the well (low volume). Also check for a water logged bladder tank.
RJ
Jun 29, 2011 | Plumbing
2000 blazer will start and idle fine. but wont take fuel. the rpm will run up to 2000 after 2000 it looses power.i have checked the igntion/fuel presure/replaced throttle postioning sensor/replaeced fuel...
CHECK THE JETS , YOU HAVE GAS PRESSER BUT YOU COULD HAVE MAYBE JET PROBLEMS AND CHECK AIR HOSE'S.
GAS-------INTO-------JETS---into---------ENGINE-----LOW RPM
Feb 09, 2018 | 2000 Chevrolet Blazer
2000 gmc jimmy shut off while driving, replaced fuel pump relay, did not help. checked fuel pump and filter, both seem okay. after disconnecting and reconnecting fuel filter, vehicle started and ran very...
Replace the fuel filter first. When you turn the key on, the fuel pump should run for a few moments, then turn off. If it keeps running, then replace the pump as well. Suggest having the fuel system pressure checked at the engine itself. Hope this helps!
Sep 29, 2010 | 2000 GMC Jimmy
We have a well that has recently lost all water pressure. We have now replaced the points, the switch, the valves, and the pipe from the pump to the tank. We have bypassed the underground piping to see if...
What kind of pump is it? If it is a jet pump, it may need to be primed or the foot valve in the well could be blocked with rust or dirt. On a shallow well or jet pump, check it for suction side leaks. turn it off, and see if water seeps out of any of the joints. A small amount of air seeping in will make the pump airbound and keep it from building pressure.
Mar 07, 2010 | Plumbing
Cabin pump, primed fine only goes to28psi and keeps running
Sounds like the injector nozzle is plugged. This nozzle is directly inside the influent line on single line jets and down in the well on two-line jets. I'm assuming you have it primed correctly. If this happened suddenly the it'd definitely the injector nozzle. It it was a gradual process over time then I would say it's either a badly worn nozzle or worn impeller.
Apr 21, 2009 | Flotec Corrosion Resistant Shallow Well...
Turn 92 Escort 5 speed to right & engine goes dead even in a curv
if you jack up the right side of the car while its running does it die?...........just thinking that maybe the pickup has fallen off of the fuel pump in the gas tank so when the fuel moves to the left side of the tank the end of the pump may not be immersed in fuel.
hope this helps...keep me posted its definitely an interesting problem.....Good luck!
Dec 08, 2008 | 1992 Ford Escort 4 Door
Plumbing Logo
425 people viewed this question
Top Jet Plumbing Experts
Lawrence Oravetz
bobalix
Are you a Jet Plumbing Expert? Answer questions, earn points and help others
