At boot up my Dell Inspiron 8000 laptop gives a "Memory write/read failure" error message and will not continue booting. How do I solve this error and boot the laptop?
    President:
  • 2,049 Answers
This error is described by Dell as follows: "Faulty or improperly seated DIMMs or defective system board."
Let's hope the RAM (memory) is the issue as a system board would be very expensive.
The easiest check is to "reseat" the DIMM modules. Try removing and the memory and putting them back. If that doesn't work, the next solution would be to take the memory modules to a reputable computer repair center and have them checked. If faulty, replace. If not, it would indicate a motherboard issue.
Follow this link to Dell's instructions on removing and replacing DIMM modules...
http://support.dell.com/support/edocs/systems/ins8100/en/sm_en/remove.htm#1075961
Posted on Nov 17, 2009
  • 2,418 Answers
Check your memory, On the bottom of the computer is a small door to access the computer main memory. Check to see if it is not knocked loose - reseat it. and then it may be bad -and will need to replace it.
Dell Inspiron N5010 4 beep error
This may help. The 4 beep code error in Dell Inspiron N5010 mean Memory read / write failure. Try draining the residual charge and check if you are able to boot. Here are the steps:
  • Disconnect any external peripherals (flash drives, printers, external hard drives) from the computer including the battery and AC Adapter.
  • Press and hold the power button for 20 seconds.
  • Reconnect the battery and the AC Adapter. Try to restart the computer and check.
Please make sure that the memory modules are firmly reseated and there is no dust accumulated on the memory slot on motherboard.
May 20, 2014 | Dell Inspiron Computers & Internet
Why does my dell inspiron m5030 laptop give me a series of 5 beeps and wont boot when I try to turn it on?
Please read this:
DELL BEEP CODES
Beep Codes Beep Code Description Failure Coverage 1 System Board: BIOS ROM failure System Board, covers BIOS corruption or ROM error 2 Memory No Memory / RAM detected 3 Chipset Error (North and South Bridge Chipset DMA/IMR/ Timer Error for Intel platform); Chipset Error System Board Chipset Failure Time-Of-Day Clock test failure. Gate A20 failure Super I/O chip failure Keyboard controller test failure. 4 RAM Read/Write failure Memory failure 5 RTC Power Fail. CMOS battery failure 6 Video BIOS Test Failure Video card / chip failure 7 CPU Cache Test Failure CPU failure 8 LCD LCD failure
Jan 12, 2013 | Dell Inspiron M5030 Laptop
Dell inspiron beep codes
These are the Dell beep codes.
DELL BEEP CODES
Oct 11, 2012 | Dell Inspiron M5030 Laptop
Boot error "Remove disks or other media"
Set the hard drive to boot first, I find this fixes most boot errors.
Jun 07, 2012 | Dell Inspiron N4010 Notebook
When I started my DELL Inspiron 1525 running Win 7 Ultimate, I got a white-on-black screen which questioned the voltage from power adapter. Diagnostic program run.. Stopped with the following msg: Error...
2000-0142 and 2000-0146 are hard drive SMART errors, indicating the HDD will fail.
To boot message about the AC adapter was a BIOS level message that normally appears when a Auto/air ac adapter or other 65 watt ac adapter is used to power the system.
Jul 16, 2011 | Dell Inspiron 1525 Laptop
Inspiron 531s will not boot up, keeps beeping, saying it is in power save mode. How do I fix the problem
System Beep Codes The Inspiron™ 531 / 531s system can emit a series of beeps during start-up if the display cannot show errors or problems. These series of beeps, called beep codes, identify various problems. One possible beep code consists of repetitive three short beeps. This beep code indicates the computer encountered a possible system board failure.
The series of beeps has a 3-second delay before it repeats. The series and delays continually loop until you press the power button.
Code Description Suggested Remedy 1 BIOS ROM checksum in progress or failure System board failure; covers BIOS corruption or ROM error 2 No memory modules detected
  1. If you have two or more memory modules installed, remove the modules, reinstall one module, and then restart the computer. If the computer starts normally, reinstall an additional module. Continue until you have identified a faulty module or reinstalled all modules without error.
  2. If available, install a good memory module of the same type into the computer.
  3. If the problem persists, contact Dell.
3 Chipset error (North and Southbridge chipset, DMA/IMR/Timer Error for Intel® platform); chipset error System board failure. Power LED is blinking amber. Time-Of-Day Clock test failure Gate A20 failure Super I/O chip failure Keyboard controller test failure 4 RAM read/write failure
  1. Ensure no special memory module/memory connector placement requirements exist.
  2. Verify the memory modules you are installing are compatible with the computer.
5 Real time clock failure. Possible battery failure or system board failure.
  1. Replace the battery.
  2. If the problem persists, contact Dell.
6 Video BIOS test failure Video card failure 7 CPU cache test failure Processor failure
Oct 06, 2010 | Dell Inspiron 531s Desktop Computer
Memory write/read & address line failures on Dell Inspiron 1525
you may need to format that memory because it may be corupted.
Jul 17, 2009 | Dell Inspiron 1525 Notebook
Dell inpiron 1535 laptop - memory write\read failure
memory write/read failure at 14020058,read ED22ED02 expecting ED02ED02
decreasing available memory
Apr 08, 2009 | Dell Inspiron 1525 Notebook
48 people viewed this question
jasbo
jasbo
