Question about Ovens
Magic chef digital clock beeping showing F 1 on display
  • 72 Answers
It is ocerheating replave temp sensor
Posted on Nov 17, 2009
Why does my magic chef oven, model 34HN-3TKXW, keep beeping and sowing -f1-
Your clock has failed and would need to be replaced, part number is 7601P155-60 but I was unable to find one for you. Maybe you will have better luck. Common rule is after 8 years they stop production of parts so I hope you get lucky in your hunt. Good Luck
Aug 06, 2014 | Magic Chef Ovens
C clock will not stop buzzing. 15 year old magic chef oven. do not know model number because manual does not identify it. the only thing I have is a number at the bottom of the installation manual. Not...
Beeping from ovens is an indication of function buttons in user. Observe the entire feature function either as cooker still in operationality where beeping is warning as haven been completely secured from functionality. Refer with an expert with condition over impressive.
Mar 01, 2011 | Magic Chef Ovens
I wanted to change the time hour. I pushed clock and up arrow at a time and the clock is showing 5 AB. The screen is frozen. I can't use any options. How could I get it back to normal? Thank you for your...
To
provide sabbath feature (or to cancel this setting):
1. Push the PREHEAT pad and set the oven
temperature to 500°F/260°C or more using the UP
ARROW pad.
2. Push the PREHEAT pad within the next 2 seconds
for 3-4 seconds. A beep sounds and a number
appears in red to the right of the display. For the
conversion, "3" must be displayed. If another number
is displayed, push the PREHEAT pad and select
"3".
3. Push the UP or DOWN ARROW pad to change
from 12 hour to 9999 in the display, for no 12 hour
shut-off.
4. Push the CANCEL pad to confirm your choice.
Other Displays:
When proceeding through steps 1 and 2 in the
Temperature Scale Conversion or in the elimination
of the Sabbath feature /12-hour Shut-off time limit,
two other words can be seen in the display. One is ESC
with O in red. It cannot be changed. The other is USE or
SALE with 3 in red. This one is for factory use and should
stay on USE.
Nov 20, 2010 | Magic Chef 9112 Gas Double Oven
What does F1 mean when appearing in the digital display area accompanied by beeping? This is appearing repeatedly every few hours even when stove not in use.
Hello,this indicates a ERC/clock electronic range control fault.
Check or replace the touch pad or clock. The touch pad is a more common problem for this unit. Check for a stuck button by pressing each one and feeling for it retracting. This is easy to replace.
Thanks
Jun 10, 2010 | Magic Chef 9122 Gas Single Oven
Our magic chef oven starts beeping and gives us a F1 on the display
f1 indicates a shorted touch pad ,if you want to make sure ,unplug unit ,disconnect touch pad from computer board ,if f1 goes away touch pad is bad.if not replace board
Sep 13, 2009 | Magic Chef 9815 Electric Single Oven
I oven is showing -F7- what is that
You have a function key stuck or shorted. Replace touch pad or if touch pad is part of the clock, replace the clock (ERC).
Regards, --W/D-- Please feel free to rate this solution! Thanx!
Jul 31, 2009 | Magic Chef Ovens
F 1 beeping on Magic Chef oven ?
The F1 code is a defect touch pad or membrane
May 01, 2009 | Magic Chef Ovens
Contune to beep F-1 flashes
f-1 codes are usually a temperature issue. you should try ohm'ing out the temperature probe you should have about 1260 ohms. if you are off by 40 ohms then replace the temperature probe. if it is close then you may have a bad control.
Dec 01, 2008 | Magic Chef Ovens
Magic Chef Oven
An F1 usually suggest a defective touch pad (The keys get stuck sometimes because long use or "over pressing" or poking it with things like knives and such). If its a unit with seperate touch pad and clock (controller) changing the touch would be enough othewise the whole controller has to be replaced. You did not give a model number so not able to give an exact price. But it should be in the region of $120 - 230 depending on the model you have
Regards
Sep 04, 2008 | Ovens
"F1" error code on Magic Chef gas range Model 3488XRA
the burners on my magic chef stove work but the flame is not as high as it should be on one burner. I switched the top of the burner with another and it did not solve the problem.
Jan 03, 2008 | Whirlpool 30" Self-Cleaning Freestanding...
Ovens Logo
47 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
