Question about Cell Phones
Any idea to troubleshoot the antenna of 7610, or make a jumper for it?...
Motherboard msi 7610 ver 2.1
To reset the motherboard: set the dipswitches at OC_SW1 to ON-OFF-ON, then clear the CMOS Ram by setting the jumper at JBAT1 to pins 2&3 while the power is OFF. Wait fifeteen seconds,Then return the jumper to pins 1&2 and turn the power on. This will re-set you to the factory defaults. You will need to enter the BIOS and re-configure your hard disk. The manual can be downloaded at ECS's website at: http://www.msi.com/product/mb/P41TC31.html#/?div=Manual
Apr 18, 2014 | MSI Ms-7610 P41t-c31 Motherboard Intel G41
My nokia 7610 light on the keypad no light on the screen
how to use a jumper? my nokia 7610 has a keypad problem, it had been repaired once, but it came back.. then later after i had just checked it without doing anything on it, it happened that the light went low and there's no more display on the screen..
kindly help me :( if there is a solution for this before i'll bring it to a cellphone repair shop.. so i can have lesser expenses..
thanks in advance..
Nov 04, 2010 | Nokia 7610
7610: I want format code for nokia 7610.. I dont have an...
hey my nokia 7610 has 4 buton no work what can i do?
May 17, 2010 | Nokia 7610
The antenna of my nokia 7610 are not working... what would i do to troubleshoot this prob,
Its called P.I. You can replace it from any mobile repair shop.
Nov 17, 2009 | Nokia 7610
My signal are not working? i want to troubleshoot this problem.... but i have no idea.... can you help m for this
Antenna will cause this problem.So You can give youe phone in any authorised service center and get it serviced...This problem will get over....Hope you will succeed...Thank you...
In keypad the numbers 4,5 and 6 are not working
there is a cut line between the board, because the 456 a the same line in the outer key, so you need to jumper it , if you dont know let the technician do it, JUMPER
Apr 03, 2009 | Nokia 7610
MY NOKIA 7610 KEYPAD CONNECTORS TWO PRINT BROKEN WILL YOU SOLVE THIS PROBLEM?
just use jumper between key plate and keypad connector..
Mar 10, 2009 | Nokia 7610
There is no network coverage in my mobile (nokia 7610). If i go for manual search for operator selection it results in "no operator found". But if i put the same SIM card in any other mobile then there is...
If searcing manually say no operator found,it means any problem with receifer in your phone,for 2-4 scnd (than operator not found)check antenna and its connector.for 5-7 scnd check switch antenna. for 8-10 check RF IC. for 10 scnd up Check UEM(power IC) and CPU.But for safely do a software repair with a good PM.
Jan 27, 2009 | Nokia 7610
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
