Question about KitchenAid Dishwashers
I have a kitchenAid dishwasher and am getting a humming noise. it fills with water and will drain when you hit cancle. i think there might be something in the pump how can i access it to find out. is there any other things i can try. I have added CLR to try and brakfree any gunk thoughts
  • mike_ciemieg Nov 17, 2009
    how do i access it? i looked at the inside of the washer and found that there was no gunk in the masorator
  • 72 Answers
The motor is stuck free it up manually
Posted on Nov 17, 2009
Kudi01tj
do you here a hum noise ? trying putting some water in the unit and strat it to see if the motor is running if that works then you have a problem in the fill components there is also a float in the front corner and it might be stuck up
May 24, 2014 | Dishwashers
Kitchenaid kuds02frss1
The wash pump and drain pump are different. So it is likely the wash pump is choked and trips or the motor is faulty.
http://www.searspartsdirect.com/partsdirect/part-model/KITCHENAID-Parts/Dishwasher-Parts/Model-KUDS02FRSS0/0593/0130000/W0602076/00008?blt=06&prst=&shdMod=#
It is likely the flap valve (item 5) or the chopper (item 6) are damaged and could be replaced before you get to the wash motor.
Apr 17, 2014 | Dishwashers
Dishwasher starts then pauses and drains.
Fixed! I had the issue where the cycle would start, the KUDS30IXBL8 would hum 4-5 times and then drain. Plastic folk pieces jammed in the disposer. These instructions took a few minutes (only 5 screws and a couple clips) to figure out how to take it apart, and it only took 60 seconds to put back together. How To Repair Dishwashers KitchenAid Repair Chopper Replacement
Apr 25, 2012 | KitchenAid Dishwashers
KUD 101 JBL0 kitchenaid dishwasher fills with water then just hums. When I hit the cancel/drain button the water does drain.
Before you go ordering any new parts, have you made sure that the dishwasher is LEVEL. Surprisingly this is a very finicky thing with dishwashers and I even went as far as replacing my float switch before realizing that the dishwasher was slightly out of level. Once I straightened it out the dishwasher was totally fine. Just to be sure, I skewed it in another direction and had the same problem. Like I said, give it a try (front to back AND side to side) and you might be in luck!
Jan 04, 2012 | KitchenAid 24 in. KUDI01FLSS Stainless...
The dishwasher fills with water but then hums. Water will drain if cancel button is pushed.
Sounds like something stuck in spray impeller. Remove spray arm and top of motor pump assembly and clean.
Oct 27, 2010 | KitchenAid 24 in. KUDS01FLBL Built-in...
Kenmore elite not washing dishes
Sounds like the motor is stuck. If your careful you can unplug the dishwasher or turn the breaker off, take the bottom panel off and reach in with your finger and spin the motor assembly.
Nov 12, 2009 | Dishwashers
Maytag quiet 300 series
The most common solution to your problem is replacing a failed main wash motor/pump.
Without the model number, I can't point you to the correct model number.
Be aware that replacing a wash motor is not a trivial task and most households hire a service tech to do the job.
Good Luck!
Feb 01, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Kitchenaide KUDM24SE1 dishwasher will not fill with water
It may be the water inlet valve or the electronic control board. To check, remove the bottom toe panel. The valve will be on the left side. There will be live power, so use extreme CAUTION. Start the DW, 1. if you can hear the valve humming or the valve coil is getting warm, replace the valve. 2. Using a device with wires to check the power at plugs, connect to valve power connection, if power is present, replace valve else replace electronic control board.
Jun 07, 2008 | KitchenAid KUDM24SE Built-in Dishwasher
Dishwashers Logo
134 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
