Question about Brother IntelliFAX 1840C Plain Paper Inkjet Fax
Can I use my phone number as my fax number?
I have a Brother fax, copier, scanner, can I use my phone number as my fax number?
  • 62 Answers
Yes. Use a splitter. If fax has fax switch built in then fax calls should go to fax only and not phone. A fax switch can be fitted separately.
Posted on Nov 17, 2009
2 Suggested Answers
Soulvisitor
  • 1113 Answers
SOURCE: brother mcf-440cn
Jacki
 Must have DSL filter attached before fax, not sure how you are saying you have it setup, but phone line should come from wall then to filter then to fax socket marked line, phone should be hooked to socket on fax marked EXT, if you dont have dedicated fax line then fax number will be same as phone no.
If you have Adsl then there will be a lead from wall that splits into two, one goes to your modem (ADSL) and the other marke phone or line needs to go to fax socket marked LINE
Posted on Oct 21, 2007
Using a brother MFC-J415W printer, what are the steps in sending a fax?
How to fax :
1. Entering fax mode To enter fax mode press (Fax), and the key will glow green.
2. Sending a fax from the ADF (Automatic Document Feeder): Using the ADF to send your faxes is the easiest way. To cancel a fax in progress press Stop/Exit.
a. Make sure you are in Fax mode . b. Place your document face up in the ADF. c. Dial the fax number. d. Press Start.
The machine scans the pages into memory and then sends the document.
3. Sending a fax from the scanner glass : You can use the scanner glass to fax the pages of a book, or a single page at a time. The documents can be up to Letter or A4 size. Press Stop/Exit to cancel a fax in progress.
a. Make sure you are in Fax mode . b. Place your document face down on the scanner glass. c. Dial the fax number. d. Press Start.The machine starts scanning the first page.
For more detailed instructions, you can go directly to Section 4 - page 22 of the manual in Brother's site. Hope this helps.
Apr 14, 2011 | Office Equipment & Supplies
How can you use this fax machine as a scanner to view in PDF?
Brother Fax 2820 is fax/copier/printer. Can't use as scanner unfortunately
Feb 15, 2011 | Brother IntelliFax-2820 Laser Fax
How do i send a fax ? mfc-240c and where to insert paper.
To send a fax, you need to have a working phone line plugged into the jack on the left hand side of the printer. If you are faxing one page, place it on the scanner bed (the glass) and close the lid, then press the Fax function button, type in the phone number to fax to, and hit Start.
If you are faxing multiple pages, it is the same process, but instead of placing the paper on the scanner, you would place it in the document feeder on top of the printer, and each page would scan through individually. (Make sure none of the pages are stapled or paperclipped together.)
Dec 28, 2009 | Brother MFC 240C All-In-One InkJet Printer
Insstructions for sending a Fax on a Brother
You can find the entire user manual by clicking here:
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_240C_EN_249.PDF
Or, here are the instructions for sending a fax:
Entering Fax mode 5
To enter fax mode, press (Fax), and
The LCD will show the new job number and
the memory available.The number of pages
you can scan into the memory will vary
depending on the data that is printed on them.
Faxing from the ADF 5
a Make sure you are in Fax mode .
b Put the document face down in the ADF.
c Dial the fax number using the dial pad.
d Press Black Start or Color Start.
document.
Note
• To cancel, press Stop/Exit.
• If the memory is full, the fax will be sent in
real time.
Faxing from the scanner glass5
You can use the scanner glass to fax pages
of a book one at a time. The documents can
be up to letter or A4 size.
You cannot send multiple pages for color
faxes.
Load your document on the scanner
glass.
If you press Black Start, the
page. Go to step e.
If you press Color Start, the
machine starts sending the
document.
Do one of the following:
To send a single page, press 2 to
choose No. (or press Black Start
again).
To send more than one page, press
1 to choose Yes and go to step f.
Put the next page on the scanner glass.
Press OK.
starts scanning the page.
Dec 15, 2009 | Brother MFC 240C All-In-One InkJet Printer
Brother MFC 8440 Automatic Document Feeder doesent feed
Could be a sensor in the ADF, or the hinge on the left rear of the scanner cover is broken.
Jul 21, 2009 | Brother MFC-8440 All-In-One Laser Printer
Fax problems
I think you just not plugged with the phone/fax cord.
Please check the cord is connect or not.
Mar 16, 2009 | Brother MFC-7340 All-In-One Laser Printer
Can't send faxes
First disconnect the fax from the phone line. take regualar phone and plug into the wall outlet. dial thefax number. and listen for the the fax tone.
if the line is good. connected the fax and do the follwoing:
Manual Fax mode:
Press the fax icon (should turn green)
Load the document on the scanner glass.
Dial the fax number
press Mono Start.
if not, try to find a good phone line to use.
Feb 02, 2009 | Brother MFC 210C All-In-One InkJet Printer
I have just purchased a printer scanner copier and fax from argos where do i get my fax number from please?
Your fax number is the phone number of the line going into the fax machine.
Or do you want to input the phone number into the machine? In which case I would need to know the make and model number of the machine. But if its just the Fax Number, it is the Phone number of the incomming phone line.
Aug 12, 2008 | Brother Office Equipment & Supplies
Brother mcf-440cn
Jacki
Oct 21, 2007 | Office Equipment & Supplies
Brother IntelliFAX 1840C Plain Paper Inkjet Fax Logo
145 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
