Question about Dell 3010cn Laser Printer
Can't shut back reg cover 077-301 . Something seems to be blocking...won't shut!
  • linda_m_carr Nov 17, 2009
    This may be correct. What I had to do was move the machine forward so that I could open the door all the way, then after it was opened all the way, I was able to close the door without any problem.
  • 62 Answers
If I remember correctly, there is a guide that allows the print to exit through the back of the machine or up, over and on the top of the machine. That guide may need to be clicked into place before the main back cover is shut.
Posted on Nov 17, 2009
Unit comes on but seems to be stuck on drain cycle. Have had unplugged for day and tried to start a load and still sounds like its trying to drain, door won't lock, and unit won't shut off...
Good evening
Have you had a look at the manual?
Could a fuse in the machinery have blown?
seems to me that here is something to do with the electronics that is not functioning as it should.
Kolbrun
Feb 26, 2012 | Whirlpool Washing Machines
The back of my timex fell off when i was putting it on this morning. I can't seem to get it to go back on. Please advise.
hello there are alot of watches that have a very tight snapon back, some times just squeezing the back cover with your two thumbs just won't do. some back covers are tapered so as to ensure an air tight seal. Do Not lay crystal face down and try to force it on with heavy pressure. you run the risk of cracking the crystal, Hence NEW WATCH TIME. take the watch into any jewelry store they have tools to do this with without harming the watch. wood blocks with cutout holes , so the bezel rests on the wood and not the crystal. it take ten seconds and they will do it free. hope that was helpful
Aug 24, 2011 | Timex Watches
LG RH2T80 HDD/DVD recorder dvd tray won't shut we have turned off the power and at the power point but it still won't shut. It sounds like something is locking or jaming. It goes a 1/3 of the way...
This is a common problem on this model LG RH2Txxx DVD Recorder unit.
Source and install a new DVD player/burner unit - cost approx $120.
Avail from :- http://spares.bigwarehouse.com.au/product_info.php?cPath=24759_24831_81108&products_id=1546447&s=lg%20rh2t250&n=1&pcid=2274323
Easy to self instal with basic repair knowledge (+ philips screwdriver).
Remove top cover screws and cover,
Unclip front plastic front cover, roll out of way,
Remove 4 mount screws of DVD player/burner unit,
Unplug ribbon cable and DC power connection to DVD unit.
Install new unit by reverse of above procedure.
Jun 04, 2011 | LG DR787T DVD Recorder
I have a propane fireplace and the pilot flickers when burner is on and flame on burner seems low. I have filled the 100 lb tank, but problem still persists. The pilot used to flicker and go out when...
sound like a pressure problem low gas , check burner is not blocked , check vent on reg is not blocked, check gas line is not blocked , if all this is working then it could be your reg not working
Jan 22, 2011 | Heating & Cooling
I have the Dell laser printer 3000cn. The printer powers on and everything but I can not do anything because it keeps asking me to close the reg cover. ther reg cover and all the other covers on the...
Dell 3000cn Color Laser has a duplex. If you face the printer on the top right of the duplex there is a button to release the duplex and it folds back. The reg cover is a door on the back of the printer that is covered by the duplex, try opening again, I know you have done this, maybe even wiggle it a little see if it registers as closed.
Also check to see if any dust or paper pieces maybe be jammed in there.
Nov 02, 2010 | Dell 3000cn Laser Printer
Blower
something blocking the air off this is why its blowing smoke
Jan 29, 2010 | Reddy R115DT Oil Filled Utility Heater
Gets warm. Shut it off and reset it will work for a couple days.
It could very well be the start relay or capacitor. It also could be the compressor is wearing out. Unplug, remove cover on compressor wiring and mark the wires going to compressor. Take the capacitor to a refrigeration store or have someone check the capacitor. You also could replace the capacitor and start relay with a three in one relay and capacitor combined, that is rated for a refrigerator the size of yours. Get back with me when you find something, Thanks, Sea Breeze
Mar 23, 2009 | KitchenAid KTRC19MKSS Top Freezer...
I can't get the cover back on
the plastic part that you are referring to is the lock or bracket that the door needs to lock into to and then it should swing shut. make sure that the filters are snug in there and not blocking the way of the door shutting cause that can cause things not to work right. if you have any other problems please let me know and i'll see what else we can do.
Sep 13, 2008 | Holmes Products HAP726-U Air Purifier
Black square on one channel
that's a picture inside a picture option, and it sounds like the inside picture is set for a blank channel...just go to the menu, and shut off the picture in a picture option..should do the trick..
and keep the kids away from the machine
May 24, 2008 | Insignia IS-LCDTV32 32 in. Television
Roller Fell Out (with my help)
Pick up the printer, lay it on its front and close the reg cover. Simple as that but it took me ages to figure it out!!!!
Jan 22, 2008 | Dell 3100cn Laser Printer
Dell 3010cn Laser Printer Logo
388 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
