Question about GE Refrigerators
GE Profile model# TCD18PADBWW timing switch reset button location
4 Suggested Answers
aasc
  • 1606 Answers
SOURCE: GE Profile model PFS22MISBWW stopped working, panel problem?
Replace the main control board on the back of the refrig . PT# WR55X10656 . It's behind a panel about 10" x 6" .
Posted on Aug 08, 2009
  • 415 Answers
SOURCE: GE Profile Side by Side water dispenser and ice
no by saying the imkr works sometime do you mean you runout of ice or is it when you try to get out of the dispenser only if the latter is more what is happening check the dispenser to ensure the type of switching you have on it is working properly
Posted on Aug 19, 2009
  • 288 Answers
SOURCE: GE Profile refrigerator temperature problem
refrigerators have 2 coils. the evaporator coil and the condensing coil. one is on the bottom of the fridg and one is on the back or inside behind a false panel. these coils must be kept clean or if the condensing coil cannot reject the heat absorbed by the evaporator, the box temp will stay high and if the evap coil cant absorb heat the box temp stays low running the risk of freezing
Posted on Nov 27, 2009
How to reset a button for a ge profile washing machine
Model # please? If it has a reset button, it would be clearly labeled on the console.
Nov 20, 2017 | GE Washing Machines
Ge profile oven lock button won't go off
  • 1.Press the "Clear/Off" button on the control panel to reset the oven. This will clear the lock setting and unlock the door.
    2.Allow the oven to cool to room temperature to avoid turning the lock on again during this heating cycle.
    3.Reset the oven to the temperature you require to finish cooking by pressing the correct temperature control on the control pad.
    or
  • 1.If your GE Profile microwave won't turn on, unplug it, then plug it back in. A power outage may have occurred due to a power surge. Check your home's fuses and circuit breakers.
    2.Set the clock of your GE Profile microwave. Certain models will not operate until you set the clock. Select the "Clock" key and type in the correct time.
  • 3.Hold down your microwave's "Off" button. You may have accidentally hit the control-lock feature on your GE Profile microwave. Hold down the "Off" button for three seconds to turn the lock off.
  • 4.If the sensors of your GE Profile microwave are not working correctly, remove the food from the machine. If the sensors detect food-surface temperatures over 200 degrees Fahrenheit, it will not work properly until the area cools down.
  • 5.Contact GE Support if you are unable to resolve the issue on your own. Call the GE Support hotline or browse the help library on the GE website. You can also schedule a service visit on GE's website.
  • Nov 22, 2011 | GE Profile JK915 Electric Single Oven
    I have a ge profile dishwasher model pdw9280j00ss. After a storm event, house lost power. Since that time, dishwasher constantly beeps; however has no power to it. shut off circuit, beeping stops; but...
    http://www.geappliances.com/search/fast/infobase/10000380.htm
    According to this link, it should reset after the power is shut off for awhile. Maybe try holding the start/reset button too. Also check the circuit breaker or any fuses
    Aug 28, 2011 | GE 24 in. Profile PDW9880JSS Built-in...
    Aug 07, 2009 | GE PDS22LBN Bottom Freezer French Door...
    GE profile performance dishwasher- not starting after child pushed buttons.
    The only way we have been able to fix this is to turn off the breaker to the dishwasher for 5 minutes and then turn the power back on. The dishwasher should reset.
    May 31, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
    GE: E Profile Single Electric Oven Model: JSP40W0WJWW
    First press and hold the cancel/off button for 10 seconds.
    If that does not work you have a bad thermal switch due to excessive heat buildup. Possibly a bad fan motor.
    The 2 thermal switches are located on top of the oven behind the control panel.
    Mar 18, 2009 | GE Profile JTP18 Electric Single Oven
    GE Profile WPRE6100G will not spin
    hi thanks for the question. i think the problem is with the lid switch . lifting the lid 10 times wont help if the switch is faulty check the lid switch thanks the appliance doc
    Sep 20, 2008 | GE Profile WPRE6100G Top Load Washer
    Buttons on Control Panel not working for my GE Profile Gas Range
    Anyone has any information as to how to fix my describe problem with GE Profile Gas Range I have.
    Thanks
    Mar 14, 2008 | GE Profile Spectra JGBP79 Gas Kitchen...
    GE Profile does not run.
    Just to be sure... check your owners manual to see if this unit has a "showroom switch". It's a little switch that turns off the compressor, etc. but lets everything else light up so the sales persono on the showroom floor can show it off. Some customers have hit the switch to "on" during cleaning by accident.
    Sep 29, 2006 | GE Profile PSS26NGS Side by Side...
    Refrigerators Logo
    355 people viewed this question
    Top Refrigerators Experts
    Sal DeAngelo
    Charles T Nevin
    Charles T Nevin
    Andrew Taylor
    Andrew Taylor
