Question about Grundig YB 300PE AM/FM/SW Radio
Radio shuts down
Radio powers on but shuts down after a few min. Can't find anything in manual to help with the setting mistake. Have reset in battery compartment and have new batteries.
  • katti Jan 10, 2008
    Thanks for the quick response. Actually, I can't locate the cord at present. I just changed to new batteries and now the radio won't power on. I reset again in battery compartment. Given a little time I can locate the cord, but can we address my new problem of a dead radio?
  • 233 Answers
Does it shut down with the AC adaptor pluged in and no batteries?
Posted on Jan 10, 2008
  • Pedro
    Pedro Jan 10, 2008
    I know of other users that had the same problem BUT only with the battery power... I would inspect the battery contact in the compartment maybe bend them a little so the batteries fit in tighter.
    if it works with the power cord then we know the radio is ok and it's probably something with the battery contacts
    Hope this help
Can I reset the computer of my Audi A4 cabriolet B6 model,if yes ,what is the procedure.
Which computer (module) are you referring to?
Generally: disconnect the battery for 20 min. This often helps to reset the modules (computers).
Note: if not done, you should look for the radio code. Originally part of the paperwork that came with the car (often a rip out card in the operator manual). Some write it down in the manual. If the radio is without power for a long time, it may be required to enter the code again. If code is not available, the dealer can look it up by VIN number and serial number of the radio (need to remove radio typically to get the serial number).
Jan 12, 2017 | Audi A4 Cars & Trucks
If I turn off my trailblazer and put the key on accessory after 20 min my radio was still on My owners manual says I have retained accessory power but it is not working please help
On GM products, usually the radio will stay on (even with key off) until you open the drivers door. Maybe your drivers door ajar switch isn't working properly. Also try disconnecting the battery for 5 minutes and see if that helps to reset anything.
Oct 15, 2015 | Cars & Trucks
My lights got left on and ran my battery down. Now I got it started and my radio will not work. It doesn't do anything how do I get it to come back on and is there a lock code?
Your radio has an anti-theft devise that shuts the radio down if the radio is stolen(when the power is lost). You will have to have the anti-theft code reset by a dealer. There is nothing wrong with the radio.
Aug 26, 2010 | 2007 Chevrolet HHR Special Edition
Please i need help with 2001 montero sports radio
if you put in wrong code 3 times the radio will shut down for a few hours will not let you do anything try again the next day
Mar 31, 2010 | 2001 Mitsubishi Montero
I have a renault scenic 2000, replaced battery need to input the radio code, noticed on this blog that you can push numbers 2, 5 and on button, I did this and my radio came on without me having to inp
Some radios hold the codes for a few Min's.However ,Disconnect the battery again and leave disconnected for an hour.Then reconnect and Enter codes and confirm.Should work ok.
May 29, 2009 | 2000 Renault 181
Radio wont' shut off when drivers door opened
Try a window ,see if they still work too . RAP relay supply's power for radio windows etc. when key is turned off for ten mins or till a door is open .
Jul 24, 2017 | 2008 Chevrolet Equinox
Resetting Radio with WAIT on an 01' Ml 320
I've entered incorrect radio code and it is now stuck on WAIT. but i don`t have the code what can i do. pl. help me
Mar 01, 2009 | 2007 Mercedes-Benz ML320 CDI
Times Indiglo Nature Sounds Clock Radio T466W
Go to timexaudio.com, select SUPPORT, then select PRODUCT MANUALS.
Nov 19, 2008 | Timex T276B Clock Radio
Cuts off
This is simply a low battery issue. If you replace the batteries it should work. Apparently, the unit has a voltage sensor that cuts off the radio when the voltage drops too low. However, eventhough the radio will not run, there is still sufficient voltage left in the batteries to run the light.
This is why the radio will run when plugged into AC.
Hope this works for you !!!!
Jan 19, 2008 | Grundig YB 300PE AM/FM/SW Radio
Emerson Smartset Clock Radio
For the Clock/Radios that are having problems with the clock display and settings. You will have to reset the Clock/Radio's microprocessor. To do this you must unplug the Clock/Radio from the wall outlet and remove the internal battery. You must let the Clock/Radio set with no power for at least 1 hour to discharge the microprocessor circuits. The microprocessor should then be able to reset itself. You can then reinsert the battery and plug the Clock/Radio into the a/c wall outlet. The functions should have reset and be working normally. If this does not solve the problem, try putting in a new battery (CR2430). Before putting in the new battery, unplug the clock radio and remove the old battery and let it set again for a few hours this time to try to reset the microprocessor. If this does not solve the problem (This includes the person with the complete Clock/Radio operation failure) you can call the Emerson customer support at this telephone number 1-800-898-9020. Give them the make and model number of the Clock/Radio. Tell them the problems you are having with the operation of the Clock/Radio and ask them for assistance. I hope this information helps you solve the problems your are having with your Clock/ Radios.
Dec 17, 2007 | Emerson Smartset Clock Radio
Grundig YB 300PE AM/FM/SW Radio Logo
259 people viewed this question
Top Grundig Audio Players & Recorders Experts
k24674
xxxxxx xxx
Are you a Grundig Audio Player and Recorder Expert? Answer questions, earn points and help others
