Question about Samsung HT-DB120 System
HT-DB120 WHEN EVER I INSERT A CD THE SCREEN REASA LOADING AND AFTER A COUPLE OF SECONDS IT STOPS LOADING, THE SCREEN READS OPEN, AND THE TRAY COMES OUT. I HAVE NO PROBLEMS AT ALL WITH IT PLAYING DVD'S
  • KISHAD Jan 10, 2008
    REGULAR MUSIC CD
  • KISHAD Jan 11, 2008
    THE CD IS A REGULAR MUSIC CD. THE CD PLAYER USED TO WORK PERFECT UNTIL JUST RECENTLY
    Genius:
  • 1,067 Answers
What brand cd is it is it in right formatt or just reg music cd
Posted on Jan 10, 2008
My dvd player tray does'nt open when it should and when i insert a disc to play, it only plays for a few seconds then it stops but the disc continues to spin
Hello
The laser pickup unit of your DVD player may either be faulty or dusty. Just put in a cleaning disc into it and play it for at least three times, and check. If it does not help you, the laser pickup unit of your device should be replaced with same type and number. Just check the loading belt too. OK.
Dec 16, 2011 | Zenith XBV443 DVD Player/VCR
I have a samsung home cinema systems HT-DB120,and eveytime i go and turn this on it cames up protected, then 2 seconds and turns off.
Assuming you did NOT modify the speaker complement...
Generally speaking, an amp protects itself from heat, shorts and overloads by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections as a root cause for intermittent shutdown.
Feb 27, 2011 | Samsung HT-DB120 System
Why does the Samsung Home Theater DVD player display the word PROTECT then does not work?
if the speaker connections are not properly or anything wrong in dvd drive it goes in protection mode.remove all the speakers and insert the cd and see if it works with headphones. if it works check all the speakers one by one
Jun 04, 2010 | Samsung HT-DB120 System
I have an RCA DVD/VHS combo with TVG. The DVD
This is a work-around rather than a solution. We put an audio CD in the tray and after closing the tray the unit begins to play the music. After waiting a few seconds we open the tray and quickly substitute a DVD and it loads OK. We had also tried cleaning the player to no avail. The CD approach is a pain but it does allow us to play DVDs. Jim
Jan 15, 2010 | RCA Televison & Video
Recording trouble
Hi again,
I understand. Must be a glitch somewhere. Anyways, I already posted possible solutions here your original posting/problem. They were:
1. Power on the Philips FW-R7, leave the left tray empty and closed. Open the tray and put in a recorded CD (not a CDR but a regular CD from your music collection), close the right tray. Wait a couple of seconds as the FW-R7 reads the CD. Now open the tray, remove the music CD and insert your CDR. The FW-R7 should read the CDR without the error message and record to the CDR from any source. Let me know if this works for you;
2. laser cleaning or realignment (would need a service center);
3. try using lower then 40X blank CDs.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 18, 2008 | Philips FW-R7 CD Shelf System
Door tray will not open and screen reads loading but no disc is in
sounds like your system needs maintenance cleaning dust or some debry has been clogging tray gears have profesional clean out and regrease gears for proper use again
Jun 01, 2008 | Samsung HT-DS610 System
Heed to unlock an samsung dvd ht-x30
1. Remove Disc from Tray.
2. Switch Off Player
3. Wait 30 Seconds, Then Reconnect Mains.
4. Turn On player with Remote Control. Wait for player to Finish Loading and Display 'No Disc'.
5. Press Enter on Remote Control. (There will be No On-Screen Response.)
6. Press 8, 4, 2, 6, 9 on the remote. (There will be No On-screen Response.)
7. Press Enter on the Remote Control. Player will Automatically Turn Off.
8. Turn Player On.
9. Open Tray
10. Close tray.
11. Turn Player Off then On Again.
12. Player is Now Region Free
May 05, 2008 | Televison & Video
Samsung HT-DB120 DVD tray
I assume it DID work at one time. You need to take it apart and see how the tray is driven... belt or gear. If belt driven you could replace the belt.
Geno
Mar 04, 2008 | Samsung HT-DB120 System
PROTECTION
See my post "HT-DB120 - PROTECTION due to shorted output stage "
Jan 02, 2007 | Samsung HT-DB120 System
Protection displayed on screen
Nov 08, 2005 | Samsung HT-DB120 System
Samsung HT-DB120 System Logo
118 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
