Question about D-Link AirPlus Xtreme G DI-624 Wireless Router (DI624RE)
Need to find the sotware to my DI-624s router . Can not get it to work with my pc. I know this device has been descontinued and im unable to find the sotware anywhere online. What other options do i have IT IS A D-LINKS ROUTER
  • 2,260 Answers
Who is your ISP ? If you connect the computer to the modem , does it work ? If that works then you can set u0p router without the CD or any software. You can set up router manually. You will need to access the router set up. Click Here for step by step solutions
Posted on Nov 17, 2009
Repetitive disconnect problem....requires powering off & on to reset
I used a D-Link Di 624 for a number of years with Comcast and never had a problem with the router, but I did upgrade the firmware. You may want to look at the following items from D-Link about the DI-624S and see if you can find a better solution. I took the router out of service as I changed to Verizon FIOS and use their provided router.
See: http://www.dlink.com/support/faq/default.aspx?question=DI%20624S&page=1
Dec 06, 2010 | D-Link AirPlus Xtreme G DI-624S Wireless...
I'm trying to set up 2 computers in a wireless network. I have a D-Link DI-624 router. Where do I plug in the flash drive on the router?
Hi norman66, the wireless flash drive you connect to the computers that do not have a wireless card, not the router. First install the CD on the computer and then insert the usb device.
I hope this helps. Please do not forget to rate and provide positive feedback for our fast free support today. Thank you :D
Apr 30, 2010 | D-Link AirPlus Xtreme G DI-624S Wireless...
Router will not work wirelessly
Reset your router via the recessed reset button on the back, this should reset your router back to factory default settings.
Login to the router and reconfigure as needed.
Good luck, God bless
-Carlos:
Jun 17, 2009 | D-Link AirPlus Xtreme G DI-624S Wireless...
Printing with Dlink DI-624S and VPN connection
I am guessing this VPN is something work related and not a VPN you setup yourself?? If that is the case your company's VPN access will not allow you to pass from there network back to yours which is why you are unable to print to your local home printer when connected to VPN. You might could run it by your IT staff and see if they will allow connection and help you set it up. If not then simply email the docs to yourself and then print them out after you are finished using VPN connection.
Hope this Helps
TankMurdock
Jan 24, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
Using DI-624S ... VPN works fine through CAT5 but not wireless
I resolved my issue by updating the DI-624s firmware.
regards,
boreeeeec
Jun 09, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
DLink DI-624s - can't get Cisco VPN Client to connect.
The "Virtual Server" setting is designed to give the general public access to a network resrouce (web/ftp/media server) on your internal network. If your the VPN concentrator is external to your network (meaning you'll have to use the internet to connect to it), then you won't need to define a virtual server on the DI-624.
You'll just need to enable the IPSEC and PPTP VPN Passthrough which it sounds like you've already done this. I've run into some ISP's that block VPN connections out of their network. If you have the ability, try to directly connect your laptop into your cable/DSL modem in place of your router and see if you can make a VPN connection, if not contact your ISP, if you can then verify you enabled the VPN passthroughs because your router is blocking them.
GIve it a shot and let us know your results.
Apr 26, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
DI-624s
That sucks... we need more info before we can try to help though.
Sep 09, 2007 | D-Link AirPlus Xtreme G DI-624S Wireless...
UPnP?
This FAQ is for the DI-514, DI-524, DI-604, DI-614+, DI-624, DI-624S, DI-714P+, DI-754, DI-764, DI-774, DI-784, DI-804HV, and DI-808HV. Universal Plug and Play (UPnP) allows discovery of UPnP enabled devices in a network environment. UPnP is only available on Windows Me and XP. If you are not using either operating system on any of your computers, or do not want to use UPnP, then it is recommended to disable UPnP on the router. Step 1 Open a web browser and type the IP address of the wireless router in the address bar (default is 192.168.0.1). Press Enter. Step 2 The default username is admin (all lower case) and the default password is blank (nothing). Click OK. Step 3 Click the Tools tab then click Misc. to the left. Step 4 Under the UPnP Settings section, select Enabled using the radio buttons to enable UPnP on the wireless router, or select Disabled using the radio buttons to disable it. Step 5 Click Apply and then click Continue to save the new settings.
Feb 16, 2006 | D-Link Air Xpert DI-774 (DWL-774) Wireless...
Forgot my password
The following reset procedure will completely restore the default settings on your D-Link device including your password. This procedure applies to the DI-514, DI-524, DI-604, DI-614+, DI-624, DI-624M, DI-624S, DI-754, DI-764, DI-774, DI-784, DI-804V, DWL-700AP, DWL-800AP+, DWL-900AP+, DWL-1000AP+, DWL-2000AP, DWL-2100AP, DWL-6000AP, DWL-7000AP, and DWL-7100AP. Step 1 Locate the reset pinhole on the back of the unit. Step 2 With the unit powered on, press and hold the Reset button. Step 3 Hold the Reset button for about 10 seconds. Step 4 Release the Reset button. Step 5 The unit will reboot. Allow 20-30 seconds before reconnecting. Step 6 The device is now at factory defaults. Note: Do not recycle power during the reset procedure. The default user name for most D-Link devices is admin and the password is left blank.
Feb 16, 2006 | D-Link AirPro DI-764 Wireless Router
Forgot my password
Feb 16, 2006 | D-Link AirPlus DI-614+ Wireless Router
D-Link AirPlus Xtreme G DI-624 Wireless Router (DI624RE) Logo
91 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
