Question about Kenmore 24 in. 15932 Built-in Dishwasher
Help My Kenmore ultra wash quiet guard 1 dishwasher door will not open. There is power. All the cycles work.
  • dakota4v Jan 27, 2008
    Tech 17, we ended up busting the handle and entering thru it there was no other way to access it. Now it opens. Thanks for help
  • Anonymous Mar 24, 2014
    Frigidaire precision wash shstem ultra quiet dishwasher
  • 1,314 Answers
Wow that could be a tough one there is no door lock on a dishwasher only a door latch what happens when you depress the door latch and can you send me a model number so i can pull up the blue prints and see if we can figure out a way to open it try pushing on the door and depressing the latch at the same time let me know what happens
Posted on Jan 10, 2008
  • robert samples Jan 27, 2008
    well actually there was i found it for you if you want to send me an email ill send you the diagram for the future
Kenmore Ultra Wash Dishwasher door won't open
It seems most likely door latch stock and you going to need buy new door latch as for stock one most likely you hsve to forceit to open and replace it with new one
Dec 09, 2013 | Kenmore Dishwashers
Could you please help diagnose problem...dishwasher consistently stops washing in the middle of wash/sensing cycle. 2005 Kenmore Ultra Wash Quiet Guard 3
most likely the water is not hot enough,,it trying to heat the water,,when it starts to sense open the door and just test the water,,careful may be hot ,,but i doubt it...another easy way to tell is what is your hot water heater set on,,if you have a lot of soap residue is a good sign..
Sep 02, 2011 | Kenmore Dishwashers
I have a Kenmore Quiet Guard 2 (model 16994400) and the soap door doesnt open during the washing cycle.
There are three common problems that cause the Soap Dispenser or Cup not to open. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem
Detergent Cup does not Open
Jan 05, 2011 | Kenmore 24 in. 15932 Built-in Dishwasher
My Kenmore Ultra Wash Quiet Guard
take kick plate off get book out how to reset board
Apr 24, 2010 | Kenmore 15899 Built-in Dishwasher
Soap dispenser will not open during was cycle.
Probably a faulty solenoid on the dispenser. Not replacable new dispenser needed
Jan 20, 2010 | Dishwashers
Loud Buzzing Sound from Dishwasher
have you ever seen green led "Clean" light flashing? before or about the same time the buzzing sound started? and if so that would indicate that the control senses a fault in the temperature rise during the heating cycle and that the electronic control could be reset by initiating a service diagnostic cycle.(which is what you were trying to do) pls reread your manual there are times during that sequence that some buttons have to be pushed at the same time and within a certain amount of time..possible that your machine also has a bad timer which would give you a buzzing noise..if thats the case I would recommend replacing the cpu or control board..or the machin all together..The Kenmore Ultra Wash Quiet Guard name is sears but whirpool has the contract to produce all "kenmore products.hope that helps.
Jul 30, 2009 | Dishwashers
Smelly dishes from Kenmore Ultra Wash
If you post the model number of your dishwasher plus its approximate age (in years) I can help more.
But the most common cause is a weakening pump motor. On many dishwashers, the wash pump motor is also the drain motor. Replacing that motor / pump assembly will solve the problem. While you are replacing the pump, check the heating element to confirm that it is not shorted out or broken.
For now, add a cap full of bleach to the water _after_ the initial dishwasher fill cycle ends and the wash cycle begins. White vinegar would also work, but this will not fix your problem.
Good Luck!
May 04, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Suddenly stopped working - won't run on any cycle.
First check the electrical supply. I have seen dozens of dishwashers which did not have the hot wire connected tightly enough (inside the connection box behind the lower panel). Sometimes the loose wire caused the breaker to blow. If you have control lights but the dishwasher will not start it could be a bad door latch saftey switch. $10 part, cheap. Hope this helps, Ken
Apr 24, 2009 | Dishwashers
How do I acess the control panel
Open the door and remove the top screws connected to the console. Close the door (not locked) and flip the console down toward you. Remove the control cover to gain access to the control board and the thermal fuse.
Mar 06, 2009 | Kenmore 16602 / 16604 / 16609 Built-in...
Kenmore 24 in. 15932 Built-in Dishwasher Logo
264 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
